Canon R5 help...weird swirls in images
Started Oct 3, 2021 | Discussions
Pmm85 New Member • Posts: 5
Hi,
I have a Canon R5, and during editing, especially when anything over a +8 bump in shadows or small bump up in exposure is done this weird circles pattern engulfs the image making it unusable. I've exaggerated the edit it in the attached image so you can see the pattern, but this doesn't happen on my 5D IV or 5D III when doing the same thing with the same settings. It's pretty much rendered the R5 useless because it shows up doing very minimal editing using Lightroom or ACR. It shows up at most ISOs, and the images across all ranges seem noisy (no matter of how much light I get on the sensor. Is it a noisy camera compared to the 5D IV, even just raising shadows a little seems to bring up noise the 5D IV doesn't have issues with pulling up in the same settings/setup. I can't reproduce the patterns/swirls doing the same on my 5D bodies.
Can anyone help? Is my R5 faulty?
Any help would be great, I'm totally stuck.
Thanks.
Paul
 Pmm85's gear list:Pmm85's gear list
Canon EOS 5D Mark IV Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM +5 more
dmrimer Junior Member • Posts: 49
Re: Canon R5 help...weird swirls in images
This is not normal.
cduff406 Regular Member • Posts: 115
I might be wrong, but try turning off lens correction.  I think that was what solved it for me.
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
The R5 produces cleaner and less noisy images than the 5DIV.
What you have is something unusual.  Either faulty camera or something in the settings or processing chain.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
draacor
draacor Senior Member • Posts: 1,882
5
I actually get something similar but not with every shot. I think it has something to do with Lightroom. If I use DPP and save as tiff and import into Lightroom the issue goes away.
Aaron Smith
Wolfe Photography
www.nvwolfe.com
https://www.flickr.com/photos/finalimpact/
 draacor's gear list:draacor's gear list
Canon EOS R5 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 100mm F2.8L +1 more
GrunRad
GrunRad Regular Member • Posts: 118
The rings in the sample image look almost like Newton rings ... it could be caused by a defect in the sensor assembly/stack (anti aliasing filter disalignment?).
 GrunRad's gear list:GrunRad's gear list
Canon EOS 5D Canon EOS R5 Canon EF 8-15mm f/4L Fisheye USM Canon EF 40mm f/2.8 STM Canon EF 24-70mm F4L IS USM +9 more
Karl_Guttag Senior Member • Posts: 1,883
Yep, Try Something other than Adobe for RAW conversion
First, the circular ring pattern does not look like something a camera could do.
Second, time and again on this forum, people have found that Adobe's raw converter has serious problems, particularly with low light noise.
Thrid, definitely try DPP4 and get a "baseline reading."
Fourth, give DxO PureRAW or PL4 with DeepPrime a try (free trial and often sale).  It is widely recognized as the best RAW converter for reducing noise while preserving detail.  In my tests, DxO can be good for 2 to 3 stops over Adobe Camera RAW, which is just ridiculous. Adobe is not even trying with their RAW converter.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
Quarkcharmed
Re: Yep, Try Something other than Adobe for RAW conversion
I haven't experienced such problems with the images from my R5 and LR/ACR.
That's a good point.
You don't get additional dynamic range by using a different raw converter. A stronger noise reduction could give you such impression.
John Sheehy Forum Pro • Posts: 26,688
Pmm85 wrote:
Hi,
Looks like either lens distortion correction for the wrong lens, or for the right one, but your camera's readout channels are not even for the two green channels and the distortion correction math is coarse and makes the worst of the readout issue.
RAW files are always best for determining this.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
This type of thing invariably has to do with lens correction, and possibly also uneven blackpoints or gains in the two RAW green channels.
John
CameraCarl Veteran Member • Posts: 9,193
Can you replicate this using Canon DPP?  If not, it is likely in the post processing settings you are using.
I might have thought so too before running my own experiments. There are big differences between various Bayer to RAW conversion processes. DxO with DeepPrime will give BOTH better colors and better resolution a the same time. With Adobe RAW you have to trade color saturation and resolution for noise reduction.
DxO with DeepPrime changed the way I shoot is it so good with the R5. I don't mind pushing ISO if that is what is needed rather than say hoping I don't get subject motion blur by going to a slower shutter speed.
Here is a link to Jan Wegener talking about how much DxO (PureRAW which is the also from DxO and uses similar algorithms) improves noise over Adobe RAW: https://youtu.be/q-gMFMd9D7s?t=607
Here is another comparison: review: https://youtu.be/nn520b1mOas?t=167
From: https://www.dpreview.com/forums/post/65418038
Open to 100% to see the dramatic difference
From: https://www.dpreview.com/forums/post/65405499
Some tests I ran about 7 months ago right after getting DxO PL4 compared to DPP4.
https://www.dpreview.com/forums/post/64948762
My shock was that DxO PL4 with DeepPrime was seeming to violate Nyquist by showing single-pixel detail. I think the reason it can do this and why it is so much better at preserving detail is that is has more "scope" in looking at many pixels and making better inferences as to what is color, what is detail, and what is noise.
