Olympus 100-400 vs (found faulty) Panasonic/Leica 100-400
Started Sep 14, 2021 | Discussions
Henry Richardson Forum Pro • Posts: 21,959
Even E-M10II IBIS is darn good with Olympus 100-400mm
5
E-M10II IBIS is darn good with 100-400mm after 2 cups of coffee
https://www.dpreview.com/forums/post/64526654
About 800mm-efl, 1/30 second, standing with no support, no special care to be extra steady and after 2 cups of coffee:
IBIS turned ON, ILIS turned OFF with 100-400mm after 2 cups of coffee
https://www.dpreview.com/forums/post/64537034
Henry Richardson
http://www.bakubo.com
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Re: Review: Olympus 100-400 vs Panasonic/Leica 100-400
xaprb wrote:
Thank you for correcting me!
For static subjects, the Pen-F works perfectly well with the PL100-400. Just use the lens IS, not the camera IBIS, it works better. On the EM5.3 I found the IBIS does a slightly better job than the lens IS.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
vigna Regular Member • Posts: 377
It is so ridiculous that this thread is based on a comparison of a photo of a button to conclude as a bad lens.
 vigna's gear list:vigna's gear list
Panasonic ZS100 Panasonic LX100 II Canon EOS 20D Panasonic Lumix DC-G9 Sigma fp +13 more
jalywol
jalywol Forum Pro • Posts: 12,301
Have you read the follow up? LensRentals tested it and found it was, indeed, a bad lens.....
And the photo of the stuffed animal (I guess the eye is the button you are referring to), has the mushiest fur detail, which I suspect is what most people were looking at. And, the OP described unusual AF behavior in his post...so...
J
RichardCass
RichardCass Regular Member • Posts: 333
I have the Olympus. My gallery has a number of examples. I'm very happy with it.
However, I've also seen excellent examples from the Panasonic.
A fair comparison would be either to switch IS off on both lenses and test them on a tripod at the same aperture, focal length, same static subject, same conditions -or- test the Panasonic on a Panasonic body.
EDIT: I too didn't read the follow up!
Here's one from the Olympus.
 RichardCass's gear list:RichardCass's gear list
Panasonic Lumix DC-S1R Olympus OM-D E-M1X Panasonic Lumix DC-S5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 50mm F1.4 (L-mount) +7 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
7
xaprb wrote:
Thanks Roger, I appreciate you taking the time to respond directly on this. I rent from LensRentals because of the stellar customer service, and my confidence in your equipment and your technicians' testing. In fact, that's literally the reason it didn't occur to me to check first with LensRentals before writing my results on this forum. I'd seen mixed reviews on the Panasonic and my experience seemed to back that up, and it didn't stick out to me as "this lens is SO bad that it might be a bad copy." It just seemed like "yep, people have said the Olympus is sharper, it looks like that's what I found too."
I just heard from your team a few minutes ago confirming that the lens I rented was not meeting expectations.
I appreciate the people who responded to this thread suggesting that I contact LensRentals!
Good outcome! Now to be fair, you should ask the forum moderator to add the following to your OP title "bad copy" or something similar, so that potential purchasers don't have to read all the way down to this post before getting an inaccurate opinion.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
kitanaka
kitanaka Contributing Member • Posts: 966
olrett wrote:
kitanaka wrote:
I recently wrote a blog post about this lens
Bird and wildlife photography with the Panasonic Leica 100-400 (richardcookphotography.com)
and while these pictures aren't amazing [...]
Your pictures are wonderful, regardless what system and lenses you use.
And I love the PL100-400 review.
Thanks so much olret. Really glad you liked the review too. Thanks for taking the time.
 kitanaka's gear list:kitanaka's gear list
Nikon D500 Olympus E-M1 II OM-1 Nikon AF-S Nikkor 300mm f/2.8G ED-IF VR Nikon 200-500mm F5.6E ED VR +2 more
OP xaprb Regular Member • Posts: 105
Re: Olympus 100-400 vs (found faulty) Panasonic/Leica 100-400
5
As a followup to this thread, I have purchased the Panasonic 100-400. I'm also shopping for a newer, more capable Olympus body. In the end, the size and weight was really compelling to me.
One thing I'm curious about: I keep pretty detailed notes, and I'd noted that the copy I rented was stamped as made in Japan next to the serial number on the mount. The copy I bought is stamped China. I checked the Q&A on this lens's page on B&H, and people have reported both China and Japan in the past, and not only recently, but going back quite a few years. So apparently they have multiple suppliers, and have for years. To be clear I have no prejudice against things made in China, however, I do wonder about having multiple suppliers and what that might reveal about people's reported positive or negative experiences with the lens. My experience is the "same" lens built to spec by different suppliers is never truly consistent. Thus far, my new copy seems to be fine.
PS: thanks to whoever contacted the moderators and asked them to add "found faulty" to the thread title.
 xaprb's gear list:xaprb's gear list
Fujifilm X100V Olympus PEN-F OM-1 Fujifilm X-H2S +1 more
jalywol
I assume the performance of the one you have now is better than the one you rented
How are you liking it?
Some photos?
