EF-M to EF adapter on EOS M6 ii loose. 70-200 can fall off. What can I do?
Started Sep 1, 2021 | Questions
Helgaiden New Member • Posts: 5
So a while ago I got an M6 ii. I own a Sigma 18-35 F1.8, was using with a Viltrox EF-M2 speedbooster on my Panasonic cameras, but I was over the crappy autofocus of those cameras, so switched to Canon body to keep using this lens too. Researched the EF-M to EF adapters and settled on the Fotodiox supposedly basically being as good as the official Canon adapter for ALOT less money. The Villtrox EF to M43 Speedbooster on the panasonic...ROCK SOLID. Never loose, never worried. But this Fotodiox adapter on my m6 ii? A tad loose at first. Went to help a friend shoot a wedding as a B-cam guy and slapped his 70-200 on this sucker and it worked great, but I felt the adapter become looser. Eventually, if the lens wiggled just right, the lens + adapter together would fall off the EF-M mount. Like it would rotate like the button was pressed and come off, catching itself on another lip in the mount. Walking with the camera on the tripod then setting it down would cause enough vibration to make this happen, even missed a good shot because the lens + adapter fell off right as I put the tripod down. Not sure what to do and I'm not sure if I should throw money at another adapter, like the Viltrox EF-M to EF adapter.
What do you guys think? Thanks in advance. Clips showing the looseness linked below:
With lens: https://www.youtube.com/watch?v=GhvH0PK52_w
W/O lens: https://www.youtube.com/watch?v=p1Fi3zm_yTY
Canon EOS M50 (EOS Kiss M) Canon EOS M50 II Canon EOS M6 Canon EOS M6 II Sigma 18-35mm F1.8 DC HSM Art
(unknown member) Regular Member • Posts: 201
Re: EF-M to EF adapter on EOS M6 ii loose. 70-200 can fall off. What can I do?
I do not have the M6 MII, But I do have the M6 with the Fotodiox. I've never heard or have had any issues with my adapter. In fact I have three of them on each lens. This sounds to be a serious enough to warrant contacting fotodiox.
thunder storm Forum Pro • Posts: 10,139
I have a Viltrox which works fine. However, I also have the Canon OEM adapter. I bought the Canon OEM adapter for heavy lenses like the sigma f/1.8 zoom, just to be sure.  The Canon adapter is also the best for avoiding flair issues.
If you're attaching the combo to a tripod, attach it to the adapter or the lens, NOT the camera. The M cameras aren't designed to be mounted on tripods with heavy adapted lenses.
Look, I'm not a guy who's always buying OEM stuff. Third party options can save a lot of money. But in this case I would go with the Canon adapter. The Viltrox is fine for the 50 f/1.8 stm or the 24 f/2.8 stm or even the 15-85mm f/3.5-5.6 IS USM.
For anything heavier and also front heavier I would get the OEM adapter.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
TS Your comment is relative and I was going to mention the heavier lens aspect. But I've been getting away with using the fotodiox pro adapt with the 100mm f/2 USM without issues. granted it's not the 200mm the op mentioned but heavy non the less.
OP Helgaiden New Member • Posts: 5
Huh interesting. The price of the Canon adapter is nearly unjustifable, I would hope it isn't the fix. Though I see some on ebay for around $110 so maybe. I did have the camera mounted to the tripod directly instead of via the thread on the adapter itself, and I agree this didn't seem to help, but the Smallrig cage I have on the camera blocked me from mounting to the thread on the adapter. I had to remove it. I'll see if i can maybe modify the thing to fit with the cage on still, hopefully. I'm going to contact Fotodiox support and see what they say as well, I didn't think of that. I may also end up trying the Viltrox adapter since its cheap enough at least but we'll see. Thanks for the feedback.
m100
m100 Senior Member • Posts: 2,048
This is a good place.
https://www.mpb.com/en-us/used-equipment/used-photo-and-video/used-lenses/used-canon-fit-lenses/canon-ef-eos-m-mount-adapter/
" It's a virus that hitches a ride on our love and our trust for other people. "
Dr. Celine Gounder
 m100's gear list:m100's gear list
Canon EOS M6 II
Max5150 Senior Member • Posts: 1,045
I've used a Viltrox adapter to mount an EF-100-400 on my M6 mkii without concern. Just make sure you hold the rig by the lens, not the camera.
