Moon again
LillyLo Junior Member • Posts: 26
Moon again
Hello, here I am back to the fullmoon subject. Theory says to get the moon surface you need a high speed and a low ISO. Well if I have that with manual setting,  it's impossible to catch even lightly the objects (ie buildings, tree branches etc) of the foreground. A detailed moon is possible only alone, for what I understand. What am I doing wrong?
petrochemist Veteran Member • Posts: 3,186
Re: Moon again
Nothing, the moon is very bright compared to most night scenes, To stand any chance of capturing foreground detail you need to add quite a bit of light, or merge multiple shots at different exposures.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +17 more
Quarkcharmed
Quarkcharmed Senior Member • Posts: 1,659
Re: Moon again
The full clear moon at night creates a very high contrast scene; it's not the sun but still very bright compared to the foreground objects.
Getting exposure right in such conditions is tricky, I'd suggest to expose by histogram so that the moon is almost blown out (but not yet). Then you'll see, by the shadows in the histogram, if the foreground is recoverable. If not, you may resort to HDR/exposure blending.
(The above implies you shoot raw.)
The moon is easier to work with when it's behind some light clouds and/or sits low at the horizon.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM
Mika Y.
Mika Y. Senior Member • Posts: 1,827
Re: Moon again
If you want to capture the moon and other scenery together in single photo, your best bet is to take the photo when there's still some residual light from the sun, i.e. shortly after the sunset or before the sunrise. That may be sufficient to reduce the contrast between foreground objects and the moon into a manageable range. In time of full moon, the moon will also be fairly low on the sky, which probably will make compositing it with foreground scenery easier.
Even if the foreground still looks too dark, you may be able to lift the shadows in post-processing to achieve the desired result, especially if the image has been show as raw.
The other option is to take multiple exposures, one correctly exposed for the moon and one or more for the foreground scenery and combine them together in post-processing.
 Mika Y.'s gear list:Mika Y.'s gear list
Canon EOS 5D Mark III Canon EOS Rebel T4i Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +13 more
Klaus dk
Klaus dk Veteran Member • Posts: 8,104
Re: Moon again
Apart from the difference in lightness, which to some extent can be helped by choosing the time for the shot just before sunrise or just after sunset, the foreground needs to be within the depth of field.
One usually wants to use a telephoto lens to shoot the moon, and they have shallow DoF, so the get the foreground sharp, it can't be too close to your shooting position. The moon is (for optical purposes) at infinity, so the forground needs to be within or close to your DoF.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 135mm F2.8 SF Canon EF 100mm f/2.8 Macro USM +14 more
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 17,897
Re: Moon again
Take a look at this again:
https://www.dpreview.com/forums/post/65428573
There both needs to be enough light from the sky to illumine the foreground, and the moon has to be low enough on the horizon to be substantially dimmed by the atmosphere.
This takes planning, knowing the needed date and time to get a good photo. Your next full moon opportunity will be October 19th at moonrise and October 20th at moonset.
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 28mm f/2.8D +4 more
Mark Scott Abeln
Re: Moon again
Can you share some of your disappointing photos for us to look at?
OP LillyLo Junior Member • Posts: 26
Re: Moon again
Thank you for your answer. You say that the foreground needs to be within the DoF. Well I wonder how it can;t be. Sorry for my ignorance, but when shooting to infinity -moon- DoF is large, right?
Re: Moon again
DOF gets longer at greater distances, shorter focal lengths & smaller apertures.
Even with focus at the hyperfocal point (which gives maximum DOF, more than focus at infinity) longer lenses will not have the DOF extend as far as many would want, especially if the aperture is wide to get in as much light as practical. I know I have lenses that when focused to infinity will show severe blur on items hundreds of metres away.
DOF is not so bad with wide angles but the moon is left looking tiny and even with these it's quite easy to get a blurred foreground.
Klaus dk
Re: Moon again
I just checked a DoF calculator. You should download one to your phone, it's a very useful tool, and you can learn a lot by playing around with it.
On a full frame camera, with a 300mm lens at f/5.6 set to infinity, the DoF near limit is 530m, which is also the hyperfocal distance. With the lens set to 530m, your near limit is 265m and the far limit is infinite.
So yes, the DoF is large, but the tree across the street isn't in it, not even at f/16.
Good luck and good light.
