Replacing my Epson R2800 printer
Sellwood Regular Member • Posts: 176
It's been faithful for several years, but I now need a wireless printer. What do you like for a 13x19 printer. I print 15-20 prints a month. Mostly Landscapes
 Sellwood's gear list:Sellwood's gear list
Fujifilm X-T3 Canon EOS 90D Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 +1 more
Distinctly Average Senior Member • Posts: 1,209
Re: Replacing my Epson R2800 printer
Probably the wrong part of the forum to ask but hey ho.
I’ve worked with many printers over the years. All have improved greatly from the dark early days when you would switch your printer off for a few days only to find the head clogged or the smallest bit of paper dust causing jams on the pick-up roller. Most brands do some very good kit now. Personally I have a soft spot for the Canon pro series like the 100S, 200, 300 etc. work very well with superb print quality.
Norm Neely Veteran Member • Posts: 3,013
I was thinking about purchasing one of the Canon Pro pigment based printers.
A poster recommended the less expensive Dye-Based for my needs.
https://www.bhphotovideo.com/c/product/1602503-REG/canon_4280c002_pixma_pro_200.html/specs
Haven't purchased yet but will later.
Check out the list of Canon printers at B&H Photo. You can get the specs and user reviews for each of them. Might help in your decision making.
Canon 13x19 Printers | B&H Photo Video (bhphotovideo.com)
A Pigment printer is expensive but might be worth considering for landscapes.
Norm
 Norm Neely's gear list:Norm Neely's gear list
Nikon Coolpix 995 Olympus SP-550 UZ Canon EOS 40D Canon EOS 7D Mark II Canon EOS 5DS R +1 more
Ken53 Senior Member • Posts: 2,179
If you hadn't yet, you might want to spend some time listening to this guy.
https://www.youtube.com/user/cheo1949/videos
 Ken53's gear list:Ken53's gear list
Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot SX60 HS Canon EOS 70D Canon EOS 7D Mark II +13 more
I mentioned in an earlier thread to consider a canon pigment ink printer.
Before you do watch this link. Very important.
https://www.youtube.com/watch?v=Q5by2Prg864
One of the videos in the link Ken53 gave.
That is why a dye based printer was recommended to me instead a pigment printer.
I don't print enough to use a pigment printer. 15-20 prints a month I might get one?
The printer you see in the video is.
Canon imagePROGRAF PRO-1000 17"
Canon imagePROGRAF PRO-1000 17" Professional 0608C002 B&H Photo (bhphotovideo.com)
Canon image PROGRAF PRO-300 13"
https://www.bhphotovideo.com/c/product/1573781-REG/canon_imageprograf_pro_300_13_professional.html/specs
Both the same a far as pigment ink and cleanings cycles to keep heads from clogging.
Norm
Not sure why that video was so important to watch. We all know the cost per page is high with any home printer.
I worked in the industry for a long time, on many brands of printer. They all suffer from the same issues. Epson had fixed print heads which means that when they clog either the printer ends up in landfill or you were lucky and could clear it but at the cost of lots of waste ink. I know one of our workshops managed to come up with a method 0f cleaning them but it was not something a home user could do. At the time, other brands had heads as consumables or they were part of the cartridge. This made carts more expensive but if one clogged it was simple to replace.
Things have changed, the tech evolved and now heads are less prone to clog, waste  is lower etc. However, cost per print is still high.
This bings me on to thirds party inks and even toner for laser printers. For some it is OK. However it also can lead to problems. First toner. We would see many issues with colour accuracy often leading to complaints. Works was destruction of fuser units due to the toner not bonding to the paper so well/ that could get expensive very fast as well as producing poor print quality, jams and prints that you could very quickly rub off the paper.
Inkjet third party inks have problems too. Colour accuracy is often off, particularly in cyan for some reason and especially so when used it archival papers. With some third party inks heads are more prone to clogging with low use printers. In many cases they fade after a short time too so customers complain.
So when buying a printer you do have to consider the use of third party inks carefully. If you are selling prints as a business then OEM is probably the best option. If you are printing photos as a hobby and want to keep them for display, then OEM is also probably best. If you are printing off lots of leaflets or more disposable types of prints then third party inks are fine, but for that kind of work you would not be using this type of printer. For general stuff at home I have a cheap A4 printer loaded with third party ink as it is just there for the family to abuse.
So yes, you should carefully consider what you buy. There is nothing in that video that most people don’t know already. Cost per print is always going to be high at home. What you have to realise when buying is it is measured in a specific way that you will almost never meet. General printers are often based on 5% coverage while photo printers use a specific test chart. What is printed in real life will almost certainly not match that or even be close. You simply have to live with the shortcomings. For many home users they are better off using the likes of Costco for printing g as they do prints at considerably lower cost than you can do at home with quite decent quality. When you want a higher level of control and to use specific papers the you use your home machine of a good quality print shop.
It was very important to me that Sellwood watch the video.
Quote from my first reply to Sellwood
"A Pigment printer is expensive but might be worth considering for landscapes."
Whenever I recommend or tell someone to consider a product. If I come across information that might be a negative, I feel obligated to pass that on.
Even though I think 15-20 prints a month would be fine.
That's a decision Sellwood needs to make not me.
The reply to Sellwood was a heads up.
I don't know if Sellwood knows or not.
Ps.
Been going over my reply, If I had said.
Before you decide to purchase, watch this link. Very important.
Instead of:
Your thoughts please.
Norm
Fred Colon Forum Member • Posts: 97
If your only issue is that you need a wireless printer then why not look into getting a Wifi Printer Adapter/Server.
https://www.amazon.co.uk/LOYALTY-SECU-Wireless-Server-Adapter-Printer/dp/B094NVJP8Q/ref=sr_1_3?dchild=1&keywords=wireless+usb+printer+adapter&qid=1631001372&sr=8-3
 Fred Colon's gear list:Fred Colon's gear list
Given that Selwood has been using a printer for some time they would know how much it costs.
Ps.
Instead of:
Ps.
Instead of:
Been re-reading my replies and yours.
I had been looking for a printer, received good info from another member.
I hastily decided to pass it on, in this thread.
I see now that was a mistake on my part.
Thanks to your replies. No more hasty replies that wind up being redundant info.
Promise! I'll give more thought before posting future replies.
Especially on a topic I know nothing about.
I'm planning on upgrading my color laser.
I really know nothing about ink jets, yet I replied. Duh. I deserve a thumbs down on all my replies.
Thanks Again, Even though I now feel like a dork
Norm
Ps.
Instead of:
I wasn’t trying to be offensive Norm. The premise of the video was IMO flawed, not your response.
As for your laser, they can be a bit of a nightmare too.
Thank You for that specific link Norm. I have been using the discontinued Pro 100 for a few years now. I knew it was incredibly wastfull with the ink consumption. I had not seen the video you linked to. It is an eye opener.
I know this thread has been started in a less then an ideal forum but maybe it will help some that don't view the printer forum.
Thanks again.
Ken
Thanks again.
Ken
How wasteful any printer is does depend on how you use it. Lots of things can have an effect depending on the design. For instance, some printers people leave switched on all the time. This obviously wastes a small amount of electricity. Some models will do little refresh cycles while on standby which uses ink too. Other models will do a clean cycle whenever you switch them on also using ink. It is not consistent between brands or models from the same brand. There was one model in the ast that if just switched on daily but never actually used would eat a full set of cartridges in just over two months. That lead to a lot of complaints.
RedFox88 Forum Pro • Posts: 30,544
dpreview.com/forums/1003
