Lens Mount Interlock
Tom Schum
Tom Schum Forum Pro • Posts: 12,320
In recent threads and in some lens adapter reviews I've read online, there is mention of something different about the lens mount in L mount cameras.
I explored this with my Sigma fp L, and if you have a different brand and your lens mount behaves differently please post!
NO LENS: Camera works fine, LCD shows light hitting sensor and you can take a picture of that (not that anyone would want to of course).
L MOUNT MANUAL LENS: Same as no lens except that there is an image. Manual lens has no electronic contacts.
ADAPTED MANUAL LENS: Same as no lens and manual lens above.
PRESSING THE LENS LOCK BUTTON AT ANY TIME: LCD goes dark, camera operation is inhibited.
L MOUNT ELECTRONIC LENS: Pressing the lock button with the lens properly mounted will remove power from the lens, and the LCD goes dark, camera operation is inhibited.
LENS HALFWAY ON, BUT NOT LOCKED: LCD is dark, camera operation is inhibited.
Conclusions: (1) This supports electronic lenses by removing power from the lens when the lens is not properly seated and locked, and when you are changing a lens with the camera powered up. (2) A lens or adapter that does not fit properly will not lock properly and the lens lock button will not pop up, keeping camera operation inhibited.
How I tested for power removal:  My Sigma 45mm F2.8 DG DN lens has the aperture completely closed down to F22 when the lens is not installed on the camera.  When I power up the camera with this lens installed, the aperture opens up.  When I press the lens lock button, the aperture immediately closes down to F22 and camera operation is inhibited.  When I release the lens lock button, the button pops up because the lens is still properly seated, and the lens initializes, the aperture opens up, and camera operation resumes.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
