Nikon 16-80 DX 2.8-4e ED lens focus override not working
Started 2 months ago | Questions
Tumblingrun New Member • Posts: 2
Hello Everyone - I have the Nikon 16-80 DX 16-80 mm DX 2.8E ED lens which I have been using mostly on a Nikon D500. The last couple of days I have noticed the focus override is not working or is frozen. The ring simply will not turn nor can I change the focus switch from M/A to M. I have determined that it must be the lens as other lens with manual focus override are working on the D500 and when I attached the 16-80 lens to my D7100 the same problem occurs. It doesn't matter if the lens is on or off the camera, the manual focus ring will not turn and the M/A - M button is locked. Auto focus continues to work fine. Any ideas what is causing this problem? Thanks for any assistance.
Nikon D500 Nikon D7100
embie
embie Veteran Member • Posts: 3,125
Re: Nikon 16-80 DX 2.8-4e ED lens focus override not working
Hello, welcome to DPR !
Sounds like a mechanical problem inside your lens.
Remove your lens from the body and try to (gently) turn the focus ring a bit, simultaneously with "moving" the M/A - M switch.
Success,
eMBie
"Travel is fatal...for prejudice, bigotry and narrow-mindedness" (Mark Twain) - "The world...is our home" (eMBie)
You can edit and repost my pictures until you drop but they will still be mine Please respect my copyright
 embie's gear list:embie's gear list
Panasonic Lumix DMC-FZ200 Olympus TG-5 Nikon D7200 Nikon AF-S DX Nikkor 18-140mm F3.5-5.6G ED VR Nikon AF-P 70-300mm F4.5-6.3G VR +1 more
OP Tumblingrun New Member • Posts: 2
Thanks for the suggestion. With a bit more than a gentle twist of the focusing ring I was able to free it and it now turns. Was unable to move the M/A - M switch however but I rarely use the M selection on the lens just the override.
m1964 Contributing Member • Posts: 754
I just checked mine. I almost never use focus override and don't even remeber wnen I moved the focus mode switch- probably when I got the lens a few years ago.
On mine, the focus ring moved fine, the switch needed a little effort, probably because I never used it.
If you used the lens outdoors,  in dusty environment, it possible some dust got into the mechanics.
You can try spraying electrical connector cleaner/lubricant around the switch, or possibly send the lens to Nikon for servicing.
I would not apply increased pressure to either one-the focus ring or the switch.
 m1964's gear list:m1964's gear list
Nikon D7100 Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR Tamron SP 85mm F1.8 Di VC USD Nikon AP-F 70-300mm F4.5-5.6E Tamron SP 35mm F1.4 Di USD
