iPhone 13 Pro arrived (PICS)
TempusFugit2012 wrote:
I haven't read all the responses, but from the first few that I have I'm guessing they are consistent. Marco Neroasks if the iPhone will replace a dedicated camera...on a photographer's message board that is full of photographers who love their gear.
It's probably no secret that adding a reasonable quality digital camera to a smartphone will kill off a camera/lens sale. I suspect the entire camera industry is mindful of this. The one thing we know is that everyone needs a smartphone these days... so that means having a digital camera literally at arm's reach is the reality for most of us now. If I was selling something on Ebay or perhaps selling a car, I'd simply use a smartphone these days to take the pictures. People used to borrow cameras from friends and family but they also tended to hire professionals to take pictures for them when needed. I guess those days are on the wane.
Will the iPhone 13 stop me from buying an R6? Well, yeah...for a little bit since there is only so much expendable income to go around for me. Will it replace my current bodies and lenses? Of course not because those tools are for other purposes.
Marc
iPhone 13 (Pro Max) - Initial observations - with PICS.
So far the cameras on the iPhone 13 Pro work fine although it took a few days to figure them out well enough to consider leaving my dedicated cameras behind. If I had to start again, I'd probably buy an EOS M6 II camera with four decent EF-M lenses and one EF telephoto zoom and that would probably be it. But I do appreciate the wonders on cameras like the EOS R6 and nothing quite beats the impressive bokeh from a wide aperture lens on a Full Frame camera. The image quality is simply wonderful on a dedicated camera. But I do intend to test out the iPhone 13 Pro in the desert and in several remote locations in future. Photographing closeups of venomous wildlife in Australia is going to get a little more complicated with something like an iphone though.
I've had the iPhone 13 Pro Max for 3 days now (which isn't long enough for a fair review) and I've spent each day changing settings and testing out the camera on various subjects in different types of lighting conditions. I like it and to be perfectly honest my old iPhone 6S was on it's last legs since Apple were going to stop supporting it this year and its second battery was loosing power. The Face-ID took some getting used to... until I discovered you can set up an "alternate appearance" for when wearing glasses etc. I feel the price of the newer phones is too expensive when you compare them with the price of prior models which function much the same.
The colors from my iMac wallpaper reflected nicely on the iPhone 13 Pro Max's reflective surfaces when I went to take this picture of it sitting on my desk this week.
At first I was slightly impressed with the three new cameras on the phone. Then I discovered that the images were eerily HDR-like... which turned out to be because the camera uses Apple's HEIF files instead of JPEG by default. All the HEIF files are in fact HDR shots.. which explained the ghosting effects (see example directly below which was taken on a clear sunny day as I passed someone's garden). This meant that areas of high contrast often had exaggerated halos around them. So I changed the setting to capture in JPEG instead. Again, the in-camera sharpening kicks in and produces artifacts around say leaves on distant trees etc. So then I tried ProRAW. Admittedly, this was closer to a normal shot from a camera although Photoshop didn't recognize the DNG files so I had to first open them up in Lightroom.
HEIF files have quite a bit of room for accessing and shifting the Dynamic Range of images, but so too do the JPEGs.
The HDR
A 4mm long native bee - around 1/10th the size of a Honey Bee.
Now that I've had the last two days to push the three lenses, I discovered that my iPhone 13 Pro Max required a firmware update, even though it left Apple's assembly line barely a week ago. But hidden in that firmware update was a new switch that was added to the iPhone's camera app. In the menu, you can now finally tell the camera to stop shifting between lenses when attempting to take a macro image. The new switch is called "Auto Macro" (on/off) and it appeared right at the bottom of the camera settings in the User Settings menu... so it's wasn't immediately visible unless you scrolled right down. With this switch activated, the camera stops trying to switch between lenses when its trying to focus using Macro. Now, you simply select the Wide Angle lens when using the Camera app and just zoom the camera towards the subject with your hands. I am glad they did this because the first day of trying to use macro was nightmarish as the camera just kept switching between lenses.
