HDR in IOS camera app
Started 11 months ago | Discussions
Howard Junior Member • Posts: 38
Can the range of exposures taken in the hdr setting of the camera app be adjusted? It seems to be too mild in my experience.
JT26 Veteran Member • Posts: 4,788
Re: HDR in IOS camera app
As in increase the HDR effect? No afraid not.
A tip would be to focus on the brightest part of the image, which will force the camera to expose for that and it'll be default try and protect the shadows too.
Franz Weber
Franz Weber Contributing Member • Posts: 644
This is only a problem on non HDR monitors.
Once you view your HDR photos on HDR devices such as the new MiniLED iPad Pro 12.9 you will notice, that the HDR redering from Apples latest iPhones is absolutely stunning.
This column is intended for something inspiring, something meaningful or at least something that makes any sense at all. I‘ll work on it.
 Franz Weber's gear list:Franz Weber's gear list
Olympus OM-D E-M10 IV Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-45mm F4 Pro Apple iPhone 13 Pro +2 more
