New RF 16mm has quite some vignetting at F2.8 - (with no Lightroom lens profile yet)
Started Oct 13, 2021 | User reviews
phatgreatwall Regular Member • Posts: 182
Re: New RF 16mm has quite some vignetting at F2.8 - (with no Lightroom lens profile yet)
tkbslc wrote:
Swerky wrote:
That’s basically fine. Sure for a prime lens distortion should be better, but it’s an affordable fast ultra wide angle lens. By f5.6 vignetting is gone. Good show.
Gotta remember it's a Full frame f2.8 ultrawide and it's the size of a nifty fifty and costs $299. We all knew there would be compromises.
exactly.  i had the sigma 14 1.8, 20 1.4, canon ef 16-35 2.8ii, tamron 15-30 g2, and i'm more than happy to exchange the weight for more time post processing.
And-roid
And-roid Senior Member • Posts: 3,198
Both the Sigma and the Canon 15mm seem to work well as a donor and then reduce distortion to around 40 to taste.
atolk Regular Member • Posts: 120
Did you mean to give the lens 0 stars? Averaged with one other review (4 stars), the lens currently has a 2-star rating on DPR. Granted, this is not enough data to make a purchase decision on (Amazon has 4.8 stars on 118 ratings), but still.
Thanks for the sample photos!
 atolk's gear list:atolk's gear list
Canon EOS 6D Sony a6500 Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM +4 more
ProDude Senior Member • Posts: 4,851
One of many reason I dumped everything Adobe years ago. LOL Use it at your own peril.
Name the gear and I've probably owned it and used it.
CameraCarl Veteran Member • Posts: 9,193
This thread is OLD. Adobe has had a lenses correction profile for months.
yeah but nothing has otherwise changed about Adobe. They still suck
PicPocket Veteran Member • Posts: 5,897
So nothing to do with this thread, you just want to vent out even when you are no longer a user.
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Interpol Regular Member • Posts: 480
Given that you "dumped everything Adobe years ago", I'd recommend that people take your assessment with a very small grain of salt.
You sound like one of those people who gives a movie a bad review despite never having watched it.
 Interpol's gear list:Interpol's gear list
Sony RX100 VII Canon EOS R6 Canon EOS R3 Canon EOS R7 DJI Pocket 2 +32 more
mermaidkiller Senior Member • Posts: 1,450
Re: New RF 16mm has quite some cropping as well
The autocorrection crops the image considerably.
I took a photo of a brick wall and have the jpg and the cr3, of which I corrected the latter manually. The FOV of the cr3 is about 10 degrees more than the .jpg.
I compared it with the Samyang 14 before I sold the latter and saw that the FOV is with manual correction the same as the Samyang 14,
But in both cases the IQ is very good for such a cheap lens and I like it even more than the Samyang 14 as the latter is heavy and bulky and its 'moustache distortion' is more difficult to correct, despite having a lens profile in Affinity and Photoshop. Both apps lack a lens profile of the RF 16, but correction is much easier.
Manual currection of the CR2
In-camera correction of the JPG
Ricoh KR-5 ... Pentax ME Super ... Canon T90 ... ... ... 40d ... 7d ... 6d ... r6
 mermaidkiller's gear list:mermaidkiller's gear list
Sony RX100 VI Canon EOS R6 GoPro Hero7 Black Canon EF 85mm F1.8 USM Canon EF 50mm f/2.5 Macro +5 more
Sittatunga Veteran Member • Posts: 5,406
The DPP4 auto correction for this lens gives exactly the same field of view as it does for the EF 16-35mm f/4. PhotoLab gives a slightly larger field of view. I have both lenses now and have compared them.
12mm field of view. I hid the superimposed distortion corrected image layers for clarity, just leaving the frames.
When you correct barrel distortion manually, you end up magnifying it to a greater degree with increasing distance from the centre. As the ends are further from the centre than the sides, and the corners are even further, you would end up with an image with roughly parabolic concave sides if you didn't crop it at all. For the amount of barrel distortion this lens has, the largest rectangle you could crop out of this curved shape has an aspect ratio close to 16:9, which means that using PhotoLab I can get a field of view with this lens a little wider than a 16:9 crop from an image cropped at 16:9 from a 14mm rectangular lens.
Kameratrollet Senior Member • Posts: 1,099
The profile for RF16 was released for six month ago for Lensfun (Affinity).
JustUs7 Senior Member • Posts: 4,327
If that’s you, you’ve been doing a great job keeping up on releases. Thanks. I noticed the 100-400 is available too.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
At Lensfun and its database the vignetting correction data is still missing. You can manually copy from the print screen below or just copy paste from the xml file at my page .
