Canon choices within my budget
Started Sep 29, 2021 | Questions
jmschaller New Member • Posts: 2
Am considering “graduating” from my ancient 30D to a full frame mirrorless. I have about $2,500 to spend. The dilemma is body vs. lens. Should I invest in the 24-105 L lens and use the RP body, or purchase the R body and go with the less expensive Canon 24-105 lens? Lots of trade offs to consider, I realize. I do travel shooting, so weight is somewhat a factor, as is not having to carry a bagfull of lenses. I have 3 lenses for my DSLR-C body I can use in a pinch, recognizing I won’t get full sensor coverage for the full frame body.
Jack Schaller
Canon EOS 30D Canon EOS R Canon EOS RP
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
Re: Canon choices within my budget
7
Either one with a 24-240 would be in your budget. 24-240 is an excellent lens.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
ArtHeals
ArtHeals Regular Member • Posts: 267
I'd go for a used EOS R ($1100-1300) and pick some prime lenses (RF 35/1.8, RF 85/2, RF 50/1.8).... No point using APSC lenses with full frame
 ArtHeals's gear list:ArtHeals's gear list
Ricoh GR II Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 85mm F1.8
Andy01 Veteran Member • Posts: 5,188
It may depend on what other lenses you use. The RP is a very compact body (more similar to the better EF-M series bodies) and ergonomically not great with larger/heavier zooms or tele lenses. Many people do it and learn to hold the lens primarily (instead of the camera), but not ideal.
Perhaps the suggested RF 24-240mm might be a decent option. I have never used one, but it would seem that as long as you apply lens corrections, either in-camera JPEG or in Canon's DPP (or similar) if shooting RAW, it can produce good results.
I have 3 lenses
What are they ?
Depends on the lenses. If they are Canon EF-S lenses then the camera will automatically go to crop mode, so you lose resolution (by a factor of 1.6x1.6 = 2.56 times) which may be more of an issue than the narrower FoV (ie. a 24mm lens produces a FF equivalent FoV of around 38mm) because the RP becomes a 10Mp camera.
I think that some third party APS-C lenses can be used without the automatic crop function applied but there can be severe vignetting.
If they are EF mount lenses then you shouldn't lose anything.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Jack Calypso Senior Member • Posts: 1,094
I just got the 24-240mm f/4-6.3 for my RP after 18 months of adapted lenses. It's about the same weight and dimensions as the 24-105 f/4 L but a lot more reach, and so far I'm very impressed with it.
Refurbished on sale from Canon USA for  US$719 through October 3.
JPAlbert Senior Member • Posts: 1,296
OP:
If you're in the USA, you can pick up a Canon-refurbished EOS R for about $1,620, which should leave enough for either the 24-105L or the 24-240.
Same 1-year warranty as new, probably indistinguishable from a new one (except for the packaging).
I believe you can request the "customer loyalty" discount (you'll need to give the serial number of the 30d) for an extra discount...
Hmmm...
You might even consider aiming for a refurbished R6 (again with the cs discount)...
quiquae Senior Member • Posts: 2,265
When you say "DSLR-C," you mean EF-S lenses for your 30D? They work in the sense that EOS R/RP will let you shoot photos with them, but between the mediocre quality of the lenses themselves and the 1.6x crop factor, the resulting image quality will be such that you won't feel like you're getting your money's worth out of your new camera.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
jayk0607 Regular Member • Posts: 172
Depends on what's on your thoughts as far as your upgrade path is concerned, but for me, lens is more important than the body. I'd go with RP and the 24-105L and buy one L glasses at a time. And when you have enough money later, you can upgrade the body. IMHO, this is a better upgrade path, since you will have collection of L glasses, should you decide to upgrade the body. Maybe wait until around Thanksgiving time to see what Canon offers. Just remember that Canon's 'Holiday/Black Friday' sale comes at an odd timing.
 jayk0607's gear list:jayk0607's gear list
Olympus PEN E-P2 Canon EOS M50 Canon EOS RP Canon EOS R6 Mark II Canon EF 100mm F2.8L Macro IS USM +13 more
Eddie Rizk Senior Member • Posts: 1,224
In that budget, I'd get an RP with an RF 24-240 for the daytime and an RF 35 F1.8 for the night.  At full retail, that's a little over your budget, but if any of it is used, refurbished, or on sale, you come in at or under budget.
If you want a more powerful body in the future, the RP is the one you will want to keep as a second camera, over the R, because of its size and weight.  It's a perfect travel rig with those two lenses.  Later, you can add the RF 16 F2.8, if you want an architectural lens, the RF 85 F2, if you want a portrait lens, and/or the RF 600 or 800 F11 or the RF 100-400, if you want a wildlife lens.
The less expensive RF lens catalogue is really good.  The 35 and the 85 both have 0.5-1 macro focusing, which is perfect for florals and food.  You really only need 1-1 for bugs, then you really need 2-1.
That's my opinion, and it's worth what you paid for it.
