An E-P5 + lens question
Started Sep 12, 2021 | Discussions
MiguelATF
MiguelATF Contributing Member • Posts: 516
I'm wondering if the hardcore E-P5 (EP5) users would weigh in on a small question.
I'm on the verge of acquiring my first (relatively lightly used) E-P5 camera body.
The one lens I always had in mind to use with it, is the smallish Panasonic 20mm f/1.7. In previous lifetimes, I have owned, and used - and seriously appreciated - both version of this lens, the original one, and the second V II (all-black) version. I honestly never noticed any differences at all in the output or functioning of the two lenses (except, weirdly, it seemed that my v.II autofocused more slowly than my v.I had).
For those who have used their P5 with either (and preferably, with both) versions of the 20mm - do or did you have a preference for one or the other?  And if so, why?
"I photograph to find out what something will look like photographed."
~Garry Winogrand~
Ipernity: http://www.ipernity.com/home/1647950
Flickr: https://www.flickr.com/photos/migueltejadaflores/
Blog: http://migueltejadaflores.wordpress.com
 MiguelATF's gear list:MiguelATF's gear list
Olympus C-7070 Wide Zoom Fujifilm X30 Panasonic Lumix DMC-GX1 Olympus PEN E-P5 Pentax Q7 +10 more
Olympus PEN E-P5
Day Hiker Forum Pro • Posts: 10,829
Forget the E-P5
The E-P5 is a fabulous but seriously flawed Pen camera; I owned four of them. Three of them exhibited the dreaded front/rear dial failure. The only reason the fourth one did not fail on me is that I got smart and sold it while everything was still working OK. I moved on to Pen F and E-M1. That was a very smart move.
Put your 20mm f/1.7 on any other body. It’s a great lens with no appreciable differences between v1 and v2; too bad Panasonic didn’t upgrade AF performance between versions. I would recommend any E-M10, especially the current Mk IV.
James
MiguelATF
OP MiguelATF Contributing Member • Posts: 516
Re: Forget the E-P5
James
I appreciate your opinions, James, and I'm quite aware of the E-P5's many flaws. What I am really wondering about, however, is not the merits of camera bodies - but rather, feedback on the two versions of the 20mm lens. (Whose fast AF deficiencies are well known to most of us, though with the kinds of photography I do, AF speed is not an issue.)
But my serious thanks to you for your 'take' (that there are no appreciable differences between v1 and v2) - it's helpful!
Weirdly, in my previous experiences with both v1 and v2, they seemed to perform as well or even better on Olympus bodies than on Panasonic ones.
~Garry Winogrand~
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Forget the E-P5
As a happy E-P5 user I see none of these "many flaws". I would like to find out what all the flaws are.
Bought a black one in 2014 and it did have front/rear dials that failed while on a 6 week holiday, no matter, revert to E-PL1 button only mode and all OK until the warranty fix.
Bought a silver one in 2015 and its serial number was a bit earlier than the black one, no dial problems at all now 6 years later. Ditto the repaired black one, no further problems in the same 6 years.
So the only flaw that I knew of was no problem.
MiguelATF
Back on topic (v1 vs v2 of the 20mm with the EP5)
Let me revise my previous post, Guy - and strike out the word 'many'. The E-P5's most documented 'flaw' was its issues with dials; additionally, for many Olympus fans who were hungering for a built-in EVF before the EP5's introduction, its lack thereof constituted another 'flaw'. Along the same lines, for addicts of EVF viewing, adding an external VF2 or VF4 made the camera a bit unwieldy compared to its competitors with built-in EVF's, aka the E-M5 and the GX7, etc. (Although, arguably, the superior quality of the VF-4 makes the viewing experience of an EP5 equipped VF4 superior to many if not most of those self-same competitors.)
And just to be clear by the way: if I didn't appreciate the E-P5 and think it was a fairly remarkable camera, I wouldn't be going out of my way to get one in the first place
Sorry for going off on a tangent, let me come back to my original question (and the reason I created this thread): as an E-P5 owner and user, do you have experience with - or opinions regarding - either v1 or v2 of the Lumix 20mm lens with the P5?  Would you recommend or favor one or the other on an EP5 body?
~Garry Winogrand~
Guy Parsons
Re: Back on topic (v1 vs v2 of the 20mm with the EP5)
The dial situation was very patchy, some had awful problems time after time, others never had any problems at all and some had a problem and a good warranty fix. I'm happy to be in the latter two groups.
