Oly 60mm f2.8 macro focus limiting
Started Oct 13, 2021 | Discussions
OP bbbbbbbbbbb Senior Member • Posts: 2,239
Re: Oly 60mm f2.8 macro focus limiting
Another quirk of this curious lens is the default focus position for each of the focus ranges:
Closest range 190-400mm: The default is somewhere in that rage. Makes sense.
Full range 190mm-infinity: The default is infinity.
Far range 400mm-infinity: The default is close to 400mm.
It's curious that the Full range defaults to infinity but the Far range defaults to the closest end of its range?  Just curious if there is a purpose in this or just a quirk of the system? It's no biggy, just curious.
 bbbbbbbbbbb's gear list:bbbbbbbbbbb's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus E-450 +8 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Try to beam yourself into the minds of Japanese engineers
The way I see it, it makes sense to have different defaults for full and far range. That way you can use one as infinity preset, the other for near preset.
Other than that, the far only range is IMO not very useful in practice. I guess it is only there, because it was easy and cheap to implement a position between near and full range.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
Bassam Guy Veteran Member • Posts: 4,885
Headaches
I think the engineers just got headaches contemplating half of infinity and gave up.
I only wish the two ranges overlapped a bit. At .4m you're forced to use .19m-inf
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Re: Headaches
What would make some logical sense for fly-by-wire lenses in general, is that they defaulted to the hyperfocal distance for whatever aperture was set. Perhaps some do, I don't know.
