Re: Oly 60mm f2.8 macro focus limiting
SterlingBjorndahl wrote:
BobT3218 wrote:
Can anyone explain why this is and how it's supposed to be used?
I think this has been answered already, but another way to put it is: This switch is not intended to override the camera body's setting of AF vs MF. You can't use it to switch the body to MF.
It might be cool if it did, but then what steps would be needed to revert the body back to AF - would you need to change both the lens switch and the body's setting? Would the lens switch force the body back to AF even if you previously had the body set to MF? And would all the MFT camera body manufacturers agree to implement it the same way? (MFT bodies are made by more than just Olympus and Panasonic.)
Most macro lenses do not have such a focus limiter switch. In fact, very few do.
So the question can be asked: why having it at all?
Because it CAN make life easier. Note CAN, not must.
If not needed, or not desired, the focus switch can simply be ignored. Use the 60mm lens like any other macro lens. It is not at all a requirement to set the focus limiter away from its normal position to shoot macro pics.
I see the focus limiter switch simply as a nice-to-have option. Great that Olympus included it in this lens almost for free. But nobody is compelled to use it. Like the snap focus clutch in the pro and some premium lenses. Nice to have it. But some people do not like it, so they simply do not use it.
To be honest, if there were two versions of the 60mm lens at the same price, one as is, the other with no focus limiter but instead the snap focus clutch, I would much prefer the latter .
If the 60mm was offered $50 cheaper without the focus limiter, I would buy the cheaper version. But since it only comes with focus limiter, I do use it. Quite a lot actually.