Image quality? I'm not really sold on it yet. The closeup shots if using the 77mm camera seem awfully digital looking and smeared. It's like the camera switches to a digital zoom instead of an optical one. Either way, I thought this would be great to have a 77 optical zoom on a camera yet the results are unsatisfactory to me. Perhaps I'm doing something wrong.
The HDR effect from using a HEIF file format
Even in JPEG mode I get halos around the fine details on trees. Holding a CPL filter in front of the lens was not as simple as I thought it would be. Nor was it necessary with most sky images. Using a CPL filter with the Wide Angle lens was much more difficult - although this image was shot using the 77mm lens.
Overall, the majority of shots are noticeably better than my old Apple iPhone 6S. But I'm personally unconvinced that the new iPhone 13 Pro Max is capable of remotely approaching the image quality of a dedicated camera without the continued use of ProRAW format images. Even then there's quite a few compromises due to image size and file conversions etc. I made the mistake of shooting with 16:9 format and ended up with duplicate images since this "letterbox" format in the camera menu is simply an internally cropped 4:3 image... which seems a little less than ideal to me.
The "Synthetic Bokeh" is surprisingly good in MOST (but not all) cases.
Homemade sourdough pizza.
If you get enough light your macro shots can be acceptable.
This image was in taken in shadow with my back to the sun.
The Macro is a little hit-and-miss. But it's MUCH more reliable since downloading the Firmware update yesterday. I rescued this Honey Bee from ants on a hot road earlier today.
I intend to test the iPhone out in the city tomorrow. It will give me a chance sample some of the sort of photography I would normally use my iPhone 6S for and should prevent me from having to carry my mirrorless APS-C and Full Frame cameras with me - which is something I often do.
My initial thoughts are that as good at the images can be, there's still a little inconsistency that hampers my use with this device when using it as a camera. But having all my music and photographs and videos alongside me with a larger screen than I'm normally used to is almost like using a tablet or iPad mini. I suspect the Macro feature on this new model of iPhone was never intended for viewing plankton but if you keep your distances practical the results are pretty reasonable.
An uncropped image showing the smeared look which is occasionally generated by the 77mm lens - especially when using it for "closeups". I can't quite understand why it does this. It's clearly a "digital zoom" being used when the images turn out like this. Sometimes the wide lens (which is the Macro lens) does this as well. I took a landscape shot earlier today and ended up with similar muddy details. I have no idea what's happening here.
It wouldn't be fair for me to review the iPhone 13 Pro Max cameras until I've spent more time with it to determine what I'm doing wrong or to at least understand what the limitations are. Anyone with ProCam (aka ProCam 8 and ProCam XL) - which is a manual-control App for shooting better images with your iPhone cameras - should known that it appears to work perfectly well with the iPhone 13 models. At first it wouldn't work properly until I delved into the settings to give the App access to my Photos folder. But the Auto-Focus is far more reliable and even manually controllable using the ProCam App. With the native Apple Camera App I had little chance at getting reliable AF with SUPERCLOSE subjects yet the ProCam worked perfectly.
What I'm noticing is that these images look fine at a distance of when viewed in their entirety. But zoom in to 200% and the details are essentially gone and the images fall apart under closer inspection. The one thing that impresses me is the artificial bokeh... which appears to use the LIDAR to scan the subject and then separate it from the background. The effect is surprisingly convincing and it's certainly appealing for certain subjects. I did notice, however, that when lifting the shadow details in a shot taken of a flower (not shown in this set) that the masking was visible along with a lot of grain that surrounded the masked subject. So at this point, when it comes to sheer image quality, the iPhones aren't about to replace my cameras for anything extremely important but they certainly have come a long way with the present models.
I think I posted all of these images (above) at full size (around 4000 pixels wide) but they've been tweaked slightly in both Lightroom and Photoshop. When I've thrown some more challenging subjects at it, I can perhaps write a more detailed report in a fresh thread some time next week if anyone is interested.
