R3 EF Lens Compatibility List with high-speed modes from Canon
UZI2D30 Regular Member • Posts: 146
Should be interesting to see what speed the unsupported EF lenses shoot.
___
https://hk.canon/en/consumer/web/ef-lenses-compatible-to-eos-r3-max-continuous-shooting-speed
支援EOS R3最高連續拍攝速度的 EF 鏡頭
EF lenses compatible to EOS R3 Max. Continuous shooting Speed
以下EF鏡頭支援的連續拍攝速度:
  • 高速連續拍攝+模式(H+)時:最高約30FPS連續拍攝(電子快門)或約12 FPS 連續拍攝(機械快門及電子第一簾快門)。
  • 高速連續拍攝模式(H)時:最高約8FPS連續拍攝(電子快門)
The EF Lenses listed below supports the following continuous shooting speed:
  • High-speed continuous shooting + (H+) mode: Max. approx. 30FPS (with electronic shutter) or Max. approx. 12FPS (with mechanical shutter and electrnic first custain shutter).
  • High-speed continuous shooting (H) mode: Max. approx. 8FPS (with electronic shutter).
EF 鏡頭|EF Lens
  • EF 24mm f/2.8 IS USM
  • EF 28mm f/2.8 IS USM
  • ​​​​​​​EF 35mm f/1.4L II USM
  • ​​​​​​​EF 35mm f/2 IS USM
  • ​​​​​​​EF 40mm f/2.8 STM​
  • ​​​​​​EF 50mm f/1.8 STM​​
  • ​​​​​EF 85mm f/1.4L IS USM
  • EF 100mm f/2.8L Macro IS USM
  • ​​​​​​​EF 300mm f/2.8L IS II USM
  • ​​​​​​​EF 400mm f/2.8L IS III USM
  • ​​​​​​​EF 500mm f/4L IS II USM​
  • ​​​​​​EF 600mm f/4L IS II USM
  • ​​​​​​​EF 600mm f/4L IS III USM
  • ​​​​​​​EF 8-15mm f/4L Fisheye USM
  • ​​​​​​​EF 11-24mm f/4L USM​​
  • ​​​​​EF 16-35mm f/2.8L III USM​​​​​​​
  • EF 16-35mm f/4L IS USM
  • ​​​​​​​EF 24-70mm f/2.8L II USM​
  • ​​​​​​EF 24-70mm f/4L IS USM​
  • ​​​​​​EF 24-105mm f/4L IS II USM
  • ​​​​​​​EF 24-105mm f/3.5-5.6 IS STM
  • EF 70-200mm f/2.8L IS II USM
  • ​​​​​​​EF 70-200mm f/2.8L IS III USM
  • ​​​​​​​​​​​EF 70-200mm f/4L IS II USM
  • ​​​​​​​EF 70-300mm f/4-5.6L IS USM
  • ​​​​​​​EF 70-300mm f/4-5.6 IS II USM
  • ​​​​​​​EF 100-400mm f/4.5-5.6L IS II USM
  • ​​​​​​​EF 200-400mm f/4L IS USM Extender 1.4x
 UZI2D30's gear list:UZI2D30's gear list
Canon EOS-1D Canon EOS-1D Mark II N Canon EOS-1D Mark III Canon EOS-1D X Canon EOS-1D X Mark II +19 more