When I went through my most recent acquisition of this lens, I had two from China, one from Japan. (And I think my original was from Japan, from several years ago). This round, one from China and one from Japan were each bad. The first one, from China, focused fine but had a defective AF motor with a loud whine, unfortunately. (I prefer my lenses not to sing to me as I use them, so I sent it back. It's too bad, as optically it was stellar). The one from Japan had a bad AF module, so that one went back too (I think it might have been shipping damage as the lens box was bouncing around a large box on the way to me, without proper cushioning). Third time was the charm, and this one was from China also.
Enjoy your new lens!
-J
(A couple from it from the other day:)
glassoholic
Some photos?
-J
My PL 100-400 has travelled thousands of kilometres in a motorcycle pannier (inside a Lowepro shoulder bag)... many dirt roads with the motorcycle bouncing around. I would expect a premium lens to survive some bouncing around, but who knows, maybe I have just been lucky.
Addicted To Glass
cba_melbourne
Panasonic moved production of this lens from Japan to China about 2 years ago.
A rather late move by Panasonic. The Japanese government now subsidizes Japanese companies to move production out of China - either back to Japan or elsewhere.
Bassaidai Contributing Member • Posts: 801
7
Thanks for opening this thread and following up all messages and paths this thread has come. I really appreciate the way you handled all suggestions and even some accusations.
I'm relieved your PL copy turned out to be faulty, and thumbs up for someone from LensRental even taking care of this issue within this very thread. You called that a "stellar service" and I see why.
I'm a very (very!) happy user of the PL100-400 myself. Not one single zoom lens comparable to that focal length has given me as good results wide open at the long end of the focal range as this lens has. This includes well respected lenses like the Canon L 70-200/2.8, Canon L 100-400/f5.6, the Sigma EX 120-300/2.8 or the newer Sigma 150-600/...f6.7.
(The only overall sharper zoom lens I have seen so far is the Oly 40-150/2.8, witch amazes me every time I use it. Sure, 150mm is no 400mm, but f2.8 is no f6.3 either... It is my understanding that the PL 50-200 is similarly impressive, but I don't own one so I can't personally comment on that)
So, in the end you have become confident enough to purchase the PL100-400 instead of the Oly 100-400, which is a statement in itself.
Have plenty of fun with the new lens!
the other day at the zoo: G9, PL100-400, 400mm, f6.3, ISO1600, 1/200s
G9, PL100-400, 400mm, f6.3, ISO1600, 1/400th
Bass
If things appear to good to be true - they're usually neither of both.
 Bassaidai's gear list:Bassaidai's gear list
Panasonic GH5 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +8 more
6
Followup: I'm quite satisfied with the Panasonic 100-400 copy I bought. I do believe the stabilization on the Olympus I rented was smoother and handled panning etc better, though the stabilization on this one is definitely better than the one I rented.
Image quality is more than satisfactory on this copy. This is just an offhand shot at 400mm, handheld, just after dawn (not full light).
glassoholic
I would never swop my PL for the Oly 100-400 as my PL performs as well as I could expect and is noticably smaller and lighter.
Addicted To Glass
glassoholic
Thanks for the follow up.
Addicted To Glass
bbbbbbbbbbb Senior Member • Posts: 2,239
I've often heard it said that Oly tends to be sharper wide open than other lenses. Is it a popular myth or a deliberate business decision, I don't know. I shoot with a 300mm f4 + MC-20. That gives f8 wide open. I dare not go lower or risk loosing every shot to blur but that's plenty sharp enough, in fact incredibly sharp.
 bbbbbbbbbbb's gear list:bbbbbbbbbbb's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus E-450 +8 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: A poor sample - the last resort excuse
Lotus Cat wrote:
Bobby J wrote:
I've the P/L almost since it came out and have had none of the problems you seem to have here. Zero. I've never considered buying the Oly 100-400 for myself, but got one for my son and from what I've seen of his images it's quite good. I have thought about ordering a 150-400 but decided not to. I shoot with an EM1MK2. I have a feeling you possibly got a poor sample unfortunately. Just my 2 cents.
Hi Bobby J,
So many people claim a tester must have gotten a poor sample when their favorite lens does not measure up in a test. Yes, you may be correct, but it seems there are so many comments of this nature that poor samples must be the norm rather than the exception.
I am glad that your PanaLeica 100-400 measures up to your expectations. You may have gotten an exceptional sample. Happy shooting.
James
My Panasonic pl100-400 is soft when fitted to a Panasonic dual IS gx8, even with electronic shutter.
But when the pl100-400 is fitted to my Olympus em1-mk2 camera it's very sharp. So I always use it wide open unless I need more DoF. Mine doesn't get sharper when stopped down.
Was it bad copy, user error, or poor comparability?
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
jalywol
If you read through the entire thread, it was a bad copy (LensRentals tested it and verified it was not performing properly)
The OP has since purchased another copy of this lens and is very pleased with it (see posts down further in the thread).
-J
Adrian Harris
-J
Thank you .
Stevenray New Member • Posts: 1
The picture sample you have posted for the Lumix lens is back-focused. The Lumix Leica lens is focused on the hair not the eye. It would be better if you could have manually focused both lenses on the eye for the comparison.
