Best option for long focal length zoom
ChrisG56 New Member • Posts: 5
When the screen on my A99v stopped behaving nicely I bit the bullet and bought a new A7riv and, because I was so heavily invested in alpha lenses, I also bought the LAEA5 adaptor.
I then sourced and bought a replacement screen for the 99 and paid someone to fit it for me.
So, I now have two cameras with different mounts and a really good adaptor.  When I retire in June I am looking at acquiring a longer/better zoom than the Minolta 75 - 300 I currently own for wildlife and I am wondering if people feel that I would be better off buying something like the Sigma 150 - 500 in alpha fit or getting the dedicated FE 200 - 600?
toughluck Veteran Member • Posts: 3,748
Re: Best option for long focal length zoom
The old Sigma 150-500 OS HSM in A mount? I'd give it a pass.
70-400 is a sure-fire bet, but it's expensive, especially the second (white) version, Sony FE 100-400 used is not much more expensive.
Tamron's SLR 150-600 (original or G2) is pretty good, but not as good as more recent xx-400/500/600 lenses your mirrorless.
And there's the 200-600 which is widely regarded as one of the reasons to get Sony.
 toughluck's gear list:toughluck's gear list
Sony a99 II Sigma 50mm F1.4 EX DG HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 85mm F1.4 ZA Carl Zeiss Planar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +7 more
AkashRana
AkashRana Regular Member • Posts: 347
Of the available big zooms for A-mount Sony 70-400 is a great option, hands down. Its my favorite of the bunch.
Another option would be Tamron 150-600, where G1 is good and G2 is slightly better than previous generation. Though crop-ability at 600mm isn't great, so if you fill the frame you will get some good pics.
But as you have an E-mount body, I would say move in that direction instead as there are some good options available for all budgets like Sigma 100-400 at the lower end, Tamron 150-500 & Sigma 150-600 in the middle; with Sony 200-600 and Sony 100-400 at the top tier. From what i have seen, your E-mount camera with a native lens, you would have lot more keepers when compared to A99.
 AkashRana's gear list:AkashRana's gear list
Sony a99 II Sony 70-200mm F2.8 G Sony 70-400mm F4-5.6 G SSM Tamron 15-30mm F2.8 Sony 24-70mm F2.8 II +6 more
Michael Fritzen Veteran Member • Posts: 6,450
Hi,
in 2019 I added an a6400 to my A-Mount gear built around an A99II. Since the idea was to check out E-Mount for me (handling but also AF performance) I got only the 18-135 as native E-Mount lens and added the LAEA-3 for using also my A-Mount lenses to test how they fare adapted.
Both my 70-200 and 70-400 performed well. Also my Sigma's 24-70 and 12-24. So essentially I didn't see the need for a complete change.
Well, at some point I added the E-Mount 200-600 but much more because I wanted a longer FL than the 70-400.
Michael Fritzen
OP ChrisG56 New Member • Posts: 5
Thanks for this. Very helpful, and I can feel myself moving in the direction you suggest.
Thanks for this. Useful guidance.
Ed at Ridersite Forum Pro • Posts: 19,962
I use the 70-400mm A-mount on my A-68.  A friend uses the 200-600mm E-mount on his A7R4.  For longer reach he also uses the crop mode making the 200-600mm a 300-900mm.  Furthermore, he can use it with the 1.4TC reaching 1260mm in crop mode.  He's a professional and his photos are top notch - much better than anything I produce.  Based on what I see from him, I'd definitely recommend the 200-600mm for your A7R4.
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony SLT-A68 Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
Lensmate
Lensmate Veteran Member • Posts: 6,482
No brainer...go for the 200-600mm!
-M
 Lensmate's gear list:Lensmate's gear list
Sony Cyber-shot DSC-F717 Sony RX100 Sony RX100 VII Sony Alpha DSLR-A100 Sony SLT-A55 +11 more
grsnovi
grsnovi Senior Member • Posts: 1,703
I'm using the original a-mount Tamron 150-600 on my a7Riii with the LA-EA5 and other than not getting AF-C I'm having a hard time trying to justify the 200-600.
What do you shoot?
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 Sony 50mm F2.8 Macro +7 more
TomV1 Regular Member • Posts: 383
What do you shoot?
I have the G2 version of the Tamron (2 copies actually) and find them to be excellent lenses for the money. I also have the SAL500f4 and they compare favorably to it  optically. The AF is of course faster on the prime but the focus limiter on the G2 helps out a lot. My a99ii has MFA for both wide and tele ends of zooms, so that also helps out with the focus. With mirrorless, that is probably a moot point. Unless you need more AF points, then I can recommend it.
 TomV1's gear list:TomV1's gear list
Sony a99 II Sony 70-400mm F4-5.6 G SSM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Rokinon T-S 24mm F3.5 ED AS UMC Sony 70-300mm F4.5-5.6 SSM II +11 more
Gary Waugh Senior Member • Posts: 1,811
A useful guide to the quality of Sony zoom lens can be found here:
https://www.dyxum.com/lenses/results.asp?chbLensType=3
Just be aware that this does not cover how well it works on the adapter.
Gary in PA
 Gary Waugh's gear list:Gary Waugh's gear list
Panasonic Lumix DC-G9
tbcass
tbcass Forum Pro • Posts: 51,735
I own a Tamron 150-600 which is very good.
Tom
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-300mm F/4-5.6 Di USD +8 more
lehill
lehill Veteran Member • Posts: 6,359
I retired in 2016 and I freely admit I'm a lens hoarder. My old Sigma 150-500mm F5-6.3 DG OS HSM is the only lens I've sold - that should tell you something. The original Tamron/Sigma 150-600mm lenses just raised the bar for inexpensive long zooms and that bar has only gone higher ever since.
Today my main long lens setup is the A7RIV, SAL70400G2+LA-EA5, and SEL200600G.*
400mm zooms typically have a minimum focus distance around 5-6 ft. 600mm zooms are about double that. So the SAL70400G2 gets used in "close quarter" shooting (botanical gardens and such) while the SEL200600G gets used out in the field where the action is farther away.
The Tamron 150-500mm F5-6.7 Di III VC VXD looks very interesting. With Tamron's recent track record of excellent, yet inexpensive, lenses, this should go on the "check it out" list.
Sony's Lens Compatibility chart could be useful in your search (but only for Sony lenses). Pick a lens, then a body, then an adapter to see any restrictions.
*My A99II is now happy taking indoor photographs of my granddaughters.
Lance H
 lehill's gear list:lehill's gear list
Sony a6000 Sony a7 II Sony a99 II Sony a7R IV Sigma 10-20mm F4-5.6 EX DC HSM +30 more
