FTZ adapter firmware update broke autofocus on 18-35mm D?
Started 8 months ago | Questions
j_photo Veteran Member • Posts: 5,833
Re: FTZ adapter firmware update broke autofocus on 18-35mm D?
I wonder what the OP is thinking about all this!?
 j_photo's gear list:j_photo's gear list
Nikon Df Nikon Z7 Nikon Z6 II
BasilG Veteran Member • Posts: 9,600
Probably watching the show in disbelief (the original question has been answered though).
mobydick Contributing Member • Posts: 618
Have I missed anything?
Not a lot: AF-P lenses also exist with E-type aperture (e.g. the 70-300 FX zoom).
Yes, thank you, I have corrected it my previous posting.
Wolfram
 mobydick's gear list:mobydick's gear list
Nikon D7500 Sony RX100 III Sony Alpha DSLR-A850 Nikon Z7 Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +34 more
Come to think of it, the Z 58 f/0.95 doesn't  autofocus at all, but surely it also communicates distance info to the camera.  As you say, D functionality is not about focus control.
You are right, but these old designations like D,G,E,etc. may be obsolete now in the Z mount...
Wolfram
There are also the perspective control (PC) lenses that are D and E-type manual focus lenses. But that's only of peripheral interest here.
wildblanket Regular Member • Posts: 264
BasilG wrote:
Cryhavoc38 wrote:
I was referring to AF-D lenses not f/4 D lenses.
If there are AF-D lenses that have internal motors, I guess I have come across any yet.
I guess I assumed the op was talking about an AF-D lens. My bad.
What you have discovered is that the AF-D nomenclature is misleading. The 300/4 D is just as much a D lens as all the other D lenses, and there is more than a dozen D lenses that do have internal AF motors. The relevant categories are AF, AF-I, AF-S, AF-P, not "D or not D".
Is there a list of the D designation lenses with internal motors somewhere ?
Anyway the original posters' lens does not appear to be one of them, does it ?
 wildblanket's gear list:wildblanket's gear list
Nikon D850 Nikon Z5 Leica D-Lux (Typ 109) Nikon D810 Nikon D800 +5 more
Cryhavoc38 Contributing Member • Posts: 582
Hi, can you post a picture or nikon web link for your exact lens please?
Thank you
(unknown member) Forum Pro • Posts: 15,443
G lenses with screw-driven AF
mobydick wrote:
Does anyone know a G lens which still has screw-driven AF?
AF 28-80 f/3.3-5.6 G
AF 28-100 f/3.5-5.6 G
AF 28-200 f/3.5-5.6 G IF-ED
AF 70-300 f/4-5.6 G
AF 10.5 f/2.8 G ED DX
Patco
A photograph is more than a bunch of pixels.
Stan Disbrow Veteran Member • Posts: 6,090
Hi,
And a couple AI-S manual focus lenses with the D chip in them. But they are labelled AI-P rather than AI-S....D. I think they were trying to avoid more D confusion.
Stan
Amateur Photographer
Professional Electronics Development Engineer
Once you start down the DSLR path, forever will it dominate your destiny! Consume
your bank account, it will! Like mine, it did!
 Stan Disbrow's gear list:Stan Disbrow's gear list
Nikon D1H Kodak DCS760 Nikon Df Kodak DCS520 Pentax 645D +21 more
Stan Disbrow wrote:
Hi,
Stan
Indeed, Ai-P is a thing, but hopefully, nobody expects AF from those.
If it says AF-S or AF-I on them, they have a motor.
No. It isn't, meaning this lens never focused on that camera, even before the firmware update.
AF-S 300/4 D IF-ED
AF-I 300/2.8 D IF-ED
AF-S 300/2.8 D IF-ED
AF-S 400/2.8 D IF-ED
AF-I 500/4 D IF-ED
AF-S 500/4 D IF-ED
AF-I 600/4 D IF-ED
AF-S 600/4 D IF-ED
AF-S 17-35/2.8 D IF-ED
AF-S 28-70/2.8 D IF-ED
AF-S 80-200/2.8 D IF-ED
Compiled from info at: http://www.photosynthesis.co.nz/nikon/serialno.html
Patco
Hi,
Hey! Now that you mention it....My AI-P 500/4 doesn't auto focus!
I never did get the AI-P variant of the 45/2.8 although I did think about it a few times. I have the original GN version and went back to using it on the Df. That's a Pre AI lens and so needs the flip up AI tab on the Df. Ought to work on a Z though.
And now that brings up more Nikon Alphabet Soup. Pre-AI isn't an official designation. The GN is a Type-K rather than a Type-A... But maybe we should leave the remaining Alphabet Soup alone....
And, for those unfamiliar, the GN means Guide Number. It's a special design for use with flash bulbs and early electronic strobes. It has a Guide Number ring that you set for your flash. It then couples the focusing and aperture rings. As you focus closer, the aperture stops down. And it opens up as you focus further away. Works amazingly well.
Nikon revisited the lens minus the GN for the FM3a and added the distance chip and encoder strip making it an AI-P lens.
Stan
mrbr Veteran Member • Posts: 3,752
Hi,
From OP's gear list , it is this lens ( without internal focus motor ! ) : Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Specs: Digital Photography Review (dpreview.com)
There is another 18-35 mm lens with internal focus motor : Nikon AF-S Nikkor 18-35mm f/3.5-4.5G ED Specs: Digital Photography Review (dpreview.com)
If OP is correct that his lens did autofocus before the firmware update of the FT adapter , it is the AF-S 18-35 mm lens.
Greetings,
Marc
 mrbr's gear list:mrbr's gear list
Nikon D7200 Nikon Z6 Nikon AP-F 70-300mm F4.5-5.6E Nikon 10-20mm F4.5-5.6 VR Nikon Z 24-70mm F4 +8 more
ofquiet
OP ofquiet New Member • Posts: 18
Thank you
Sure thing, this is the lens: https://www.dpreview.com/products/nikon/lenses/nikon_18-35_3p5-4p5d
 ofquiet's gear list:ofquiet's gear list
Olympus Tough TG-4 Panasonic LX10 Panasonic Lumix DMC-GM1 Canon EOS 6D Fujifilm X-E3 +16 more
ofquiet
Re: AF-D
I like Lenses wrote:
Since the AF-D discussion has started again, here is a useful resource:
http://www.photosynthesis.co.nz/nikon/lenstype.html
  • AF - Auto focus (1986)
  • Lens focused by motor in camera, 5 CPU contacts on lens mount.
  • D lens (1992) - Transmits focus Distance for improved flash metering.
  • AF-I (1992) - Telephoto with Integrated AF motor, 10 CPU contacts, manual override of AF.
  • AF-S (1996) - Similar to AF-I with improved Silent Wave motor.
Ha, oops. Didn't realize I was stirring up some well-trod territory! Thanks for the resource.
ofquiet
He's thinking that he got the specs mixed up with a newer version of this lens when he thought he was buying one that would autofocus with the FTZ. Now how my initial tests with it led me to believe that the autofocus was working (pre-update)... 🤷.
Re: G lenses with screw-driven AF
AF 70-300 f/4-5.6 G
Interesting. I was not aware of any of them, most likely because  I entered the Nikon world not before 2006 (with a D80 at that time). Reading quickly some reviews of the first four lenses in the list, they don't seem to be Nikon's best performers...
Wolfram
Yes, this is funny. Maybe the large depth of field at 18 mm helped to get the impression that the AF worked as expected...
Wolfram
