New RF 16mm has quite some vignetting at F2.8 - (with no Lightroom lens profile yet)
Started Oct 13, 2021 | User reviews
Ojee99 Junior Member • Posts: 31
6
Brand new, picked up from the shop today.
Small, light weigt, compact, the ideal lens to take for walk into nature...
Lightroom (CC) has no lens profile for it, yet. So pretty much vignetting to be seen in the corners at F2.8...
First quick set of photo's at F2.8 & F5.6 & F11 and F22
And here is another quick set of photo's: F2.8 & F5.6 & F11 and F22
Even at F4.0 quite some vignetting, well visible in this shot with light sky in the corners
Canon RF 16mm F2.8 STM
Wideangle prime lens • Canon RF
Announced: Sep 14, 2021
Ojee99's score
0.0
Average community score
2.0
tkbslc Forum Pro • Posts: 17,522
As expected
Thanks for sharing. I knew with the size and weight it had to be a veritable fisheye lens. Looks like I was correct.
Did you try any with JPEGs to get the in camera corrections? Or maybe DPP has a profile ready?  Wondering how much corner softness is introduced to fix the distortion.
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
Re: New RF 16mm has quite some vignetting at F2.8 - (with no Lightroom lens profile yet)
How does it look in DPP4?
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
OP Ojee99 Junior Member • Posts: 31
Re: As expected
In-cam correction helps for JPG: in Lightroom JPG looks better and CR3 still looks bad.
But the JPG is a crop from the CR3, so it cuts off the vignetted corners and is straightened.
I'm pretty new to this, it this a normal way of correcting the vignetting, just cutting it off?
(perhaps the CR3 in LR shows more then I already saw in my EVF, so I get actually the same as I saw in my EVF?
In DPP it shows both the corrected JPG and CR3, so yes, it looks like DPP already has the correct profile for this lens? I'm not experienced with DPP, so don't know where to look?
JustUs7 Senior Member • Posts: 4,327
Thanks for sharing. I’m used to wide angle corrections with the 24-240 and don’t have a problem with them.
More curious about the coma and if this will be of any use for Astro, or even Christmas lights. Looking forward to more reviews.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
Re: As expected
Would you be willing to share some JPEGs at large size so we can see what the corrected corners look like?  Thanks in advance if you can.
If it is like the 24-240mm and 14-35mm,  the lens is actually wider than advertised, and then they fix distortion, crop out the extreme vignette and the end results is the advertised FOV.   So it should still be 16mm after correction.
If you are on the edit image window, click on the tab that looks like a lens.  And then a little ways down there is a thing that says "Lens Data" and then either Yes or No.   If it says No, then click the little circle arrow button next to it and it will bring up the list of profiles you can download.  I just tried it and 16mm is there.   Once you get it downloaded, then you can enable the Lens Optimizer, Peripheral illumination and distortion corrections.
Yes, that's what I'm also curious about. Is there a way to test this, without having a clear sky these days?
If you have a strand, shoot Christmas lights in the dark at f/2.8 from a distance.
Re: As expected
Indeed I can download the lensprofile.
Wil retest again tomorrow, and share large size images with jou.
SergioMPS
SergioMPS Regular Member • Posts: 261
Re: not bad
doesnt look that bad uncorrected, its one of those lens that correct from DPP is required (dont know when LR is gonna update and add profiles)
slight C.A. but for that price i think is gone be great add on to my 24-105
 SergioMPS's gear list:SergioMPS's gear list
Canon EOS 7D Canon EOS M5 Canon EOS R GoPro Hero8 Black Sony RX100 IV +17 more
JConrad Regular Member • Posts: 318
Thanks for the samples.
As expected due to the small size, the barrel distortion is massive, and has some complexity to it, so simple distortion tools won't fix it...we'll have to wait for the profile to use it outside DPP for architecture.  However, we all new this going in.