Jeff Peterman
Jeff Peterman Forum Pro • Posts: 13,585
First, it sounds like you have a bad adapter. Second, any time you have a lens that is bigger/heavier than the body - even if that body is a 5D without any adapters - it is always best to support the combination by the lens. Think of a big lens with body as a lens with body attached, not a body with lens attached. When I shoot with my 70-200 on a DSLR, I always support the weight with my left hand under the lens. If I walk around with that combination hanging from a strap, I always have one hand on the lens. I would do the same with my M6 and anything bigger/heavier than the EF-M lenses.
BUT, you still need to replace your defective adapter.
Jeff Peterman, Moderator 7D and Phone/Tablet forums.
Not a staff member, or paid employee, of DPReview.
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
www.pbase.com/jeffp25
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +19 more
If budget is tight, get the Viltrox. It works fine in my experience.  I couldn't justify taking a risk mounting heavy and expensive lenses on a third party adapter. YMMV.
dan the man p Senior Member • Posts: 1,201
I somehow managed to get the OEM adapter for less than $40 on eBay several years back. Since those kinds of prices don't seem to be available anymore, I'd probably go for one of the excellent condition ones on mpb if I were doing it again. Seems worth it for just $30-$40 more than the third party models, and mpb has a great reputation.
 dan the man p's gear list:dan the man p's gear list
Sony DSC-RX0 Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 40mm F2
Oh nice! Thanks for the suggestion on this site, I will likely order a Canon one from here to use as the main adapter then. I contacted Fotodiox and they opened a support ticket for me to send them the adapter to fix, so then I could keep that one as a backup or use it with a smaller lens. Appreciate all the help everybody.
Jeff Peterman
Re: EF-M to EF adapters
To me, the price of the Canon adapter doesn't make any sense - they charge that much because they can. I both one from Commlite for $40 (at Amazon) and it works perfectly well - even with a 70-200 f2.8L IS lens (supported via the lens).
Jeff Peterman
I have bought used 22mm and 18-150mm EF-M lenses from, both in excellent condition for a great price - I have also sold them a bunch of old gear that was just sitting around for many years (the 18-150 was technically a trade, getting money back and the lens).
I recommend checking them out - you can even request something they don't have in stock and get notified when they have one (I did that with the 22mm).
Very nice lens by the way.  Works like a charm on the M6II.  The 32Mp is better served with this zoom than those tiny ef-m zoom lenses.    And the lens is best served by the sensor of the M6II.
Sittatunga Veteran Member • Posts: 5,406
It makes sense to me. Mine's over five years old and apart from a bit of paint at the bottom edges of the tripod socket, as good as new. Cheap substitutes become expensive if they don't last. Remember Ruskin's thought; “There is hardly anything in the world that someone cannot make a little worse and sell a little cheaper, and the people who consider price alone are that person’s lawful prey. It’s unwise to pay too much, but it’s worse to pay too little. When you pay too much, you lose a little money — that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot — it can’t be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better.”
Yeah I love this lens, thats why I stuck with a body that would let me use the lens still lol.
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
Canon Lens Adapter (PICS)
The Original EOS M body shipped with the Lens Adatper in the box - in an attempt by Canon to sell the EOS M as a "backup camera" for professional DSLR shooters.  You can see it on the side of the box in this image from 2012.
You asked "what can (you) do" and there's literally but one answer: Get your hands on a genuine Canon lens adapter.  There's simply no alternative...
The Viltrox adapters & devices are well known to be horridly loose-fitting. I had a Viltrox tele-tube (not the Lens Adapter) detach with an EF 100mm Macro lens attached to it when I was shooting Macro images with an indoor lighting setup ... almost ruining the lens when it struck the glass table. I was picking the camera up and it literally fell off, even though I'd locked it into place. It was as though I'd pressed the lens-release button. I will not use their products any more. The worst offenders are their EF-to-EF-M adapters. There's plenty of stories about them online producing loosely fitting lenses with poor electrical contacts and a penchant for detaching with larger lenses. You can see just some of the lenses I've adapted to my EOS M + EOS M6 cameras directly below. The snug fit is important.
