Cropping and Upsizing with Topaz
rick decker
MOD rick decker Forum Pro • Posts: 18,159
Both Topaz Gigapixel and Adobe SuperRes are reasonable solutions for upsizing. Here is a shot I took and wished I had brought a longer lens.
Image1 the original shot with some editing but no croping or upsizing. Takenwith a 15-30 at 30mm on a 1.7 crop: (image1)
Cropped it down to get the tighter composition 1232 x 881: (image2)
Next run through Topaz upsizing it to 3010 x 2148 (image3)
Any comments appreciated.
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
Ken60 Senior Member • Posts: 3,181
Re: Cropping and Upsizing with Topaz
5
Rick , I have to be a swine and say I prefer the first shot. The sheer scale of the waterfall, and the dwarfing of the human figure, truly represent "man v nature"  in a way the others dont.
Never mind the tele, bring shower gel and a towel nest time !
Gear ... what I need to get the job done , after all you don't see mechanics listing their brand of spanner as a qualification .
Lan Veteran Member • Posts: 3,325
Nice shot Rick - I can see where Ken60 is coming from, but I find the crop stronger as the person stands out more. I suspect the uncropped version would win when printed big though?
FWIW there's one obvious issue with the upscaled version; the CA is bad. The (frame) right leg is green, as is the right half of the person's hair. There's a clear magenta halo around the rock they're standing on too. I recommend you fix the CA before you crop and run Topaz.
I might also experment with the different upscaling models a bit more? This one's a bit oversharpened, but I think your original is a bit under sharpened:
Crop uprezzed using Topaz Gigapixel AI, Lines model (SN:0, RB:63). Some painting in Color Mode using the Clone Tool to try and correct the worst of the CA.
Hope that is of use; it's a great shot
robert1955 Veteran Member • Posts: 6,303
Image 3 seems a bit softer to me.
Have you compared to traditional {Photoshop] upsizing?
 robert1955's gear list:robert1955's gear list
Fujifilm X-E3 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
rick decker
OP MOD rick decker Forum Pro • Posts: 18,159
Well I  have to agree with you. I was surprised myself.
rick decker
Thanks...I probably will just leave it as the more I compare the two the more I prefer the vertical  Appreciate the input.  It is good that I know to look for CA and  color issues.
rick decker
Not on this shot but on others altahough I have not kept the results.  Both Topaz and SuperRes do a  noticeably better job.  I have compared it to photozoom and both are better.  When I get some time I will do another post.  May be a few days.  Image3 would have to be somewhat softer given the upsizing.
If I can suggest , a tad more contrast in water and darken sides.... like a curtain tight top loose lower.
rick decker
My goal in this first round is to get some feedback from people about the general usefulness of these new upsizing products (GigaPixel and SuperRes).  The comments about CA and Magenta are (IMO) more likely related to the lens (Sigma 15-30 very old) and/or sensor (SD9).  I am glad these issues have been brought up as it will be something to be aware of in future comparisons.
1Dx4me
1Dx4me Forum Pro • Posts: 12,697
Rick, your 1st shot is brilliant, it gives the true sense of a majestic fall and the person in front of it, give the size and scale of the fall! the second shot shot is ok, too, but nothing like the 1st one. TFS.
the nest.
Nature is under no obligation to make sense to us!!!
poldersnapper
poldersnapper Veteran Member • Posts: 4,988
Perhaps keep it vertical?
Hi Rick,
This would be my crop, keep it vertical to accentuate the impressive waterfall. Also made the highlights less bright and darkened the person a little:
André
http://mcpint.zenfolio.com
'Forever Morning'
Mr. Tony Banks
rick decker
Re: Perhaps keep it vertical?
Thanks for the input.  It is difficult to say which I prefer.
ThrillaMozilla Veteran Member • Posts: 6,143
Here you go. Upsized with special sauce and sharpened by magic.  Compare it to your upsized and sharpened one.
Details deliberately withheld for the moment.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EF 400mm f/5.6L USM
Kofla Olivieri
Kofla Olivieri Regular Member • Posts: 265
Thank you for sharing your images. I have been debating if Topaz GigaPixel is something I should get to use in some of my older images.
 Kofla Olivieri's gear list:Kofla Olivieri's gear list
Nikon D7000 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Sigma 10-20mm F4-5.6 EX DC HSM Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR
JT26 Veteran Member • Posts: 4,409
Cool shot Rick and impressive upressing.
I think I would keep the crop really tall, maybe 1x2 with the man at the very bottom and maybe in black and white... Would look fabulous.
Love the shot
sobrien
sobrien Senior Member • Posts: 1,721
Your original crop looks better to me than the upsized version viewing at full screen view, just FWIW.
Stunning image btw.
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
rick decker
I have lots of   samples and comparisons with SuperRes I can make available
rick decker
agrreed...thanks
rick decker
will check it out later...see my PM
Hmm,. Maybe I assumed incorrectly that your upsized version was sharpened. And maybe I didn't do the image right.
Here's what I get when I sharpen mine again (after upsizing). I notice that it has the jaggies from upsizing.
Sharpened(?), upsized, sharpened again. Maybe not optimum.
And here's what I get when sharpening your upsized version.
Your upsized version, my sharpening.
By the way, I like the uncropped version. Print it big and you can have it both ways. Great photo..
There is, however, a little mistake in processing around the rock that he is standing on.  It looks like a masking error.