Optically it doesn't look bad at all given the size and price.  Not amazing wide open, but sharp in the central portion, which should allow to use it for closer subjects with a bit of isolation.  Stopped down it looks pretty good.  not amazingly pin sharp in the corners, but excellent over most of the frame, and decent at the edges.  I think this will do very nicely for such a compact lens.  I hope mine comes in today.
 JConrad's gear list:JConrad's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM Fujifilm X100V Canon EOS RP +9 more
CameraCarl Veteran Member • Posts: 9,193
Adobe is expected to release a major update to Lightroom at the Adobe Max conference later this month. I wouldn't be surprised if the lens profiles for this and other new Canon RF lenses are included in the update.
Kameratrollet Senior Member • Posts: 1,099
If you take a raw sample like this https://d2x313g9lpht1q.cloudfront.net/original/3X/9/9/9950e596846a6f27c6e39139f56b1966c495f7b0.jpeg
8 meters away and at f/8 I can try to get distortion correction support for RawTherapee, ART, darktable, DigiKam, Topaz Studio, Photomatix, ON1, ACDSee, easyHDR, SILKYPIX and Affinity Photo.
A straight line at the top and a straight line 1/3 down is what I need.
Brick walls are not good enough.
Swerky Contributing Member • Posts: 793
That’s basically fine. Sure for a prime lens distortion should be better, but it’s an affordable fast ultra wide angle lens. By f5.6 vignetting is gone. Good show.
No perfect gear out there. Just be happy with what you have and go shoot.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
GrunRad
GrunRad Regular Member • Posts: 118
In addition to the RF 16mm/2.8 and RF 100-400mm/5.6-8.0, Adobe has not managed to provide lens profiles for the RF 14-35mm/4.0, the RF 50mm/1.8 and RF 70-200mm/4.0  lenses yet (the two latter having been released almost a year ago!).
It would be a pleasant suprise indeed if Adobe had finally got their act together in regards to Canon RF lens profiles (and camera profiles, too)...
 GrunRad's gear list:GrunRad's gear list
Canon EOS 5D Canon EOS R5 Canon EF 8-15mm f/4L Fisheye USM Canon EF 40mm f/2.8 STM Canon EF 24-70mm F4L IS USM +9 more
This is especially frustrating given they want us to pay monthly and part of their justification was for ongoing updates and support.   What are people paying them for!?
SergioMPS
also EOS R is the last one to get color profiles, for crops M5 i think?
this prime always requires post-correction (unless shooting jpeg) its just designed that way like 14-35 and 24-240 (shooting wider to crop/stretch afterwards)
Sittatunga Veteran Member • Posts: 5,406
Just for fun, I had a go at straightening it out in PhotoLab. Too much barrel distortion for PhotoLab to correct completely, so I tried 10% fisheye correction and a bit of vignetting adjustment;
The barrel distortion lessens a bit at the corners which is why there's pincushion distortion in the corners but not in the middle with simple warping. The stretching has changed the aspect ratio from 1.5 to 1.63:1, but that's to be expected.
For a cheeky comparison, here's my RX100 II at 10.4mm f/1.8 (28mm f/4.7 FFE), with the ARW file saved as jpeg by Windows 10 Photos, no adjustments at all;
And with 13% fisheye correction, because the overall barrel distortion is slightly greater. The uncropped aspect ratio is now 1.64:1;
And as exported by PhotoLab from the ARW with camera corrections, standard noise reduction but no other tarting up. PhotoLab crops to the original aspect ratio after correcting the distortion unless you tell it not to;
Both cameras are 20 megapixels, but the R6 + 16mm seems to be about twice as sharp in the middle and even more than that in the corners.
RLight Senior Member • Posts: 4,418
Sharper than anticipated
This lens is sharper than I thought. I look forward to more samples.
The non-corrected output was expected. That's how they're getting it so compact is by design for corrected output workflow. The 17-40L, folks forget how much distortion that puppy can have at 17mm uncorrected (a lot).
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
Gotta remember it's a Full frame f2.8 ultrawide and it's the size of a nifty fifty and costs $299. We all knew there would be compromises.