In my case the VF-2 satisfied any initial cravings for an EVF, but being so used to compact cameras and using only screens I soon abandoned the VF-2 and only dig it out very year or so t see if it still works. So lack of EVF absolutely no flaw for me.
I do have a hardly ever used E-M10 Mk2 and on that I ignore the EVF and use the screen anyway, just my habit now as I like it that way.
For me when I went E-PL1>E-PL5>E-P5 then I stopped at E-P5 as it represented "peace at last" for me and it does all that I need and does it nicely. Sad that the latest "E-P7" did not follow the E-Px tradition and is really a fancied up E-PL11 if we have to give it a name.
Sorry no help there, I once did try to buy the 20mm but was out of stock at the time and I never followed up. Happily went down my usual zoom path and am happy.
If getting the E-P5 then check the shutter count and also maybe my page on the E-P5 menus helps explain some things a whisker better than the manual.
eclipsechaser1 Regular Member • Posts: 360
Re: An E-P5 + lens question
Regular EP5 user here.  No issues with this wonderful camera but I did get the dials done by Olympus.  And sorry I cant help with the lens but would add that you should also seriously consider the oly 17.5 on this camera.  They were often sold together.
 eclipsechaser1's gear list:eclipsechaser1's gear list
Olympus PEN E-P5 Olympus E-M1 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 17mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH +3 more
aw614 New Member • Posts: 8
Hey Miguel,
I used the E-P5 i am sending you with the MK1 Panasonic 20mm. I didnt experience any problems with it, but I also didn't experience the banding issue as I only shot with it in daylight outdoor situations.
I do recall reading in another older thread the Olympus bodies don't correct for CA, like how they do on Panasonic bodies, but I don't recall experiencing it.
MiguelATF
aw614 wrote:
Hey Miguel,
Interesting.  I read about the banding too, by the way, but in the past, when I used v1 of the 20mm for years, and then later had v2 for a few months, I never experienced any banding issues at all.  And actually most of the pictures I took with both lenses were indoors, in a variety of different lighting situations.
In my own (limited) experience, v1 was one of the nicest lenses I have ever used, period. But most of the shooting I did with it was done on a Lumix camera that I used to have, so I was and am a little curious about how the lens might perform on a digital Pen.
Thanxxx for letting me know.
~Garry Winogrand~
BG28
BG28 Contributing Member • Posts: 612
I've only used the mk I version of the 20mm, so can't speak to the difference. On my E-P5, it was great: nice size, no banding. I DO think that CA was uncorrected but I don't remember it every being a huge issue, except maybe only for landscapes in very specific conditions.
If I'm shooting street scenes I shoot with the PL 15/1.7 as I found the AF a bit too slow on the 20. I'm often not that deliberate in this environment, and sometimes I'm not looking through an evf or lcd so the laggy AF wasn't a great fit.
 BG28's gear list:BG28's gear list
Olympus PEN E-P5 Olympus E-M5 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
Humansvillian
Humansvillian Veteran Member • Posts: 3,013
Any Olympus camera loves a Panny 20
This morning I grabbed my Oly PL-2, a 2011 era 10mp camera, and it delivered the same spectacular Norman Rockwell type cheesy small town Missouri photos I love taking. Any Olympus loves a fast Panny 20, this one a first version.
The fast Panny 20 also is good, after dark.
It does video, but it’s a bit noisy.
The Panny 20 is what MFT is all about, tiny, fast, sharp, twice the depth of field, and cheap.
Humansville is a town in the Missouri Ozarks
 Humansvillian's gear list:Humansvillian's gear list
Olympus TG-5 Olympus PEN E-PL1 Olympus PEN E-P5 Olympus E-M5 II Olympus 12-40mm F2.8 Pro +22 more
MiguelATF
Re: Any Olympus camera loves a Panny 20
Thanks for the feedback, Humansvillain.
Nice shots, too.  I'm especially pleased to see that your PL2 is going strong. I shot with a PL2 for several years and have fond memories of it - one of the nicer bodies Olympus produced in - and a great little camera to shoot with.  If I'm not mistaken, it actually had a 12mp sensor - which was more than capable of producing stunning photographs.
