R3 lenses before R5 may require firmware upgrade or not supported
Started Sep 19, 2021 | Discussions
Will T
Will T Regular Member • Posts: 425
Read bottom small text!
It says lenses before R5 may require firmware upgrade or not supported?????
Will T.
"Galleries don't hang DxO charts" David Hull
Canon EOS R3
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: R3 lenses before R5 may require firmware upgrade or not supported
For coordinated control. So, perhaps you'll only get 5 stops of IS on some lenses. Big deal.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
PhotoKhan Forum Pro • Posts: 11,930
As I read it, the exemption pertains to the 8-stop max effect.
The other RF lenses referenced in the text will also be supported in terms of IBIS + OIS in-tandem stabilization, just not up to 8-stops.
To be confirmed...
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.humbertoborgesfotografia.com/
http://www.pbase.com/photokhan
(PBase Supporter)
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
The way it reads is that "In-body IS up to 8 Stops" is not supported on some really pricey lenses. The default statement is "up to 8 stops" for all of them. The default statement doesn't imply you get 8 stops anyway, so what exactly is "not supported" on that list of lenses. Coordinated IS?  If you only get 5 stops, that is covered by saying "up to 8 stops".  It would be very different if they said "8 stops", but they said "up to 8 stops".  That is some very muddy wording.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
GrunRad
GrunRad Regular Member • Posts: 118
5
When R5 and R6 were released, new firmware versions were also provided for most RF lenses (at least for those with IS). I understand (and the release notes confirm) that these firmware versions are required for proper co-operation of lens IS and camera IBIS.
First thing I did when I got my R5 was to make sure that all my RF lenses had their latest firmware installed (which took less than an hour for a few lenses).
 GrunRad's gear list:GrunRad's gear list
Canon EOS 5D Canon EOS R5 Canon EF 8-15mm f/4L Fisheye USM Canon EF 40mm f/2.8 STM Canon EF 24-70mm F4L IS USM +9 more
emyr evans
emyr evans Contributing Member • Posts: 649
What exactly does "coordinated control" mean?
koenkooi Contributing Member • Posts: 920
That the IBIS will complement the ILIS, instead of being largely disabled like it is when using EF IS lenses.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
Steve Balcombe Forum Pro • Posts: 15,571
It means the IBIS and the lens's optical IS cooperate so that their benefits are added together, without over-correcting - as would happen if they both operated without each knowing about the other.
PicPocket Veteran Member • Posts: 5,897
*1 is tagged to 8 stop claim
*2 is tagged to coordinated IS support on RF lenses
It's clear to me
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
John Sheehy Forum Pro • Posts: 26,688
Those CIPA stabilization numbers need to be taken with a pound of salt.  They are only about a postcard viewed at normal viewing distance, and they subject the camera and lens to all axes of shake, where real photography often only has significant pitch/yaw shake.  For 100% pixel views, they predict very little about pixel-level stability.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
Yes, adding more stabilization without coordination is not at all like adding more rocks to a bag hanging from a tripod.
John
