LG Monitor stopped working over USB C on MacBook Pro M1
birdbrain
birdbrain Veteran Member • Posts: 4,009
My 5K LG monitor which is connected to my MacBook Pro M1 via USB C suddenly stopped working?
No picture at all was visible, the monitor sensed that something was connected and asked if I wanted to switch to that input. But when I did the screen was blank and it would go into sleep mode.
The USB C port still powered my MacBook Pro.
I tried connecting my iPad Air to the same monitor via USB C and that didn't produce a picture either.
I then went into the monitors menu and under settings selected reset. Having done that it worked again when connected by USB C.
When it wasn't working via the USB C port, it worked via an HDMI port using a USB C hub which has an HDMI output.
Phil
I wondered why the ball kept getting bigger, then it hit me.
http://www.flickr.com/photos/philthebirdbrain/sets/
 birdbrain's gear list:birdbrain's gear list
Sony RX10 II Canon EOS R5 Canon EOS R6 Canon EF 16-35mm F2.8L II USM Canon EF 24-70mm F2.8L II USM +7 more
