CANON EOS D60
Rdesilva New Member • Posts: 1
CANON EOS D60
I wonder if someone could post an image of the download cable for a D60 showing the shape of end that fits the camera receptacle. I need to buy the correct cable. Thx.
KEG
KEG Veteran Member • Posts: 3,604
Re: CANON EOS D60
I would try the 10D...90D forum.
Do you mean 60D or the ancient D60 from 2001?
if it is 60D then I would guess either USB mini or micro USB, the latter being more likely.
for D60, I wouldn't count on it even being USB.
And as s general catch it all answer:
just buy a high quality card reader.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS RP Olympus M.Zuiko Digital 17mm F1.8 Canon EF-M 32mm F1.4 +17 more
KEG
Re: CANON EOS D60
the cable looks like a custom job, I think the same one was used for powershot G2.
KEG
KEG
Max@Home
Max@Home Veteran Member • Posts: 3,747
Re: CANON EOS D60
Check the review on DPReview, page 6:
https://www.dpreview.com/reviews/canoneosd60/6
You'l need
The contents of the retail box (full kit) are:
  • USB cable (IFC-200 PCU)
  • Video cable (VC-100)
...€0.02...
kindest regards!
Max@Home
Max@Home - Castricum - The Netherlands (see profile for equipment)
www.pbase.com/max_at_home (mind you, use underscores!)
 Max@Home's gear list:Max@Home's gear list
Canon PowerShot G3 Canon PowerShot Pro1 Canon G1 X II Canon G3 X Canon EOS 20D +11 more
Mark B.
Mark B. Forum Pro • Posts: 28,425
Re: CANON EOS D60
Forget about the cable.   Just get a card reader instead.  It will most likely be cheaper than what is certainly an outdated, and therefore hard to find cable.  It will also be faster than downloading from the camera.
Kameratrollet Contributing Member • Posts: 637
Re: CANON EOS D60
Bought the cable only for the reason to remove the previous owner's name. Had to use Gphoto2.
rambling robin
rambling robin Contributing Member • Posts: 578
Re: CANON EOS D60
Please could you explain how you used Gphoto2 to update the previous user's name on the D60?
Thank you.
 rambling robin's gear list:rambling robin's gear list
Fujifilm FinePix S2 Pro Fujifilm FinePix S3 Pro Nikon D70 Nikon D70s Nikon D80
Re: CANON EOS D60
Thank you.
Linux user?
https://kameratrollet-se.translate.goog/2019/03/09/byt-upphovsmansnamn-i-din-canon/?_x_tr_sl=sv&_x_tr_tl=en&_x_tr_hl=sv&_x_tr_pto=nui
rambling robin
Re: CANON EOS D60
Thank you.
Linux user?
Yes.
Neat!!!
