Artifacts on X-T4
Started Oct 7, 2021 | Discussions
maksay New Member • Posts: 1
Artifacts on X-T4
Rarely when I am taking photos with my X-T4 I see such artifacts. They happen maybe once in 1000 photos. Although it is not a very very big deal I can't understand why...
Do you have any idea about it? (I was able to catch these artifacts with XF18-55 also few times)
small artifacts
bigger artifacts
Aoi Usagi Veteran Member • Posts: 3,222
Re: Artifacts on X-T4
Try a different SD card.
Erik Baumgartner Senior Member • Posts: 6,893
small artifacts
bigger artifacts
Wow, something’s broken (try a different SD card), or we’re all living in the Matrix and you just managed to get a shot if it.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
(unknown member) Contributing Member • Posts: 813
Wow... that's definitely a corupt image, but we need to know the reason. I don't think the SD card would be the cause...  if it appears to be an in-camera problem you might try doing a reset (and a different SD card won't hurt) but I think ultimately it may require service...
Cheers !
Jean
