EOSR Fireware update 1.8. Mettering/AF start not working properly.
Started Sep 19, 2021 | Discussions
JimWork New Member • Posts: 2
Hello,
I have been using the EOSR for a little bit and recently decided to update the firmware to 1.80 (From 1.0)  Everything works as it should but the mettering/AF button is not responsive.  I can hold it for a unknown amount of time, and it will start to go off.  This was not the case before I updated.  The update is the only thing I can think of that has changed.
Is there a setting I can change or should I revert back to version 1.0?
Note: I am using a EF mount adapter with this camera.
Thank you for your time.
johncal Contributing Member • Posts: 585
Re: EOSR Fireware update 1.8. Mettering/AF start not working properly.
JimWork wrote:
Hello,
If you haven’t done so, pull the battery for a couple of minutes.
 johncal's gear list:johncal's gear list
Canon EOS 70D Canon EOS R Canon EF 50mm F1.4 USM Canon EF 28-135mm F3.5-5.6 IS USM Tamron 28-300mm F3.5-6.3 Di VC PZD +8 more
OP JimWork New Member • Posts: 2
Thank you Johncal.  I'll try that in the coming days.
