R6: Viewfinder ON when display off and no eye behind it ?
mermaidkiller Senior Member • Posts: 1,341
When using the R6 for astrophotography, I use an Android app 'DSLR Dashboard' where the camera is connected via USB. Works flawlessly, so I don't need the display of the camera. So then I reverse the display of the camera so it is turned off anyway to conserve battery power.
But in that case the viewfinder is turned on (showing a timer) during bulb exposure even when no eye is behind it and display is set to screen only (which is collapsed). This wastes the battery and I don't need it, as the same timer is shown on the Android screen (or an external intervalometer if I use that).
Anybody have the same issue ?
Ricoh KR-5 ... Pentax ME Super ... Canon T90 ... ... ... 40d ... 7d ... 6d ... r6
 mermaidkiller's gear list:mermaidkiller's gear list
Sony RX100 VI Canon EOS R6 GoPro Hero7 Black Canon EF 85mm F1.8 USM Canon EF 50mm f/2.5 Macro +5 more
Canon EOS R6
MasterWayne Regular Member • Posts: 133
Re: R6: Viewfinder ON when display off and no eye behind it ?
Hi,
I just opened a dedicated thread since similar questions turned up several times already.
https://www.dpreview.com/forums/post/65560540
Short answer:
When folding in the LCD, make sure it shows to the outside. Then all displays are turned OFF and only the EVF turns on in case you approach the eye-sensor. This needs a little preconfig, see the other thread.
Hope this helps!
 MasterWayne's gear list:MasterWayne's gear list
Canon EOS 80D Canon EOS M50 Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 135mm F2L USM +4 more
