X100V Lensmate Thumbrest ... issues?
Started Sep 22, 2021 | Discussions
xb70fan Senior Member • Posts: 1,234
I’m noticing this thumbrest (LM X100V) tends to loosen up quite a bit. I haven’t had it actually come out, but I do have to seat it more often than I’d like. It will leave a roughly 2mm gap after little use. When I flip it open, the whole unit will rotate. I have to wonder what that play (albeit small) may be doing to the hotshoe. The articulation solves one issue, but seems to be causing another.
I put on my LM X-E3 as a test, and it stays seated. The shutter speed/ISO dial is hard to get at, but it’s my least used dial, anyway (have it set mostly to auto). The LM X-E3 also has a better fit into the hotshoe on the X100V.
Has anyone else noticed this with their LM X100V?
On the same topic, has Match Technical closed shop? I see B&H is still selling items ...
https://www.bhphotovideo.com/c/product/1596629-REG/match_technical_tu_ep_2v_s_ep_2v_thumb_grip_for.html/reviews
However, the actual Match site looks dead ...
https://www.matchtechnical.com
I owned a Match Technical Thumbs Up for my X-Pro 1 and loved it.
Mississauga, Ontario, Canada
 xb70fan's gear list:xb70fan's gear list
Fujifilm X100V Ricoh GR IIIx Fujifilm X-E3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II
PhilT_UK Regular Member • Posts: 184
Re: X100V Lensmate Thumbrest ... issues?
Yep, same issue for me. I’m constantly pushing it back in. It fell out once and I thought I’d lost it. Found it at the bottom of my backpack luckily. For the price I’d expect better and it’s put me off ordering one in the future…
I’ve got the official Fujifilm thumb rest for my X-E4 and that’s rock solid.
 PhilT_UK's gear list:PhilT_UK's gear list
Fujifilm XF 23mm F2 R WR Ricoh GR III Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
OP xb70fan Senior Member • Posts: 1,234
I emailed Lensmate about it. Received the reply a few hours ago …
As you have experienced with your other Lensmate thumb grip (X-E3), the hot shoe rubber insert normally provides enough friction to prevent any movement. The movement in your X100V is likely due to an extremely slight variance in your X100V hot shoe rails. Out of the hundreds of these grips that we have shipped, we have only had three other customers experience looseness in the fit.
Fortunately, our designer came up with a super quick and easy fix that worked perfectly for the customers that I mentioned.
The hotshoe silicon insert is fairly easy to remove and re-install. (just using your fingernail) To provide slightly more friction he suggests that you place a paper shim underneath the hot shoe insert. Simply cut out a shape slightly smaller than the hot shoe insert from a thick piece of paper and re-install the silicon insert. Be sure to position the rubber wave pattern so it will point towards the camera. That should completely solve your issue. Let us know how it works out.
I’ll try what they suggest, but, eek. IMO it’s not the rubber insert, but the movement in the articulation that’s “levering” it out of place.
Looking further, I saw a few other reports of this on Amazon.
60400 New Member • Posts: 1
I bought the Lensmate thumb grip from Europe and paid a hefty price with custom fees and all. After seeing so many reviews, I thought it'd be a no brainer but I'm quite disappointed with it too.
IMO it's not that the hot shoe mount isn't tight enough to keep it in place, but that the thumbrest is designed in a way that the padded point of contact resting on the camera acts as a leverage depending on how you rest your finger and it slowly slides out of place.
It's not gonna fall off, but I find myself constantly having to put it back in place because it comes off just 1 or 2mm.
For this reason, I've stopped using it.
I have the X-E4 with the original thumb rest, and in comparison, that one would be impossible to get out no matter where you rest your thumb on.
RangerPhotog Regular Member • Posts: 303
The Fuji thumbrest for the XE4 I received came with multiple pads.  You could use the spare with the lensmate thumbrest to tighten things up.  The lensmate thumbrests I use on my XPro3 and X100f have worked just fine for me.
 RangerPhotog's gear list:RangerPhotog's gear list
Nikon Coolpix A Fujifilm X100F Fujifilm X-Pro3 Fujifilm X-E4 XF 90mm +9 more
sshapiro Senior Member • Posts: 1,018
The lensmate on my X100V does the same thing. I used a small piece of adhesive velcro, soft side, to address the problem. I put it to the front of the rubber pad on the bottom of the thumbrest and now the thumbrest stays in place. The velcro added just enough pressure to keep the thumbrest secure ,and the soft material does not create problems for the hot shoe.
DarnGoodPhotos Forum Pro • Posts: 11,881
I've always been a fan of LM thumb-rests on my X-Pros, but to be frank since getting a leather case with this small ridge I find my X100V doesn't need one.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
JConrad Regular Member • Posts: 318
Thanks for posting this.  I too have had my Lensmate thumb grip feel a bit loose, and I've had to push it back in pretty much every time I use the camera for even a few minutes.  I just put a small cutout of a business card under the rubber (I had no idea until seeing this post that it was removable), and now it fits very snugly, and it does not wobble out at all now.  There is still a very, very small amount of lateral movement, but the grip stays firmly in position, and doesn't back out at all now, even when operating the hinge.
 JConrad's gear list:JConrad's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM Fujifilm X100V Canon EOS RP +9 more
kwa_photo
kwa_photo Veteran Member • Posts: 3,649
Hmm...never had this issue...I don't recall when I actually bought my V, it has to be at least 2 years ago and I added the grip right after.  The Lensmate response may be correct, OR it may be a variation in their rubber too.
Ken
FujiFilm FinePix Moderator (Please PM vs. a public post if you have concerns or questions about the forum)
 kwa_photo's gear list:kwa_photo's gear list
Fujifilm X100V Fujifilm X-T3 Panasonic Lumix DC-S5 Fujifilm XF 50-140mm F2.8 Fujifilm XF 16-80mm F4 +3 more
