X100F Custom Display settings not working.
Started Oct 8, 2021 | Questions
bs1946
bs1946 Veteran Member • Posts: 7,778
I have two X100S models, a Silver X100S one and a Black Limited Edition X100S. I have everything turned on in the Set Custom Display, except for the histogram, for both the EVF/LCD and OVF. Everything was working fine in both cameras but all of a sudden the Gridlines, Electronic Level, and AF Distance Scale have vanished on the black X100S. I have the camera set to AFS and tried AFC but still the same. When I switch to MF, the manual distance scale is displayed but the grid and electronic level are still missing. Same if I switch from EVF to OVF.
Anybody else encounter this and know how to fix it. I've tried turning everything off and then on in the display custom settings and still no change.
Bill S.
www.flickr.com/photos/wrs1946
“If your pictures aren't good enough, you aren't close enough”
? Robert Cappa ?
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Fujifilm X100S
Erik Baumgartner Senior Member • Posts: 6,894
Re: X100F Custom Display settings not working.
Press the DISP/BACK button?
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
bs1946
OP bs1946 Veteran Member • Posts: 7,778
Thanks Ed, forgot about that, it was set on STD. Switched to custom and all is back.
Bill S.
? Robert Cappa ?
