Canon Has released a new firmware for the G7X III.
Info from canon website:
Firmware Version 1.3.0 incorporates the following enhancement:
1. Adds support for [Video Blog Recording Mode] setting to the [Movie Mode] function.
2. Adds support for [Zebra Settings] to the [Movie Mode] function.
3. Adds support for [Aspect marker] to the [Shooting information display setting] in [Movie Mode].
4. Adds support for [Recording emphasis] to the [Shooting information display setting].
5. Adds supports level display when AF mode is set to [Face + Tracking priority AF].
Firmware Version 1.3.0 is for cameras with firmware up to Version 1.2.0. If the camera's firmware is already Version 1.3.0, it is not necessary to update the firmware.
Notes:
Users manual in the WEB is updated accordingly. Please download the manual as well as the latest firmware. You can download it from the official WEB site.
Q&A:
Preparations for a firmware update:
After the downloaded compressed file (.zip) is extracted, a firmware folder is created.
*Extracting the downloaded file:
Right-click the zip file, and then select Extract All to extract the file.
In the folder you downloaded are the firmware ( PSG73130.FIR / file size: 29,762,976 bytes) and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish, and Simplified Chinese). Before starting the firmware update operations, please be sure to check the procedure in accordance with the instruction.
(The following is the history of past firmware updates.)
Changes in version 1.2.0:
1. The option to capture movies in the frame rate of 23.98p has been added.
2. The BLE remote (BR-E1, HG100-TBR)is supported when using Wi-Fi when live-streaming*.
*This function is only for the area in which live-streaming service is available.
3. In the autofocus characteristics for Movie Servo AF, "Responsive" is available below [Mode 1] in the menu and "Smooth" is available below [Mode 2].
Changes in version 1.1.0:
A new mode for Movie Servo AF has been added.
Autofocus characteristics for Movie Servo AF can be set to [Mode 1], [Mode 2] or [Disable].
・Mode 1 (newly added, with firmware version 1.1.0): This mode supports quick and responsive autofocus. Use this autofocus mode when you want the camera to be sensitive to tracking the subject, and for situations when the photographer is moving (such as shooting while walking).
・Mode 2 (current, with firmware version 1.0.1): This mode supports smooth and natural autofocus when shooting movies. Use this mode when shooting landscapes or subjects with little or no movement.
"If you prefer the previous AF characteristics, please select Mode 2 after the firmware update."
