STD (Provia) vs Velvia
Started Sep 15, 2021 | Photos
(unknown member) Regular Member • Posts: 469
Re: STD (Provia) vs Velvia
Hi OP,
Well, frankly speaking, there is mild difference but it's not huge. Some parts of the image have barely changed. Because that's the deal with Film Simulations - the effect is much more subtle compared to the kind of options present on Panasonic or Olympus cameras.
The only simulations that produce dramatic change are Classic Chrome and Classic Neg. These can be recognised in a blind test. The rest frankly are not vastly different. See, for example, these images from the wonderful website jmpeltier.com
The difference is obvious (river), but certainly not dramatic
Do you even see any difference? At this small resolution, I can't
I can tell them apart side by side, but given only one, I won't know which simulation it is
So that's that. Velvia sometimes delivers and noticeable punch and sometimes is pretty close to Provia. It varies according to scene and lighting.
If you need extra punch, you'll need to apply in camera tweaks.
bs1946
OP bs1946 Veteran Member • Posts: 7,778
This is truly interesting and I thank you for sharing these photos. I have owned 12 different Fuji cameras and the only other time I ever took the same shot using different film simulations was when I had an X-E1 with the 18mm f2 back in 2014 or 2015. Took a shot of a red railroad caboose with bright yellow railings and I do remember that the Velvia image was far more saturated that the others and stood out like a sore thumb.
Bill S.
www.flickr.com/photos/wrs1946
“If your pictures aren't good enough, you aren't close enough”
? Robert Cappa ?
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
LarsRost Contributing Member • Posts: 663
The visible difference between film simulations depends a a lot on the picture itself. For example, in a picture with lots of red/brown tones I can clearly see the difference between Astia and Velvia.
 LarsRost's gear list:LarsRost's gear list
Fujifilm X-H2S Fujifilm XF 56mm F1.2 R Sigma 50-100mm F1.8 DC HSM Art Fujifilm XF 18mm F1.4 R LM WR XF 150-600mm
Coldpaw Contributing Member • Posts: 772
That was most likely related to the subject, the lighting and last but not least the overall colors. Velvia can be really punchy, for my taste most of the time too much, so I barely use it. As Kamerakiri already mentioned, there are some film sims which provide a much more visible impact, like Classic Chrome, Classic Neg, Eterna or the fairly new Bleach Bypass.
There is a fairly in-depth article about the simulations over at Imaging Resource:
https://www.imaging-resource.com/news/2020/08/18/fujifilm-film-simulations-definitive-guide
Here is a direct comparison between Classic Chrome and Classic Neg, while the difference in some photos is striking and visible at first glance, on others it's much more subtle:
https://www.jmpeltier.com/classic-chrome-vs-classic-neg/
You might want to give the Fujifilm X-RAW Studio software a shot, you can download it for free directly from Fujifilm. The software needs you camera to be connected and actually uses the camera itself for all the processing, with the software being more or less a more comfortable UI to control you in-camera conversions. This is the most comfortable and easiest way to compare different film simulations on different images.
As usual, depending on the camera, you can further tweak each sim with some additional settings. For example there is a Color-setting which lets you adjust the overall color (de-)saturation of the film sim. Staying with Velvia, set Color to +3 or +4 and the impact of the film sim should be higher right away.
biza43 Forum Pro • Posts: 15,074
They are clearly different, with Velvia more saturated, as expected.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Amadeus21 Senior Member • Posts: 1,162
Sorry, but your monitor setup is not suited to have a adaequate  look at colours in general: 46 inch sony monitor! that is an TV monitor, showing all colours, but exactly. So the MacBook, too.
You need a calibrated environment, at least better monitors.
Johannes
 Amadeus21's gear list:Amadeus21's gear list
Fujifilm X100V Sony Alpha DSLR-A900 Sigma SD1 Merrill
