Is 300mm (on Apsc) good for wildlife photography?
Started Sep 11, 2021 | Questions
Borteese New Member • Posts: 6
I'm trying to decide between a few lenses and I'm just wondering if 300mm is a good focal length for what I'm trying to do, or if I absolutely NEED a longer lens than that.
WongRQ Contributing Member • Posts: 882
Re: Is 300mm (on Apsc) good for wildlife photography?
6
It depends on the type of wildlife photography you’re doing.
If it’s bird photography it’s definitely not enough. Many say to use 400mm on an APS-C body for bird photography.
If you’re shooting things that are larger and a little closer than birds, like elephants and rhinos, then it maybe it might be enough, but even then many shoot with a 70-200mm, and a 1.4X teleconverter. The ability to zoom is especially useful when you’re in the car.
I shoot bird photos and I use a SIGMA 150-600mm f/5-6.3 DG OS HSM Contemporary on an EOS 7D and it works well.
 WongRQ's gear list:WongRQ's gear list
Canon EOS 7D Canon EOS 600D Canon EF-S 18-135mm F3.5-5.6 IS Sigma 150-600mm F5-6.3 | C
neilt3
neilt3 Veteran Member • Posts: 3,011
You need to give us a clue what sort of wildlife your after photographing .
If it's little birds , it's not very good .
If it's a big bird like an ostrich , not a bad choice .
Elephants it'll work with and for beetles a 100 mm macro lens would be better .
Or if it's small wildlife then the Canon 1-5x macro lens would be better suited .
Care to be a bit more specific about your requirements before any more suggestions are made ?
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Abbott Schindler Veteran Member • Posts: 3,111
Very important: are you in a blind? The real questions are how close you are to what size critters and how fast are they moving…
OP Borteese New Member • Posts: 6
I'm planning to photograph more average in size animals, comparable to sizes near cheetahs.
neilt3
Borteese wrote:w
Comparable in size to a cheetah , or an actual cheetah ?
(Are you going to greyhound racing ?)
In the wild or a safari park or zoo ?
In the wild on foot , you'll be quite a distance away from large carnivores .
On a jeep with a guide on such as an African safari , you'll be much closer .
At a zoo , you'll be closer still .
If your in a safari park , where you drive through the enclosure , they might be jumping on top of your car , and a wide angle lens would be needed !
If you want help or advice you need to state what your doing , what your photographing , and how far away from it you are expecting to be .
Being as cryptic as possible just means people have to guess what you may or may not need , and end up suggesting unsuitable gear .
As it is I would suggest a selection of lenses ranging between an 8mm fisheye lens to a 600mm lens , and probably a 2x teleconverter , depending if your shooting on a full frame or crop sensor camera .
Although that range could be narrowed down a bit if you give us some information .
John Crowe
John Crowe Veteran Member • Posts: 3,476
Without getting into details, 300mm is a good start.  Better to add a 1.4x, or go to a 400mm.  I don't do much wildlife so I make do with a 300/2.8 and 2x on a 50 MP full frame camera.
In a rush I shot a fairly distant moose with just a 300/4 and 21 MP full frame.  Cropping down to about 20% of image area still yielded sharp eyes.
Using an easily handholdable prime lens with teleconverters does provide flexibility and still very good image quality.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
Fsi Senior Member • Posts: 1,276
I use a 200mm on m43. works out to 400mm equivalent. It's perfect for me.
If I had apsc, I'd be using a 300mm lens, or 400mm on ff. I usually find a spot and wait, birds get so close, They often get too close, as they don't see me as a threat.
 Fsi's gear list:Fsi's gear list
Sony a1 Olympus 25mm F1.2 Panasonic Leica 200mm F2.8 Sigma 85mm F1.4 DG GN Canon G5 X II +4 more
TeeJay626 Contributing Member • Posts: 569
I shoot APS-C (for now) and have owned both the 70-300 IS USM II and the 300L f4 IS.
I primarily shoot wildlife and they have been adequate in most situations.  I visit Yellowstone and Grand Teton often and yes, a longer lens there is preferred.  I've since upgraded to the 100-400L IS II (amazing lens!).
But in regards to your question, either lens I mentioned will work well with an APS-C body.
Here's a couple of shots with both.
60D and 300L f4 IS
77D and 70-300 IS USM II
 TeeJay626's gear list:TeeJay626's gear list
Sony Cyber-shot DSC-H55 Canon EOS R7 Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 55-250mm f/4-5.6 IS STM Canon RF 100-500mm F4.5-7.1L IS USM +3 more
Dave
Dave Veteran Member • Posts: 6,231
When you can get close (safely) and when animals cooperate.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
