Do You Find Yourself Adding Extras and Additions To Your Fuji Camera?
Started Sep 20, 2021 | Polls
bs1946
bs1946 Veteran Member • Posts: 7,778
Beyond adding one or more lenses to your new or used but new to you Fuji camera, do you feel the need to add all sorts of extras and additions to make it truly your own?
In a recent late night eBay GAS attack, I bought a Silver Fujifilm X100S. The silver top and bottom plates showed definite signs of wear, but the rest of the cameras was in excellent condition. Most importantly, the lens and all the glass was squeaky clean, everything worked, the shutter count was relatively low, and the asking price was reasonable. The X100S came in the original box, with all of the user documentation, the OEM camera strap, the OEM charger and power cord, 3 OEM NP-95 batteries, a silver Fuji filter adapter with a B+W 49mm UV filter that the seller said he put on the lens the day he got the X100S, an LCD screen protector, and a Leica Kit camera strap. The only thing missing was the silver X100 lens cap.
Of course there is always room for improvement with a couple of additions and upgrades.
  • I have lots of SD cards, so I formatted in camera, two SanDisk Extreme Pro 32GB Type 1 SDHC cards for the X100S.
  • Then I replaced the Leica Kit strap that was on the X100S with my Barton 1972 Original Style Dark Sea Blue leather strap. That I bought for my old Leica M9.
  • Next I added a silver and black JJC soft release that almost matches the design of the X100S dials.
  • Then I added an Oben APG-X100 Arca-Swiss compatible baseplate with an L-bracket and external grip. I removed the L-bracket but have kept the external grip on for now. If the grip proves uncomfortable or annoying, it can also be quickly removed. The base plate matches the quick release Arca-Swiss mounts on my tripod and monopod heads.
  • Last for now, I decided to replace the included paper thin, cellophane like, LCD screen protector because of dirt marks that would not clean off. I replaced it with a Giottos Aegis SP-8306 Schott Glass scree protector. The SP-8306 is the right size for the X100 or X100S and is simple to apply. The Giottos Aegis Schott Glass screen protectors are very similar to the special Blue Sapphire LCD glass that Leica used in several of its P version M cameras to protect the LCD from scratches and similar damage. My used Leica M8 and M9 both had Giottos Aegis LCD screen protectors installed by the original owners and I have used then on almost all of the Fuji bodies I have owned.
Not really anything to add except maybe that missing silver OEM lens cap and perhaps a silver WCL-X100 wide angle adapter…
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
POLL
Absolutely, I get everything I can find to add to that Fuji camera.
27.3% 9  votes
Maybe one or two spare batteries, but that's it.
63.6% 21  votes
No me, if it didn't come in the box, I don't need it.
9.1% 3  votes
  Show results
Fujifilm FinePix X100 Fujifilm X100S
eric333 Senior Member • Posts: 1,434
Re: Do You Find Yourself Adding Extras and Additions To Your Fuji Camera?
The X-T4…straight out of the box as is.
With other Fujifilm cameras, I’ve added thumb grips, hand grips and third party straps.  I didn’t think the X-T4 needed any of this stuff.  Even the included strap is excellent.
I did buy 2 extra batteries and the charger.
bastibe
bastibe Senior Member • Posts: 1,236
Some people seem to treat their camera as a fashion accessory. That's cool, more power to them.
But it's not me. I treat my cameras as tools. A tool for taking pictures. In fact, even if they get banged up, but I end up with more pictures, that's fine with me. I take them on bike rides, hikes, kayak tours, on a strap, out in the open. Even in rain or snow (within reason). This has given me some of my favorite pictures. My most used lens has seen stuff, and it has scars to show for it. It kind of adds to the charm.
