I´ll need to clean my S5 and I am waiting for a cleaning set to arrive.
One Lumix S5 user on Facebook assured me it works - but who knows,
maybe HE thinks the streaks are just new dirt.
Anyway, after some research:
Wikipedia says the sensor is the Exmor IMX410:
https://en.wikipedia.org/wiki/Exmor
Wikipedia lists the Sony α7 III, Nikon Z 6 Panasonic S1/S1H (so I guess the S5 as well) and Sigma fp as the Cameras using it.
It is very likely but not confirmed for this sensor that the antireflective coating
of the glass is magnesium fluoride:
Magnesium fluoride
Pretty tough btw with a mohs hardness of 6, but sand (quartz) can scratch it.
The solubility in water 0.13 g/1l. I guess this equals "almost insoluble".
Just a guess that your solution cracked the magnesium fluoride and it attracts
mousture from the air. Maybe the VSGO solution had some acetone in it
that dissolves the layer.
But again, these are just guesses.
Another Source, Sony's QHY410C astro camera that uses the IMX410 as well:
https://www.qhyccd.com/qhy410c/
"Cleaning the CMOS sensor and optical window
If you find dust on the CMOS sensor, you can first unscrew the front plate of the cam and then clean the CMOS sensor with a cleaning kit for SLR camera sensors. Because the CMOS sensor has an AR (or AR/IR) coating, you need to be careful when cleaning. This coating can scratch easily so you should not use excessive force when cleaning dust from its surface."
I stumbled over this cleaning advice from ARRI:
https://www.arri.com/resource/blob/178182/b88ad5646a684fe3a356fd3223b546f9/arri-camera-sensor-cover-glass-cleaning-instructions-data.pdf
ARRI builts many parts of the sensors themselves so the cover glass
is from them. Their film cameras are famed for their durability -
some of them are for rental only.
So many camera assistants who put their hands on them.
Panavision is another company. They give no cleaning instructions
but sell Vdust sensor plus.
Back to ARRI, quote from their wet cleaning procedure:
"2.2Wet Cleaning
Wet cleaning is recommended to remove grease or sticky dirt that cannot be removed by contact-free cleaning.
Prepare three different liquids in spray or drop dispensing bottles:
1.a neutral window detergent
2.deionized distilled water
3.spectroscopy grade isopropyl alcohol.
Always use these liquids in this sequence when cleaning
Instructions
1.Use “Texwipe Absorbond® Swab TX762 with Long Handle”
2.Always store swabs inside original bag.
Remove one by one for use.
Store swab bag in a dust-protected environment.
3.Pour cleaning liquid into separate container.
Never apply liquid to swab directly from storage container.
4.Apply cleaning liquid to swab.
5.Use swab with gentle touch. Never apply pressure."
Assuming that ARRI sensors are cleaned very often (Dune, anyone?)
and assuming their coating is magnesium fluoride as well, water should
be of no harm.
But these are only guesses. Maybe someone can shed a light
what upper AR/IR coating is applied on the Exmor410 and if I am correct with
magnesium fluoride.
Maybe this article helps:
https://www.photonics.com/Articles/Common_Infrared_Optical_Materials_and_Coatings_A/a25495
Best, Herbert GH_2
