Over/Under photos.
Started Sep 20, 2021 | Discussions
GeorgesGG New Member • Posts: 2
Over/Under photos.
Hi there! I'm new to the underwater photography world and I'm having an issue when doing over/under images.
This is what I'm shooting with:
- Ikelite 6812.7 without any extension (do not know the dome model number)
- Nikon D700 FX Body
- Nikkor AF 24mm f/2.8D
My issue is that even when shooting at small apertures (f/9, f/11) I can't get both sides to be in focus. Is either the over water part in focus or the under the water part, but not both.
I see pictures like this all the time:
However, the pictures I can only achieve are like this:
1/320 - f/9 - ISO 100 - 24mm FX
Can anyone tell me what am I doing wrong?
Should I buy a bigger dome?
I appreciate any response since I'm driving myself crazy! Thanks for your time!!
PS: These are some pictures of the housing I have:
Ikelite 6812.7
Ikelite 6812.7 with dome
 GeorgesGG's gear list:GeorgesGG's gear list
Nikon Z5
Nikon D700
Barmaglot_07 Contributing Member • Posts: 633
Re: Over/Under photos.
Per Ikelite port chart for FL system, your lens needs 5510.45 dome with 5510.16 extension. I'm not very familiar with Ikelite systems, so I can't readily identify which dome it is that you're using, but it's definitely not 5510.45.
You might also want to consider using a fisheye lens instead, as they have much greater depth of field and thus are more conducive to over/under split images.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
Architeuthis Regular Member • Posts: 491
What is the diameter of the dome in cm or inches (but this is not really the crucial aspect)?
I would recommend to close aperture to a least f 13 and to focus on the UW part instead on over water...
See here for more and better help:
https://www.uwphotographyguide.com/over-under-split-photography
https://www.ikelite.com/blogs/advanced-techniques/how-to-shoot-split-shots-half-in-half-out-of-the-water
https://www.backscatter.com/reviews/post/Underwater-Split-Photography-Tips-A-View-Of-Two-Worlds
https://www.divephotoguide.com/underwater-photography-techniques/article/over-unders
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
OP GeorgesGG New Member • Posts: 2
Thank you Barmaglot_07!!!
I appreciate your fast reply. I will be looking into that ASAP.
Nikon Z5
kelpdiver Veteran Member • Posts: 5,564
I think you got a lot of good advice.  I can't tell if that dome is a 6 or 8".   It's harder with the 6.   Tightening it from F/9 and making the UW the focal point as suggested is key, but B may be right to identify that you need an extension port so the dome focuses properly.   Don't know if you have to go to a fisheye or not.
I'm in Palau in 3 weeks and I'll be trying to do the same.   Happily I will have some shore dive opportunity where I can practice this standing.   I'm not sure how I'll be able to do it in deep water given the massive weight of the R5 rig, but I can at least figure it out in the shallows first.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
I've tried this a number of times, and mostly failed miserably.   Without some sort of float on the housing, my rig (30+ pounds dry) is simply too massive to hold half out of the water.   My attempts mostly involve a bit of momentum and total luck.
Here was my first attempt, at the end of a dive when I simply shoved the camera up and hit the shutter release.  Not much under.
Here is a better result on another attempt.  I took several images as I was ascending, with this being the last one.
I once tried to practice over-unders in a shallow area next to my dive resort.  Figured if I was standing on the bottom I could simply hold the camera as needed.
The reality was that it was almost as hard to stand up with fins on with all that weight and a bit of current as shoving the rig out of the water.  I got nothing from the attempt as I fell over repeatedly.   Sigh.
My advice:  get some sort of float for the camera
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Kofla Olivieri
Kofla Olivieri Regular Member • Posts: 342
I sure hope to get better results than these images using my GoPro and a Telesin GoPro Dome.
 Kofla Olivieri's gear list:Kofla Olivieri's gear list
Nikon D7000 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Sigma 10-20mm F4-5.6 EX DC HSM Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR +1 more
I only got in one day where I tried it.   Got good focus under, not as good above, though I used f/8 as I was trying to make up for not having strobes for the UW shooting.  I should have closed it further.
At closer range, a problem is that the body under is larger than the head above.  So I have lots of pics of my wife and niece that are not suitable for sharing.
PHXAZCRAIG
It should be far far easier with such a small rig and naturally deep depth of field.
www.cjcphoto.net
