Dp3 Merrill Macro Focus Issues: Am I a dingus?
16GreenBeans
16GreenBeans New Member • Posts: 15
Hey there,
I have a dp3 Merrill and absolutely love taking close up macro photos with it due to the high level of detail it provides. One rather annoying quirk I keep running into however is a strong falloff in focus near the far edges and/or corners of my photos.
For example, here at both the right and left ends of the image:
And here at the top right corner and bottom third of this photo below:
These photos were taken of a flat surface with the camera both on a tripod and aligned to not be on an angle. Despite this, almost every macro photo I take seems to have rather unpredictably spotty focus.
I am no pro photographer by any means, so Is this due to me just not using the proper settings or procedure when doing close-up photography? Does anyone know how I can address these issues in focus?
Sigma DP3 Merrill
brendanpaxton
brendanpaxton Forum Member • Posts: 68
Re: Dp3 Merrill Macro Focus Issues: Am I a dingus?
16GreenBeans wrote:
Hey there,
I don't think this is user error, unless you miscalculated the surface being flat and at perfect angle. This is a typical issue you see with lenses (usually cheaper lenses), and usually at larger apertures, and also usually with wide angle lenses (edge distortion). Surprising to see at 50mm.
Since the lens is fixed on that camera, I would suggest trying different apertures on the same frame/subject to find the sweet spot of edge-to-edge image clarity. Each lens really has its own sweet spot on edge-to-edge clarity and it's never where you'd think it would be. Some lenses are sharpest at f/4, some at f/22.
 brendanpaxton's gear list:brendanpaxton's gear list
Sigma sd Quattro H Sony a1 Sigma 35mm F1.4 DG HSM Art Sony FE 24mm F1.4 GM Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +6 more
atom14
atom14 Senior Member • Posts: 2,896
No, I don't think so. The focus on these does sure look off - and patchy. Sweet spots - a vagary at best - notwithstanding, that should not be happening at your f/7~8 aperture.
I don't have the camera, but others here can weigh in with advice. I suspect it's crook.
atom14.
16GreenBeans
OP 16GreenBeans New Member • Posts: 15
Hey Brendan,
Miscalculating the angle could certainly could be the case. I took some additional macro shots to test focus and there does seem to be consistent fuzzy corners and the occasional fuzzy edge.
Here with all four corners.
And here at the top two corners, as well as the left edge.
I will certainly give your idea of running through the apertures a shot.
Best,
GB.
16GreenBeans
atom14.
Hey Atom,
That could also very well be the answer as I am not the best when it comes to precision.
I took some additional test shots, showing repeat corner focus issues, in my reply to Brendan's post. I will continue to experiment just in case a solution reveals itself.
Best,
GB.
brendanpaxton
atom14.
Here's just a quick example I found of a 50mm lens comparison re: edge clarity performance w/aperture. (Skip to 10:25) https://www.youtube.com/watch?v=H_lpIwauRPI
Tom Schum
Tom Schum Forum Pro • Posts: 12,308
Are you using a magnifying lens on the front of your DP3M?
Hoya 58mm HMC Close-Up Filter Set II (+1, +2, and +4) A-58CUS-II (bhphotovideo.com)
Maybe the image would be more evenly focused with one of these on the front? Just a thought.
Sorry I could not find the spec for filter thread for the DP3M, not even on Sigma USA. But, you could buy an adapter ring to use the above 58mm lens set. There are quite a few similar lens sets available at B&H.
I used to have a DP3M but never used it for macro.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
DavidWright2010 Veteran Member • Posts: 3,141
This is not a good test image
Hey Brendan,
Best,
GB.
exposure of 0.6 seconds? Anything could go wrong. And it looks blurred all over.
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
brendanpaxton
Re: This is not a good test image
Hey Brendan,
Best,
GB.
David
Nothing wrong with 0.6 sec, We were told the camera is on a tripod (and there is clearly no motion blur in the image).
brendanpaxton
I second this - I didn't look up the minimum focus distance on the DP3 - 8.9". So they did leave out the details of how they were getting the macros.
@OP - any additional lensing elements added to your lens will result in poor performance like this, especially magnifying elements. Even flat, simple UV filters can mess with clarity.
rick decker
MOD rick decker Forum Pro • Posts: 18,145
The first test I would run is to get a hard-cover book with a cover that has textual detail including a variety of sizes.  Possibly a box that is flat enough.  See how the text looks across the frame.  The closer you are to minimum focus the more likely you are to see soft corners/edges.  I know that my DP3M at minimal distance, which I do not use in real life, has soft corners at times.
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
Hey Brendan,
Best,
GB.
David
Here's a 400% crop from the center .It certainly looks blurry to me:
David
D Cox Forum Pro • Posts: 30,237
Stop down more. I generally use f/11, f/13 or f/16 for macro on the DP3M.
Check your alignment more carefully. A copy stand is easier to level than a tripod. I use a spirit level that's about 3 inches (75mm) long.
Is your subject really flat ? Are you using a close-up lens ?
Don Cox
Sigma fp
The Raynox 150 and 250 give good results on the DP3M. Other close up lenses vary -- I have a Marumi that's OK. But the DP3M focusses quite closely on its own.
Don Cox
Sigma fp
I think those Hoya lenses are single-element, so they will not give critically sharp images. There is likely to be chromatic aberration.
It's 52mm.
Don
Sigma fp
brendanpaxton
David
David
Anything will look blurry at 400% crop.  But this is a good example to show there's no motion blur, as each thread is ghosting in different directions. Check the bottom of the image, it's pretty sharp. It's a lens issue, not a shutter speed issue.
xpatUSA
xpatUSA Forum Pro • Posts: 20,719
David
David
I disagree.
David's zoom above is not smoothed; therefore the blur is in the capture and was not caused by the 400% zoom.
Just interested in the technology.
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +12 more
brendanpaxton
David
David
I disagree.
Creating pixels out of thin air where there were none (zooming to 4x the data's resolution, i.e. upscaling by 4x) requires extrapolation of data. The result will always appear blurred. Blurring (i.e. averaging of neighboring points) is inherent to any interpolation or extrapolation process.
The OP's image is sharp in the bottom of the frame. And there is no >>motion<< blur in the image.
As Ted pointed out, you misunderstood my example. There was no resampling, and at 400% I would expect to see pixels, like in this 400% crop of a flower bud:
(This is the 100% crop:)
The OP's image has plenty of fibers in it, I'd expect to see  them 1 pixel wide, but they aren't.
Right now I'm leaning toward operator error,, but as I said originally, a 0,6 sec exposure is not the way to test  that.
David
16GreenBeans
Hey Rick,
I followed out your idea for a test using two hardcover books I had lying around with good textured covers.
For note, I am not using any macro/close up lens filters and am only using a tripod with a built in spirit level. This test was done with each book flat against a wall.
Here at the righthand corners and bottom left corner.
And here at each corner as well.
From your own personal experience, the constant presence of soft corners may unfortunately be the case with my Merrill as well.
