Best way to autofocus on a person walking towards me?
Started Oct 19, 2021 | Discussions
canonbcguy Contributing Member • Posts: 821
I'm primarily an AF-S shooter with my Fujis.   I'd like to capture someone walking towards me using short bursts so that one of the shots may capture the best body position.
With my DSLR Nikons, I would shoot AF-C with back button focus, keeping the focus indicator on the person's body (or maybe head), and just fire away.  This seems to work well enough.
But with my Fujis being of the previous generation or older (X-T2, X-E2, etc.), I was told years ago not to trust AF-C (percentage of keepers are low) and, again, years ago, the tests showed this to be good advice.  I've stuck to AF-S ever since.
I am thinking that AF-S is not the best tactic to use as the 1st shot might be in focus (I use "focus release" with AF-S) but subsequent images may not be.
Maybe things are different with more modern bodies?
What is your experience like with shooting subjects that are closing the distance to you at a moderate pace?  (I know there have been threads complaining about shooting dogs running towards the camera but my situation is not that severe.)
 canonbcguy's gear list:canonbcguy's gear list
Sony RX100 III Nikon D750 Fujifilm X-T10 Fujifilm X-T2 Fujifilm X-H1 +38 more
Fujifilm X-E2
nightowlnz
nightowlnz Contributing Member • Posts: 518
Re: Best way to autofocus on a person walking towards me?
Generally, in my limited experience - with a moving subject, you'd want to use AF-C.  On newer cameras, like the X-T4 you'd likely use AF-C and have eye/face tracking turned on.
If you were using AF-S, with either back button or shutter focus - the camera would focus on that point, but depending on the speed of your subject's motion, by the time you take the shot - they're now closer, and wouldn't necessarily be in focus any more.
 nightowlnz's gear list:nightowlnz's gear list
Fujifilm X-T4 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Guyps Contributing Member • Posts: 579
Definitely AF-C and I would probably use the zone focusing option with the smallest 3x3 box
For Afc custom setting, try that one with a pic of someone running towards you.
 Guyps's gear list:Guyps's gear list
Fujifilm X-T5 GoPro Hero7 Black Canon EF 85mm F1.8 USM Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +5 more
baobob
baobob Forum Pro • Posts: 18,248
and add burst atCL to get several shots
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
OP canonbcguy Contributing Member • Posts: 821
Will give that a try.  Thanks.
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
AF-C, low burst rate, 3x3 zone focus should work fine with the newer bodies.
"The winds of heaven is that which blows between a horse's ears," Arabic Proverb
__
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
