Aspect Ratio Canon C100
SamRepp New Member • Posts: 13
Hello,
for an assignment in my class we were told we have to use an aspect ratio of 16:9. The issue is that, the cameras we were given don’t even have 16:9 as an option. The only options are [4,3], [13,9], [16,9], [1.66:1], [1.75:1], [1.85:1],[2.35,1] I’ve emailed my professor, but I don’t think he will see my email until after I start filming (I have to start early in the morning). Would it work if I filmed on one of these aspect ratios and then converted on premier pro when I edit? If so which one should I film on?
coberg Forum Member • Posts: 60
Re: Aspect Ratio Canon C100
The third aspect ratio in your list of available ones is [16,9]
Klaus dk
Klaus dk Veteran Member • Posts: 8,095
Unfortunately ...
Unfortunately, that's a typo. The manual says [14;9].
I'd imagine [1.75:1] would be close enough: 16/9=1.778.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 135mm F2.8 SF Canon EF 100mm f/2.8 Macro USM +14 more
Re: Unfortunately ...
See my latest responses to your identical post on the Open Talk forum
Klaus dk
You're absolutely right.
Lesson for the OP: Understanding the manual is always difficult, especially when you're stressed by a deadline or somebody waiting.