EOS M6 + Canon adapter + EF 100-400mmL II lens
EOS M + Canon Adapter + EF 24mm f/1.4L II USM lens
EOS M + Canon Adapter + EF 50mm f/1.2L USM lens
EOS M + Canon Adapter + EF 100mm f/2.8L USM lens
EOS M6 + Canon Adapter + EF 85mm f/1.2L II USM lens
EOS M6 + Canon Adapter + EF 100-400mmL II lens (with other accessories).
EOS M6 + Canon Adapter + EF 2x III Extender + EF 100-400mmL II lens.
EOS M6 + Canon Adapter + EF 1.4x III Extender + T-Ring + Celestron Mak90 Spotting Scope
Toss these Viltrox parts into the trash and replace them with a genuine Canon lens adapter. The difference will be night-and-day by comparison. I still use the original Canon adapter that came with my EOS M body (Canon used to supply it in the box back in 2012) and here we are 9 years later and it's on my EOS M6 when needed. It's still tight to get it to connect to the camera EF-M lens mount. These Canon adapters are built tough and will prevent the type of movement shown in your video.
There are TWO versions of the Canon Lens Adapter... one has the "foot" included. This can be VERY handy when mounting larger lenses that have no lens ring with their own foot. The other has no "foot" included. The foot is removable (see image below for reference).  And even if you remove the foot to enable various lenses to be fitted without interference, there's yet another tripod-mount on the underside that the "foot" screws into.  I've found the foot useful for mounting a Manfrotto mini-tripod to (see below).  Because larger lenses can sometimes prove tricky to carry.  So with the lens foot attached to the Adapter, there's very litter pressure on the camera mount ring and the lens itself is snugly attached... thus relieving any pressure from the camera mount.  I can walk kilometers holding the rig (below) without much stress on my hand or camera mount.  Both the EOS M and the EOS M6 can be seen below with my favorite EF lens combo on the Lens Adapter...
Making use of the Lens Foot that came with my Lens Adapter... by fitting a mini Manfrotto foldup "tripod" solely for the purpose of carrying the camera more securely.
Accessing the M6 battery with the Mini Tripod attached to the Adapter's lens foot.
Top View of the above array.
Stable on a table 1
Stable on a table 2
Canon EF-to-EF-M Lens Adapter with "foot" attached. Canon appear to supply two versions... one with and one without the lens "foot". It is made from metal and has a tripod mounting socket attached.
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: Canon Lens Adapter (PICS)
As usual - excellent advice and photographs.
Stable on a table 1
Stable on a table 2
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
Jeff Peterman
Interesting little "tripod" - just ordered one for $30 from Amazon.
Stable on a table 1
Stable on a table 2
Your experience with Viltrox parts you actually have firsthand experience with is quite the opposite of mine. The Viltrox EF to M43 speedbooster I use on my panasonic is rock solid, and other people, who actually owned the Viltrox EF-to-EFM adapter, here (as well as reddit where I posted this question as well) have thrown their support behind the Viltrox adapter.
I've found at least a contributing cause to the issue I had with my Fotodiox though. The screws in the back of the mount (like the bottom picture in the quoted post) were loose. I tightened them back down and its good again. I may redo the tightening of those screws by adding blue loctite to keep them from backing back out, we'll see.
With all that being said, a previous poster suggested looking at mpb.com and ordering an official canon adapter from there, which I did. I'll keep the Fotodiox for a second lens or as a backup. Am really going to have to try figure out how to get the foot back on the lens for larger lenses though. I couldn't use it with the adapter because it interefered with the smallrig cage I have on the m6 ii.
Really wish Canon still sold the M series cameras with the adapter in there like you showed at the top of your post! That would be great. Considering the overall lack of support the EOS-M mount has gotten, it would have been smart to at least start doing that again once the M50 hit and the M series got popular again.
