Canon EOS M6 Mark II - Exposure button not working?
Started Oct 1, 2021 | Questions
Jaeson
Jaeson New Member • Posts: 7
Is there something odd I did to a setting?
I'm used to my M3 with the fun dial for exposure changes.  So I went ahead and assigned the back dial for it... but it does nothing.  I also noticed when I push on the small +/- button on the same dial it doesn't work.  What setting do I need to change so I can actually have control over the auto metering?  Its really annoying!
I have the camera in "manual" now.  I feel like I must have accidentally changed a setting?  All the other buttons work just fine.  When I go to take a photo its like its auto compensating the exposure (which I don't want it to do- I want to control it myself).
HELP PLEASE
 Jaeson's gear list:Jaeson's gear list
Canon PowerShot S3 IS Canon EOS 50D Canon EOS 5D Mark III Canon EOS M3 Canon EOS M6 II +9 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: Canon EOS M6 Mark II - Exposure button not working?
HELP PLEASE
You say you are in "manual". You mean you have the mode dial set to M on top? So you are setting the exposure and shutter speed manually? What about the ISO? If your ISO is fixed, the exposure compensation dial will have nothing to do. It only works to modify exposure when at least one of the three variables (shutter speed, aperture, ISO) is set to auto.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
sfa1966
sfa1966 Veteran Member • Posts: 3,483
HELP PLEASE
A guess: I think the rear dial can be easily/quickly set to change flash exposure compensation, so maybe that's where you've ended up?
sfa
 sfa1966's gear list:sfa1966's gear list
Sigma DP1 Sigma DP2 Merrill Pentax K-3 Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited +11 more
pocus Regular Member • Posts: 128
Hello,
I followed your steps and assigned "exposure compens." to the back button, but I remembered from my G5X that Exposure compensation does not work in Manual mode. When I switched to Av, Tv, P or Fv mode the Exposure compensation works perfectly.
 pocus's gear list:pocus's gear list
Canon G5 X II Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM Canon EF-M 32mm F1.4
Jaeson
OP Jaeson New Member • Posts: 7
really?  That is kind of sad.  On my M3 I was still able to adjust it.  Very annoying....
Sittatunga Veteran Member • Posts: 5,405
The only way exposure compensation can change anything in M mode is if you are using Auto ISO.  Can you still count automatic exposure by Auto ISO as manual?
