Shutter Release Half Press Focus Problem?
Started Oct 4, 2021 | Questions
bs1946
bs1946 Veteran Member • Posts: 7,778
I've been using my recently acquired Fujifilm Black Limited Edition X100S, when going out and about, while leaving my Silver X100S at home. I've been having a hard time to get the center box to turn green, indicating focus, when half pressing the shutter release. I also have back button focus set up and that works flwalessly. I've been shooting mostly at f2 or f2.8, and I am only using the center focus point with the box set to the largest size. There is a B+W XS-Pro UV filter on the lens and a Fujifilm branded soft release on the shutter button. The soft release is part of the Limited Edition kit. I didn't seem to have this problem when I first got this X100S last week, so I'm wondering if it's a setting I may have changed or something else.
Bill S.
www.flickr.com/photos/wrs1946
“If your pictures aren't good enough, you aren't close enough”
? Robert Cappa ?
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Fujifilm X100S
John Keiffer Regular Member • Posts: 210
Re: Shutter Release Half Press Focus Problem?
Accidentally in manual focus mode on the side of the camera?
John
 John Keiffer's gear list:John Keiffer's gear list
Fujifilm FinePix X100 Nikon Coolpix A Fujifilm X30 Canon EOS 300D Sony a6000
bs1946
OP bs1946 Veteran Member • Posts: 7,778
No, I checked that and it is in AF. I also ran a test in the house focusing on a couple of water bottle labels with both X100Ss set at f2.8. I was about five feet away and my Silver X100S instantly focused with a half press every time; 10 out of 10. My Black X100S instantly focused on 8 out of 10 tries. which is far better than what it was doing earlier today and yesterday. As you can see, my Silver X100S has a third party soft release that is similar to the Fuji one on the Black X100S, although the one of the Silver X100S sits higher because it has a couple of o-rings and the threads are cone shaped to work with Fuji and Leica bodies.
Bill S.
? Robert Cappa ?
McWoodley
McWoodley Contributing Member • Posts: 647
I don’t own that model but maybe try Fuji X Acquire and back up the settings from the one that is working as expected. Then restore to the one that isn’t.  As far as I know that is possible.  If the same model.
 McWoodley's gear list:McWoodley's gear list
Fujifilm X-E1 Fujifilm X-T30 Fujifilm X-T4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +10 more
bs1946
That would be a good idea and they are both identical except for the body color, but the the X100S is too old to use with X-Acquire.
Bill S.
? Robert Cappa ?