Things I add: a bit of tape over the focus assist light, to prevent it from blinking when I use the timer to take pictures, which produces glare when scanning film. Sturdy strap lugs. A third party strap. On occasion, a CPL filter or a macro filter.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
Snapsh0t
Snapsh0t Senior Member • Posts: 2,988
I have a standard setup for any camera I own: glass screen protector (GGS or similar), soft release if there's a thread for it, Arca/Swiss-compatible base plate with hand grip if appropriate to that camera and with L bracket if available. I also add a quick-release from OP/TECH so I can switch between a Cordweaver wrist strap or an OP/TECH Utility sling. Depending on the camera design I may add a deeper eye cup.
So this is not Fujifilm-specific and I can't answer your poll as it needs an entry between 1 and 2 that's something like "I add a selected number of add-ons".
 Snapsh0t's gear list:Snapsh0t's gear list
Panasonic Lumix DC-GX9 Olympus E-M5 III Panasonic 12-60mm F3.5-5.6 OIS Olympus 12-100mm F4.0 Olympus M.Zuiko Digital ED 8-25mm F4 Pro
nonicks Senior Member • Posts: 1,188
For my Xpro-3's, I don't need to add anything except screen protector films, spare batteries and (sailor style) hand strap. Mounted with one of the primes, that is a perfect setup for me already.
I do have PD slid lite but I rarely use it. I may end up selling it.
I also have OEM metal grip in case I want to use longer lens in trips but it just sits in the closet without being used at all. So this may need to go too.
 nonicks's gear list:nonicks's gear list
Leica Q2 Leica M10-R Leica Summicron-M 35mm f/2 ASPH Leica Summilux-M 50mm f/1.4 ASPH
jhorse Veteran Member • Posts: 5,913
Ah, when I reveal my list you might put me in that category!
Yes, I do add accessories to the body, currently XT4 and XE4 (both black). These include:
  • Quality leather half case to improve handling and protection. I also have a Swiss Arca non-battery grip for my XT4 for when I use a tripod or a 100-400 lens.
  • A convex, ebony wood shutter release.
  • Screen protector.
  • Peak Design Slide Light on the XT4 and a Leash on the XE4 (with sturdy, fishing quality, 60lbs rated, stainless steel o-rings instead of the weaker Fuji supplied triangles).
  • And of course a spare battery and sufficient SD cards.
Yes, my cameras too are tools, which I take travelling, hiking and to family, sports (skiing, sailing, etc) and nature events. They have been used in rain and snow, for example on our last Alps skiing and hiking trips in March and August 2019 (then XT3/XE3) and last month (Aug 21) in the English Lake District.
As you say, each to our own.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
mkmorgan Forum Member • Posts: 79
As far as tricking out the camera itself, not too much. The one thing I did to the camera itself was add a really nice strap that I was using with my previous camera.
As for the rest of my gear I have a nice bag, a good collection of lenses, filter kit, cleaning kit, etc., but those are just tools, not personalization. The one thing I did add was a very bright, flashing LED bicycle taillight to my bag so I am clearly visible when I am out at night. It's about the size of a pecan and isn't noticeable until it's turned on, and then it can be seen for a good distance even in daylight.
Laziness. Impatience. Hubris.
 mkmorgan's gear list:mkmorgan's gear list
Fujifilm X-T3 Fujifilm 16-55mm F2.8R LM WR Samsung NX300 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +7 more
Fuji Maine Senior Member • Posts: 1,702
Does this count?
Morris0
Morris0 Forum Pro • Posts: 32,181
Besides the usual things like batteries and strap, I found these essential for the X-T3:
- Soft release. Useless without one in cold weather
- EC-XH W Wide Eyecup: Essential for outdoor use with glasses.
- Flash: The included one is a joke.  I'd rather have a USB cable
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Doug MacMillan Veteran Member • Posts: 3,695
How about this?
X-H1, SmallRig cage and rails, Canon 70-200 f2.8, matte box, Majestic tripod.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
Dennis Forum Pro • Posts: 21,319
I dipped my toe in Fuji waters nearly two months ago now with a used X-T30 that came with a soft shutter release and an LCD protector. The store had an aftermarket L bracket/grip combo that I bought, tried, and then removed, figuring I'd use it as needed, but not all the time.
