Olympus 100-400 vs (found faulty) Panasonic/Leica 100-400
Started Sep 14, 2021 | Discussions
jalywol
jalywol Forum Pro • Posts: 12,301
Old thread, was solved:
Stevenray wrote:
The picture sample you have posted for the Lumix lens is back-focused. The Lumix Leica lens is focused on the hair not the eye. It would be better if you could have manually focused both lenses on the eye for the comparison.
This thread was posted over a year ago, and, if you read through it, it turned out that the Panasonic that the OP had tried was defective.
-J
PhotoMac503 Senior Member • Posts: 1,057
Re: Old thread, was solved:
Glad to hear it was resolved satisfactorily.
I went through mutiple copies of the PL and eventually gave up, and got a great copy of the Olympus 100-400.
The PL 100-400 is not a lens I would recommend buying used and without a good return policy.
It's a shame so many people kept their bad copies - if consumers don't push back against poor products then nothing will improve.
 PhotoMac503's gear list:PhotoMac503's gear list
Olympus E-M1 II Olympus 12-100mm F4.0 Olympus 100-400mm F5.0-6.3 IS +1 more
jalywol
It was a rental.  He ended up calling LensRentals and asked them to test the one he had rented, and, indeed, it was way out of spec.
These are very sensitive to shipping mishaps, I think, which is why they vary so much.  It would also explain why the LensRentals one was bad...lots of shipping malhandling possible with rental units.
-J
glassoholic
glassoholic Veteran Member • Posts: 7,641
-J
I think when it's bad, it's just bad. Mine goes in a motorcycle top box pannier (in a camera bag) on an adventure bike and on rough roads for thousands of kilometres and is still fine.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
-J
Maybe your adventures knocked it back in to spec.
ProDude Senior Member • Posts: 4,857
-J
I did my comparisons with an OM1 of both lenses at the beginning. Found the images from the Panasonic/Leica to be VERY inconsistent and not as sharp as the Oly at the  long end in particular. My copy of the Olympus 100-400 happens to be sharp one end to the other so will never part with it. Even with the 1.4x tc on it renders superb sharp images at the long end where I occasionally need it.
Name the gear and I've probably owned it and used it.