Eddie Rizk
The race is not always to the swift nor the battle to the strong, but that's the way to bet.
Formerly "Ed Rizk"
My email was hacked and unrecoverable along with all associated accounts, so I got permission to create a new one.
 Eddie Rizk's gear list:Eddie Rizk's gear list
Canon EOS R Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +3 more
davev8
davev8 Veteran Member • Posts: 4,833
Welcome to the forum
well its a bit tricky choosing between the R and RP as both are a long way behind canon latest FF MILC and probably the R will be a long way behind any RP replacement
TBF i don't see any massive stand out feature for you to go with the R..they are both slow when it comes to FPS ..with AF tracking 5FPS for the R and 4FPS for the RP ..here you won't see an upgrade over your 30D
the R has a better EVF..may or may not be important to you
the R has better battery life than the RP ..both suck compared to your 30D so factor in a couple of batteries in your cost
the R has a sensor with a fair bit more dynamic range but the RP still has 1 stop of DR more than your 30D,,so if lack of DR was not a problem for you then it won't be with the RP.
their are other advantages with the R that may are may not be important like 1/4000 shutter speed vs 1/8000
the RP has very slightly better high ISO but probably not notice it in the real world
the RP is smaller and even more so with the STM kit lens so maybe a big plus for travel
Cost
looking at amazon USA (i am in the UK i see you can get a RP with the STM kit lens for $1300 an R with the STM lens is $2100......i just don't see the R any way whats so ever a $800 better camera when the RP replacement will most probably out speck it big time in a year or 2 for a lot less$$$ so its a no brainer for me unless you really really need another 1.5 stops of DR better EVF and battery life
24-104 F4L VS the 24-105 STM kit
well optically and IS and AF there is not much to choose between them watch this vid https://www.youtube.com/watch?v=ySzMkQ0Sjik&ab_channel=GordonLaing
now the elephant in the room is the F7.1 bit
now lets put that into perspective 1st the STM lens is F4 at the wide end anyway and in the great scheme of things F4 is not that fast ..i guess you have a 18-55 kit lens on your 30D well the FF equivalent of your APS-c lens at 55mm, the RF kit lens has a 1 ish stop advantage with shallow DOF and 1 stop total light gathering on the FF sensor ..with the 24-105 stm when the focal length is set to the equiv to your 55mm APS-c its is at F6.3 so not as slow as you 1st think compared to APS-c kit lenses
Now the RP has a whopping 2 stops ISO advantage over the 30D so your low light capability is still upgraded almost 3 stops
as the RP and kit lens is $1200 below your budget it means you can supplement the kit lens with a fast prime or 2 ...or more..and still have a compact setup but way more versatile than the 24-105F4L alone giving you UWA, F1.8 and macro...for the way i would shoot RP+kit lens $1300 the new 16mm F2,8 $300 the 50mmF1.8 stm $200 and the RF 80mm is macro $600 total $2400 or the RF24-240 can be in the mix...or alone
look forwards to giving advice in 2036 with RP mk6 VS R mk6
Attention Dislexsic i mean dyslexic person... This post will have many although spell checked, spelling and grammatical errs ..its The best its going get so no need to tell me it is bad I know it is .....................................................................................................
the EOS M is not dead and wont be for a long time ....as long as you don't want a flagship camera with a VF...if that's the case it died sometime ago
My 5D IS a MK1 classic
There is no argument for FF vs APS-c (or m43) with shallow DOF..as it's a law of physics and a very subjective personal thing if you want to make use of the shallow DOF only FF can offer
If you wait for a camera that will tick all your boxes ....by then you will have more boxes to tick..... so the wait continues .....David Appleton
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
Marximus
Marximus Regular Member • Posts: 474
I'd also recommend the RP or a used R with the 24-240. With the little finger extension, the RP is the most comfortable camera I've ever held, and the 24-240 is a very competent lens on the lower megapixel bodies (I love it on my R6).
 Marximus's gear list:Marximus's gear list
Canon EOS R5 Canon EOS R6 Canon EF-S 60mm f/2.8 Macro USM Canon Extender EF 1.4x III Canon Extender EF 2x III +10 more
If you can extend your budget by $100, Canon is selling refurbished R + 24-105mm f/4 L kits for US$2610.
spec68 Contributing Member • Posts: 530
Lenses age slower than bodies so that's where I'd put my 1st money. Go with RP and lens of your choice - 24-105 f/4, 24-240, or 70-200 f/4 are good starters. I have the 24-240 as a "travel" lens when I don't feel like hauling around a bunch of lenses or it's not practical. Decent lens for its range, though it has it's quirks for sure.
OP jmschaller New Member • Posts: 2
Your comments are very helpful and much appreciated. I have been leaning toward the RP, I agree that it is hard to see where the R is $800 better than the RP.
Jack Schaller
davidwien Contributing Member • Posts: 572
I agree. Those are the lenses I use most with my RP and I am very happy with the results.
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