Then I ended up returning the X-T30 and getting an X-S10. I feel no need to get an LCD protector because I can keep the LCD reversed in a bag (I don't use one on my DSLR, either). So the only accessory I got for it was a wrist strap (tried one from Gordy's and I like it - my favorite wrist strap is the Joby DSLR strap that's no longer available). But I use wrist straps on all my cameras, so it's nothing unique to Fui. I think the X-S10 just isn't the type of camera that begs to be accessorized.
p.s. I used to enjoy carrying small film cameras with those leather "everready" cases, but have never seen one that looks as useful/handy for a digital camera. I'd be tempted if I ever saw one that was functionally and aesthetically as I remember them.
- Dennis
Gallery at http://kingofthebeasts.smugmug.com
MarcosV Veteran Member • Posts: 6,522
A silver X100S was my first Fujifilm and served as the gateway drug into Fuji-X.
At one time or another, I bought everything for it.
What I ended up using long term:
  1. 3rd party finger grip like what you picked up.  Great when handling the camera one-handed or when I want to quickly attach a small tripod
  2. Hot shoe thumb grip - For extra stability; especially when I don't use the finger grip due to weight
  3. Low profile lens hood
  4. Peak Design neck and wrist strap.  I love being able to instantly swap between a neckstrap and wrist strap
When I want to go as pocketable and light as possible, I'll get rid of the finger grip, humb grip, and hood.
Stuff that sounded good; but, didn't work out include:
  1. Fujifilm EF-X20 flash --- Love the size and the dial for FC; but, it was only good for fill flash
  2. Shutter soft release buttons --- keep losing them.  Didn't want to use o-rings to keep them in place.  Found the thumb grip worked better for stability/
  3. Converter lenses --- way too bulky to carry around
 MarcosV's gear list:MarcosV's gear list
Sony RX100 IV Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR XF 90mm +28 more
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
I have wasted so much money on add on accessories for my Fuji cameras, mainly to try to make them more comfortable to hold or operate. The only bodies I haven't needed to add some kind of grip accessories have been my XT1 & XT2 (and previously owned XE2). I added a leather half case to my XE3, an MHG to my XT30 and all kinds of failed attempts to my X100's I've owned (don't get me started on X100 series accessories). I have a shoe box full of straps but only a few are actually an improvement on the OEM strap, another shoebox full of filters of almost every diameter, a large luggage crammed full of various camera bags, plus a few laying around the house. And most of this mind you was not to improve the looks of the cameras, but to make them more functional.
So I guess most of my wasted money on camera accessories has been for functionality reasons, not so much for appearance. They (Fujifilm cameras) already look pretty cool on their own so I don't feel much need to dress 'em up.
-Rob
Edit: I suppose I fall somewhere between the 1st and 2nd category.
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +7 more
larsbc Forum Pro • Posts: 18,282
No, I've only added stuff to my X100V that I thought was necessary:
  • Nissi combo hood/protective filter.
  • Short loops of paracord on each strap ring so I can easily attach camera to a wrist strap or neck strap, or wrap around my middle finger when not using any strap at all.
Due to the close position of the battery door to the tripod thread, I might end up buying a grip + base plate solely to move the tripod thread over so I can put a Capture Clip on the camera while still having access to the battery door.  I'm loathe to do this, though, because I want to keep the camera's weight/size as minimal as possible.
bs1946
OP bs1946 Veteran Member • Posts: 7,778
My first Fuji was a short lived X-A1, followed by an X-E1. Also have had an X-E2, X-T2, X-Pro1, and X-Pro2 plus my X100s starting with two X100Ts, an X100D, an original X100, and now the X100S.
I would like to think that all of the extras I buy add value for me to use the camera or to protect my investment.
