Fast lenses for night action shots
Started Aug 31, 2021 | Discussions
sifro Forum Member • Posts: 52
Hi everyone, this is my first post here!
I would like to buy a new lens to take pictures of people dancing at local dancing events, so I will have to shoot moving subjects in low-light conditions, from quite a close distance.
I currently have an X-E4 camera with an XF27mm 2.8 which forces me to use incredibly high ISO and slow shutter speed.
I'm not 100% sure if I need autofocus, but for sure it would be nice feature to have (but only if it's super fast, otherwise I wouldn't use it anyway for this specific use case).
These are the lenses I was looking at:
Fuji XF 56mm f/1.2 - looks perfect, but I'm not ready to spend 1000€ on a lens at the moment;
Fuji XF 50m f/2.0 - everybody praises its quality and I love Fuji prime lenses, but i'm not sure it would be enough of an improvement from my XF 27mm f/2.8 in terms of light I can get in;
Viltrox 56mm f/1.4 - this is the one i'm currently thinking about buying. It seems to me that for 1/3 of the price, it doesn't lose too much compared to the Fuji XF 56mm;
Samyang 50mm f/1.2 - no autofocus (which I still don't know if it's a big minus or not), also the image quality I saw from a few reviews in Youtube didn't really convince me, but I read great things about this on the forum.
What do you guys think?
Thank you!
PS: also, as I don't have a portrait lens, I would also like to use whatever I'm going to buy as a portrait lens too.
Fujifilm 50mm F2 R WR Fujifilm XF 56mm F1.2 R APD Samyang 50mm F1.2
Erik Baumgartner Senior Member • Posts: 6,893
Re: Fast lenses for night action shots
Thank you!
Please post an example of "people dancing at local dancing events", that could mean a lot of different things. Very fast lenses typically come with a very shallow working depth of field which could certainly cause problems if your subject(s) are at close range and/or aren't always on the same plane. The larger the aperture/longer the focal length, the shallower the DOF, f/2.8 may indeed be the best aperture for the job and you will indeed need a very high ISO to maintain a shutter speed high enough to freeze the action.
I would be inclined to think the 50-140 f/2.8 would be the lens for the job, but it ain't cheap. Of your lens choices above, any could work, but I think the Fuji 50 f/2 or Viltox 56 would be the best choices if they are the correct focal length.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
michaeladawson Forum Pro • Posts: 18,315
You say you are using “incredibly high ISO” and slow shutter speed with your f/2.8 lens.  Depending on exactly what you mean, a faster lens is not going to help you all that much.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Welcome to the Fuji x forum!
I can recommend the manual KamLan 50mm F1.1 Mark II x-mount lens if you can find one.  At the moment, Adorama has some in stock for $250.
At F2 and above it is the equal of the Fuji 50mm F2 WR and of course you get F1.1. Bokeh is great.  Beware, it weighs 563 grams (about 1.24 lb) and uses 62mm filters.
Here is a small set of samples:
https://www.dpreview.com/galleries/1438043515/albums/kamlan-50mm-f1-1-ii
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
OP sifro Forum Member • Posts: 52
This for example: https://www.youtube.com/watch?v=ounrVadrqDw
So yes, indeed I didn't take into account that at large apertures, the DOF might be too shallow to get a couple with both members in focus in one photo.
What do you think?
Thank you for your reply!
Well, for example last time I found myself to choose between 1/160 and ISO 25600 or 1/125 and iso 10000 (or 1/60 and ISO 8000 but I won't even comment the results of this combo).
I would like to be able to shoot a bit faster than 1/160 and ISO not higher than 10000.
Wow, this looks so interesting! I definitely need to read and see more about it, thanks!
stoke1863 Regular Member • Posts: 158
I know you dont want to spend too much, but look at second hand XH1 or XS10 for IBIS, this will mean you can get your shutter speed much lower for more light.
I just got a second hand XH1 myself for £425.
Viltrox 23, 33, 56 would be good choices for a budget
nonicks Senior Member • Posts: 1,188
Sounds like those are VERY low light situations.
Yeah you absolutely need a fast lens and 2.8 won’t cut it for sure. Even f/2 is insufficient.
Out of the listed options, I would say the Viltrox may be the better choice.
 nonicks's gear list:nonicks's gear list
Leica Q2 Leica M10-R Leica Summicron-M 35mm f/2 ASPH Leica Summilux-M 50mm f/1.4 ASPH
DocetLector Contributing Member • Posts: 934
8
How does IBIS help for fast moving people?
