HD DA AF 1.4X AW Rear Converter & Manual Focus Lenses
GCL Regular Member • Posts: 230
Will the newer HD DA AF 1.4X AW Rear Converter work (without AF, of course) with older manual focus K mount lenses, such as the M* 300mm f4 lens? And if so, does it provide better results than the rear converter-A 1.4x-s?
I am using the M* 300mm f4 adapted to mirrorless and want to try a teleconverter - wondering if the newer AF version would work and if it is better than the older rear converter-A 1.4x-s.
 GCL's gear list:GCL's gear list
Ricoh GR III Nikon Z7 Voigtlander 40mm F2 Ultron SL II Venus Laowa 100mm F2.8 Macro Nikon Z 24-70mm F4 +27 more
Adam007 Contributing Member • Posts: 700
Re: HD DA AF 1.4X AW Rear Converter & Manual Focus Lenses
The newer converter works fine with manual lenses.  I don't know about other converters, but doubt this would change.
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +5 more
