Check shutter count on Pansonic S1, S1R, SIH, and S5 - An easier way
Started Sep 18, 2021 | Discussions
sunnycal
sunnycal Contributing Member • Posts: 775
8
If you look for the instructions on finding shutter count, they require a bit of multi-hand/finger magic that is hard to get right.
There is an easier way. Initial steps are similar, but final steps are easier.
1. Make sure battery is fully (or nearly fully) charged, and camera is in Single-Shot mode.
2. Take a picture and turn off camera (this can be skipped if you have already taken pictures in this power cycle).
3. Press Play and AF-On button together while turning on the camera.
4. Open menus, scroll to the Setting (wrench) menu. In the sub-menu for this item, there should be two wrench items (usually there is only one). Go the second wrench item.
5. Scroll down to the last item "ERR Code DISPLAY" and select it. This will display a screen with error codes.
6. Press Play+Menu together. Voila! There is the CAMERA INFO screen with all information including shutter count.
If you are curious, press DISPLAY to view the second CAMERA INFO screen, which shows camera clock and memory info.
 sunnycal's gear list:sunnycal's gear list
Canon EOS 5D Mark II Nikon D810 Sony a6300 Sony a7R III Tamron SP AF 90mm F/2.8 Di Macro +13 more
Panasonic Lumix DC-S5 Panasonic S1
mdavidp Senior Member • Posts: 2,423
Re: Check shutter count on Pansonic S1, S1R, SIH, and S5 - An easier way
Very clever.
Thank you!
Mike P
Veggiedean DTP Regular Member • Posts: 155
Cool.  Thanks.  My S1R is only at 19,756.  I have a ways to go.
Dean
dtp-realestate.com
deantylerphotography.com
 Veggiedean DTP's gear list:Veggiedean DTP's gear list
Panasonic GH5 Panasonic Lumix DC-S1R Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Leica Nocticron 42.5mm +8 more
h1pst3r88 Regular Member • Posts: 443
4453 shots on my S1R... a baby!
Thank you so much for sharing this info!!!
-Chris
All Description is necessarily selective
 h1pst3r88's gear list:h1pst3r88's gear list
Leica X Vario Sony Cyber-shot DSC-QX10 Sony RX10 IV Leica SL (Typ 601) Sony a7 III +6 more