 DocetLector's gear list:DocetLector's gear list
Canon G1 X II Canon EOS M6 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM +5 more
biza43 Forum Pro • Posts: 15,074
With those focal lengths I think you will have difficulties in shooting from close distances and frame the entirety of your subjects.
Probably a 23 f/1.4 or even the 16 f/1.4 are more adequate.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
What do you think?
Are you shooting stills or video?  If stills, an example with your 27 would be helpful (with the exif data) so we can know what the actual light levels are like. What SS/ISOs are you shooting at now? Looks like a potentially challenging proposition, a slow SS definitely isn’t going to cut it.
What do you think?
ExifTool Version Number : 11.88
File Name : DSCF9145.JPG
Directory : .
File Size : 6.4 MB
File Modification Date/Time : 2021:09:01 12:16:41+02:00
File Access Date/Time : 2021:09:01 12:16:49+02:00
File Inode Change Date/Time : 2021:09:01 12:16:41+02:00
File Permissions : rw-rw-r--
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : FUJIFILM
Camera Model Name : X-E4
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : Digital Camera X-E4 Ver1.00
Modify Date : 2021:08:14 22:30:18
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/160
F Number : 2.8
Exposure Program : Manual
ISO : 12800
Sensitivity Type : Standard Output Sensitivity
Exif Version : 0232
Date/Time Original : 2021:08:14 22:30:18
Create Date : 2021:08:14 22:30:18
Components Configuration : Y, Cb, Cr, -
Compressed Bits Per Pixel : 4.8
Shutter Speed Value : 1/161
Aperture Value : 2.8
Brightness Value : -2.93
Exposure Compensation : 0
Max Aperture Value : 2.8
Metering Mode : Multi-segment
Light Source : Unknown
Flash : No Flash
Focal Length : 27.0 mm
Version : 0130
Internal Serial Number : FF03I1211001059 Y56371 2021:01:26 CA2530110151
Quality : FINE
White Balance : Auto
Saturation : 0 (normal)
White Balance Fine Tune : Red +0, Blue +0
Noise Reduction : 0 (normal)
Fuji Flash Mode : Manual
Flash Exposure Comp : 0
Focus Mode : Auto
AF Mode : Single Point
Focus Pixel : 2208 1242
AF-S Priority : Focus
AF-C Priority : Release
Focus Mode 2 : AF-C
AF Area Mode : Single Point
AF Area Point Size : 4
AF Area Zone Size : n/a
AF-C Setting : Set 1 (multi-purpose)
AF-C Tracking Sensitivity : 2
AF-C Speed Tracking Sensitivity : 0
AF-C Zone Area Switching : Auto
Slow Sync : Off
Picture Mode : Manual
Exposure Count : 1
Shadow Tone : 0 (normal)
Highlight Tone : 0 (normal)
Lens Modulation Optimizer : On
Grain Effect : Off
Color Chrome Effect : Off
Crop Mode : n/a
Color Chrome FX Blue : Off
Shutter Type : Mechanical
Auto Bracketing : Off
Sequence Number : 0
Drive Mode : Single
Drive Speed : n/a
Blur Warning : None
Focus Warning : Good
Exposure Warning : Good
Dynamic Range : Standard
Film Mode : F2/Fujichrome (Velvia)
Dynamic Range Setting : Manual
Development Dynamic Range : 100
Min Focal Length : 27
Max Focal Length : 27
Max Aperture At Min Focal : 2.8
Max Aperture At Max Focal : 2.8
Image Stabilization : None; Off; 0
Image Generation : Original Image
Image Count : 13160
Flicker Reduction : Off (0x0030)
Faces Detected : 0
Num Face Elements : 0
User Comment :
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 4416
Exif Image Height : 2488
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Focal Plane X Resolution : 1882
Focal Plane Y Resolution : 1882
Focal Plane Resolution Unit : cm
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Manual
Focal Length In 35mm Format : 41 mm
Scene Capture Type : Standard
Sharpness : Normal
Subject Distance Range : Unknown
Serial Number : 1S002681
Lens Info : 27mm f/2.8
Lens Make : FUJIFILM
Lens Model : XF27mmF2.8 R WR
Lens Serial Number : 0DA02011
Composite Image : Not a Composite Image
PrintIM Version : 0250
Compression : JPEG (old-style)
Thumbnail Offset : 3808
Thumbnail Length : 8391
Rating : 0
Preview Image Width : 640
Preview Image Height : 480
Preview Image : (Binary data 41986 bytes, use -b option to extract)
Image Width : 4416
Image Height : 2488
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 2.8
Image Size : 4416x2488
Megapixels : 11.0
Preview Image Size : 640x480
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/160
Thumbnail Image : (Binary data 8391 bytes, use -b option to extract)
Circle Of Confusion : 0.020 mm
Field Of View : 47.4 deg
Focal Length : 27.0 mm (35 mm equivalent: 41.0 mm)
Hyperfocal Distance : 13.16 m
Light Value : 3.3
File Name : DSCF9107.JPG
Directory : .