See: https://www.dpreview.com/forums/post/64949671
Quarkcharmed
In the R5, ISOs up to 6400-12800 are usable, although for action in shots in low light I usually use ISO 800 as the R5 is basically ISO-invariant from ISO 800.
Overall rendering is better with Adobe - skin tones etc. There's lots of colour noise which is easy to remove in Lightroom, I don't know why it wasn't done in the image in the left.
David Franklin Senior Member • Posts: 1,692
This is clearly some kind of error creating moire, where no competing patterns are visible, that is not something I have ever encountered shooting on my R5 and converting in either Camera Raw in Photoshop or in Lightroom. I can't say what specifically caused the false patterns of the moire effect, but it is clearly not inherent in either the R5 or any "ordinary" Adobe raw conversion.  Perhaps some unusual and extreme combination of things like vignetting control and other erroneous profile corrections have created your issue. Without being able to duplicate the effect, not seen in any of my first approximately 5,000-10,000 R5 images so far converted with Adobe software, I can't give a better answer than that.
Keep learning; share knowledge; think seriously about outcomes; seek wisdom.
 David Franklin's gear list:David Franklin's gear list
Canon EOS R5
OP Pmm85 New Member • Posts: 5
I'd just like to thank everyone for the replies and for the help. Sorry for the time it's taken to respond to this.
It seems this was caused entirely by Adobe Lightroom/ACR, which with lens correction turned on it creates the swirls, but the R5 images seem much noisier in Lightroom or ACR still. Seems to be Adobe software causing the issues.
So, I did some tests in Capture One with the same images and couldn't reproduce it, no matter what lens correction, corrections or edits I did.
I just wanted to say a massive thank you so you all, not only did you guys help fix the problem, but you saved 2 sets of images I'd shot and thought were ruined by the camera and managed to keep my clients happy.
The images when editing are certainly less noisy in Capture One compared to ACR, and certainly no swirls. Looks like I'm moving to Capture One from now on and ditching Adobe (which has been getting clunky for the past couple of years now) I just wish Capture One export was faster on my MacBook Pro.
The R5...I still think is noiser than my 5D IV when it comes to needing to pull detail from shadows in low light, but at least the rings/swirls are sorted out.
Thanks everyone!
expro Senior Member • Posts: 2,273
As you say it is definitely LR. It does it intermittently including adding purple to skies on my 5dsr. I solve it by zooming in and then out again but rather laborious if many images to review!
im guessing that a combination of LR, high mp and potentially older tech may be responsible….
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Quarkcharmed
The R5 is much less noisy than 5DIV, if you shoot in the game conditions and settings. I had 5DIV and can compare.
If your R5's images are noisy, there's something wrong with either the camera, or settings, or workflow.
Check if you have something like highlight tone priority or electronic shutter enabled (don't use electronic shutter at ISOs less than 800).
Thanks everyone!
Quarkcharmed
Lightroom is not ideal but it doesn't have the OP's problem. There's something of going on.
With your issue, try playing with preview generation settings in Lightroom.
NightNight
NightNight New Member • Posts: 21
I can reproduce this on both my R5 and my R6, and have observed it on a rented R. Turning off lens correction in ACR resolves the issue for me. I'm sure you're further along in the diagnostic process than this, but I just wanted to let you know that you certainly aren't alone in having experienced the issue.
... or manner of inspecting. Lots of people don't fully understand the role of pixel size in both the magnification that they inspect at, or the effect it has on the default sharpening in a converter. Converters' "Sharpness" controls operate at the pixel level, which is a different image frequency for different pixel counts, for the same sensor area used. So, converters assume that the user wants pixel-level sharpness, no matter what the pixel size is, making cameras with smaller pixels seem noisier, as an illusion. For larger pixels, the sharpness mainly tries to recap the analog micro-contrast contrast lost to the AA filter, and for much smaller pixels, it is also trying to compensate for diffraction and aberration, too, which attenuate neighbor-pixel contrast more with smaller pixels. If the converter doesn't do this extra sharpening with smaller pixels by default, the user will likely do it.
Electronic shutter is noisier at all ISOs, mainly in the deepest shadows at low ISOs, and reaching into higher tones at high ISOs. The difference is quite visible at ISO 51,200. There's a difference between reading out the sensor in 14 bits and then quantizing to 12 bits, vs reading out in 12 bits to begin with.
HTP isn't too bad in 14 bits, but HTP plus 12 bit e-shutter is a bit worse than just HTP or just e-shutter. The fine horizontal banding noise is worse in 12-bit e-shutter; it disappears readily with downsampling or NR or filtering, but may be a nuisance with high magnification of the original resolution.
John