I bought the Oben grip, base and L-bracket for the Arca-Swiss compatible dovetail base. I have three tripod/monopod heads and all three have Arca-Swiss mounts. I Have not found the front grip to be that comfortable and will probably remove it. I have a similar set-up on my Panasonic GX9 from JJC. I could remove the front grip and just keep the base, but that grip just seems to fit my hand just right.
  1. Hot shoe thumb grip - For extra stability; especially when I don't use the finger grip due to weight
I have never liked the thumb grips that attach to the hot shoe. Either the grip and my finger is too short and I can't comfortably reach it or the grip and my finger is too long. Plus a lot of the ones I've tried block the top deck controls. The only thumb grip that I ever liked was one made by a small vendor in England that was designed to stick on the end of my M8 and M9 it matched the body curve exactly, and stayed on with removable adhesive tape.
  1. Low profile lens hood
I have never taken to using lens hoods. Can't exactly say why but I just don't like them and I've never had a problem not using them. If a hood comes with a lens I bought, I verify it fits properly and put it back in the box. Especially with the X100 series, most hoods block part of the OVF.
Without starting a whole debate, by personal choice I put a UV filter on every lens I have. Having paid the price before I started doing that, I considered the filter cheap insurance. With the X100 series, this of course requires that optional filter/hood adapter which in my opinion, Fuji should have put in the box with the camera.
  1. Peak Design neck and wrist strap. I love being able to instantly swap between a neckstrap and wrist strap
When Peak Design straps were the must have strap for everyone, I let the salesman talk me into getting a PD Leash for the brand new XT-2 I was buying. The Leash was too small for the X-T2, so I made the fatal mistake of upgrading to PD Slide Light. Like any other strap I ever used, I left the Slide Light on the camera when it went into my bag. Then one day, I took out the X-T2 and my pristine LCD had a huge almost gash like scratch across most of it. The only thing that could have done that in the bag was one of those metal adjusters on the Slide Light. Later just by chance, I came across a DPReview of the PD straps and it warned of that very possibility.
I rarely use flash, which might be a mistake, but after buying flashes to go with different cameras over the years and never using them, I stopped. Both my X100S and GX9 have built-in flashes if I really find the need. The GX9 is a pop-up and is more versatile than the one in the X100S.
  1. Shutter soft release buttons --- keep losing them. Didn't want to use o-rings to keep them in place. Found the thumb grip worked better for stability/
Not sure when I started using soft release buttons and like you, I kept loosing them because they would just not stay on. The first few were quite expensive, then I switched to cheeps but the results were the same and those little rubber o-rings didn't help. There are only two exceptions; the Leica-branded soft release that came on my used M9 and stuck like glue and the JJC one you see on my X100S. I first got that release for my Leica M8 and like the button on my M9 it sticks like glue. It seems to give me more control over the shutter release and is relatively inexpensive.
  1. Converter lenses --- way too bulky to carry around
When I got my black X100T, I also bought black WCL-X100 and TCL-X100 conversion lenses. Didn't like the TCL-X100 at all; it was too large and blocked a good piece of the OVF, which at that time was the viewfinder I used the most, so I returned it. I kept the WCL-X100 and found it to be more useful for me. 19mm versus 23mm doesn't seem like much but sometimes it can make a difference.
I took this shot at one of the entrances to the Souk in Casablanca, Morocco with my X100T and WCL-X100. I was standing on the absolute edge of the sidewalk with my back to one of the busiest roads in Casablanca. Without the WCL-X100, I would have had to step back into that road to get this shot and become instant road-kill.
This is another one of my favorites shots I took with my X100T/WCL-X100 combo. I was standing on the little balcony on our cruise ship with little room to maneuver, when I took this shot of a ferry leaving the main harbor in Madeira, Portugal. Not sure how different it would have been without the WCL-X100 on my T.
I sold the WCL-X100 when I sold my X100T and have not found a compelling reason to get another one.
Bill S.
www.flickr.com/photos/wrs1946
“If your pictures aren't good enough, you aren't close enough”
? Robert Cappa ?