But I have to agree with you: the Panny 20 is really what MFT is all about. Something which one doesn't really realize....until one has used it and lived with it for awhile.
~Garry Winogrand~
Humansvillian
In ISO 200 light the first 6mp Canon Digital Rebel took wonderful, National Geographic level photos.
A 12 mp Olympus PL-1 did that in JPEG, and still does.
The last train stopped at the Latham Farmer’s Exchange in 1935.
The mill stayed open another fifty years, maybe?
Is that a Citizen’s Band radio arial from the seventies or a radio dispatch arial from the old Frisco line?
An Olympus with a Panny 20 is the finest documentary tool ever devised.
MiguelATF
Conundrum solved: I got the v2
My thanks to everyone who answered this thread; your responses have all been helpful. Ultimately, I'm pretty sure I would have been quite pleased with either v1 or V2 of the 20mm lens - but I found a copy of v2 for a reasonable (affordable) price.
One of those rare cases where a Panasonic lens looks like it was 'made for' an Olympus body
I hope to put the camera + lens to good use in the near future.
~Garry Winogrand~
Guy Parsons
Re: Conundrum solved: I got the v2
Nice neat combination. Not sure though for me as I used the 40mm focal length on some tiny Rollei film cameras and was never quite happy with the framing choice. Maybe I should gaffer tape one of my M4/3 zooms to 20mm for a day and see what happens.
Here in Oz the Panasonic is an AU$499 lens tax paid (about US$366) so an expensive experiment for me if I didn't like it.
BG28
Yeah, the 20 looks reeaally good on an E-P5, especially the black one!
MiguelATF
As a follow-up to this thread which I originally started 2 months ago, I have been keeping my (relatively recently acquired) 20mm Lumix (v.II) semi-permanently attached to my E-P5, and the results have been everything I hoped for (and more).  So I'm posting this photo - taken the day before Halloween, a day which was overcast, rainy and blusterous (typical weather here in Oregon) - the kind of day where everything can look washed out and gray - but the camera and lens captured scene in a way that I liked.
If you've got a friendly pet bird, sometimes the best perch is on your shoulder
~Garry Winogrand~
https://migueltejadafloresphotos.wordpress.com/
Mingjai
Mingjai Senior Member • Posts: 1,430
I know I'm late to this thread, and what I'm about to post is moot, but I wanted to get this out there for the record. The E-P5 is one of my favorite m4/3 bodies. Sure it has its flaws, but I've taken a lot of great images with it.
I've used both versions of the Panasonic 20mm with the camera, and I've never noticed any differences in terms of autofocus speed--both versions were about the same. One thing I have noticed is that the mk. II version handles flair a lot better than mk. I. My experience is similar to what Tyler Robichaud documents here in his test of both lenses:
https://tysonrobichaudphotography.blog/2013/12/19/panasonic-lumix-2020-vision-v-1-vs-v-2/
 Mingjai's gear list:Mingjai's gear list
Panasonic Lumix DC-GX9 Olympus E-M5 III Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic 8-18mm F2.8-4 +17 more
Humansvillian
My P-5 is a prized possession.
My wife and I visited a friend who’s had a stroke and is in a nursing home this evening. We visited about his folks and how a certain Zeiss Ikon Contaflex  camera was one of his father’s prized possessions. I’m storing it for him, and it’s like new, in a case, and probably worth about fifty bucks.
https://www.ebay.com/itm/Vintage-ZEISS-IKON-Contaflex-35mm-Camera-Pantar-45mm-f2-8-Lens-UNTESTED-/265385794035?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0
My Olympus P-5 and 20mm LUMIX lens is one of my prized possessions. What else can we own that costs so little, worth so much?
I have other cameras but this is the only one I need.
After my photo taking days are over I’ll remember this outfit the most fondly.
Appreciate your toys, because we only have so many days to play with them.
Guy Parsons
Re: My P-5 is a prized possession.
[E-P5]
Ditto, two of them to spread the wear, but it is my normal camera to grab for "serious" shots or for a major trip. The Sony RX100M6 does for the general snapshots and ease to carry.
I did buy a cheap E-M10 Mk2 but it gathers dust as I never seem to reach for that at all when I need a photo. I bought it to experiment with Live Composite and with using the silent shutter, but now after two years still haven't gotten around to that.
I hope to be still clicking while my heart is still ticking.
Stop reminding me....
