GR Accepts Filters?
Dale108
Dale108 Veteran Member • Posts: 9,431
GR Accepts Filters?
Does the GRiii accept filters like polarizers on the lens?
Dale
 Dale108's gear list:Dale108's gear list
Panasonic Lumix DMC-FZ300 Olympus TG-5 Sony RX10 IV Pentax K-1 Panasonic Lumix DC-G9
Ricoh GR III
fotopan Junior Member • Posts: 39
Re: GR Accepts Filters?
Yes, if you use GA-1 adapter. It has 49mm filter thread.
 fotopan's gear list:fotopan's gear list
Ricoh GR II Ricoh GR III Pentax K-1 II HD Pentax-FA 31mm F1.8 Limited HD Pentax-FA 43mm F1.9 Limited +1 more
altis Senior Member • Posts: 1,073
However, it does make the camera substantially thicker:
https://www.dpreview.com/forums/post/63577891
Dale108
OP Dale108 Veteran Member • Posts: 9,431
Thanks.
Dale
ViMa
ViMa Senior Member • Posts: 1,842
Dale
Hi, I had an adhesive magnet ring on my lens to which a slim filter holder would be attached. I used this with two ND filters for a combined 16 stop (+ what the Ricoh has). The brand I believe is themagfilter. I was quite pleased with that and found it way better than using the bulky adaptor.
Vittorio
_________________________________________________
https://www.flickr.com/photos/155724624@N06/
 ViMa's gear list:ViMa's gear list
Ricoh GR III Ricoh GR IIIx
But be wary if you ever have to remove the adhesive ring:
https://www.dpreview.com/forums/thread/4598725
rondom Veteran Member • Posts: 3,434
Dale
Nisi makes one too. Not as bulky as the original (which is primarily designed to attach the heavy converter lens), and also cheaper. I would prefer this over the self adhesive solutions.
https://www.dpreview.com/forums/post/65471140
https://www.bhphotovideo.com/c/product/1560217-REG/nisi_nisi_rgr3_ad_49_49mm_filter_adapter_for.html
Strangefinder
Strangefinder Senior Member • Posts: 1,187
NiSi also has a filter kit for GR or Fuji which includes a brace, polariser and some other filters.
“If you're not careful, the newspapers will have you hating the people who are being oppressed, and loving the people who are doing the oppressing.” Malcolm X
"If lies can begin wars then the truth can end them." Jx/xxn Xssxngx
“Remember that all through history, there have been tyrants and murderers, and for a time, they seem invincible. But in the end, they always fall. Always.” Gandhi
ViMa
Mine was very firmly shut on the front lens but I easily removed it without even using floss or anything. It's just about taking your time with it rather than pulling from one end.
I used my finger to unstick the edges all around slowly, before trying to remove it.
Btw I removed it only because I'm selling the GR III in favour of the IIIx.
Vittorio
