R6 (fw 1.2.0) frenquently freezes
61094125 Forum Member • Posts: 84
Hello, my R6 (bought in Jan 2021) starts to freeze after taking a photo, EVF turned to black and nothing is helping except taking the battery out and in again.
Till now it was working without any problems. Do you think new fw woulf help?
I´m using my R6 with Canon adapter with 16-35/4 IS, 24-70/2.8 II, 70-200/4 IS and problem occurs with all my lenses.
Zdenek
 61094125's gear list:61094125's gear list
Canon EOS R6 Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Adobe Photoshop Lightroom 5
Canon EOS R6
pkoenig2001 Contributing Member • Posts: 819
Re: R6 (fw 1.2.0) frenquently freezes
I assume you upgraded to 1.2.0 a while ago but the issue only started recently?  Could the issue be the adapter- I m assuming you are using the same one for all 3 lenses.  Wonder if you can borrow another adapter and see if it solves the issue?  Or perhaps try an RF lens such as a 50 1.8 and see if it persists?
You can also try resetting settings and custom functions- this may help
I have not experienced this.  I’m actually running older firmware but was considering upgrading to latest.
Good luck and let us know.
Phil
 pkoenig2001's gear list:pkoenig2001's gear list
Canon EOS RP Canon EOS R6 Canon EF 100mm f/2.8 Macro USM Canon EF 16-35mm F4L IS USM Tamron 100-400mm F4.5-6.3 +9 more
Regarding your question about firmware, latest version is 1.4.0, which includes this fix from 1.3.1 - so you may consider upgrading to latest firmware.  Are you experiencing the issue in High Speed continuous?
"Fixes a phenomenon, in which in rare instances, the camera cannot function normally when the drive mode is set to "High-speed continuous shooting" to shoot still images continuously."
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/eos-dslr-and-mirrorless-cameras/mirrorless/eos-r6?subtab=downloads-firmware
OP 61094125 Forum Member • Posts: 84
yes
thanks, I'm going to update fw and also check the SD cards
Zdenek
Good luck - let us know if it resolves your issue.