File Size : 6.1 MB
File Modification Date/Time : 2021:09:01 12:13:52+02:00
File Access Date/Time : 2021:09:01 12:16:16+02:00
File Inode Change Date/Time : 2021:09:01 12:13:52+02:00
File Type : JPEG
Make : FUJIFILM
X Resolution : 72
Y Resolution : 72
Modify Date : 2021:08:14 22:25:46
Artist :
Copyright :
Exposure Time : 1/125
F Number : 2.8
ISO : 10000
Exif Version : 0232
Date/Time Original : 2021:08:14 22:25:46
Create Date : 2021:08:14 22:25:46
Shutter Speed Value : 1/128
Brightness Value : -1.73
Flash : No Flash
Version : 0130
Quality : FINE
Focus Mode : Auto
Focus Mode 2 : AF-C
Slow Sync : Off
Exposure Count : 1
Grain Effect : Off
Crop Mode : n/a
Sequence Number : 0
Drive Mode : Single
Drive Speed : n/a
Blur Warning : None
Image Count : 13122
Flicker Reduction : Off (0x0000)
Faces Detected : 0
User Comment :
Color Space : sRGB
Sharpness : Normal
Thumbnail Length : 8586
Rating : 0
Preview Image : (Binary data 39874 bytes, use -b option to extract)
Image Width : 4416
Image Height : 2488
Bits Per Sample : 8
Aperture : 2.8
Megapixels : 11.0
Shutter Speed : 1/125
Thumbnail Image : (Binary data 8586 bytes, use -b option to extract)
Light Value : 3.3
KariP
KariP Veteran Member • Posts: 6,458
Re: Fast lenses for night action shots - quite dark!
Iso 12 000 and f 2,8 - the place is rather dark.
With f 1,4  you could use ISO 3000 ...  and DOF will be very very  shallow .
Perhaps you could use a flash ?  A problematic situation and a f1,2  lens will make it really problematic - just one persons face can be in focus and the rest will be out of focus ...
More light or really high ISO ...  a slightly slower speed might work in some images - buying a new lens is difficult - i think you could /should test some "fast" lens before buying expensive gear like 56f1,2
Kari
I started SLR film photography in 1968. Now two systems: Fujifilm X-H1 + X-E3 and Canon FF gear 5dMkIV + R6
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +13 more
OK.  Well, with those exposure settings I think you can see what your options are.  If you go two stops faster with a lens you can get in the area of 1/320 @ ISO 12800.
I'm not sure what the usage of the photos are but I never want to go over 5,000 for any sort of quality work.  I'll go 6400 or 10,000 if I just have to have the shot.  I'm not sure you're really going to get good images of dancing in the 1/250 - 1/320 shutter range.
Mike Dawson
BJ60EH Regular Member • Posts: 137
Have you considered the 35mm 1.4? It's 2 stops faster meaning you can go from iso12800 to 6400 while still doubling your shutter speed. It has great light transmission(higher t stop) and at 35mm the dof isnt so small that everything will be a blur line with the 56 1.2 or the samyang. You don't need to back up as much either to get the shot.
Used you get them between 350 and 400 all day long and they produce very pleasing images.
 BJ60EH's gear list:BJ60EH's gear list
Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm 50-230mm Fujifilm XF 10-24mm F4 R OIS
What do you think?
Well, you've got yourself some crap light there, that's for sure.
First, if it were me, I wouldn't even think about shooting jpegs, Raws will get you cleaner results and way more control over the mixed lighting color and dynamic range.
If you can get by with a wider angle lens, the 16 f/1.4 and especially the new 18 f/1.4 will get you significantly sharper results across the frame and a decent amount of DOF relative to most other lenses while minimizing motion blur when shot wide open. Otherwise, in these shots, it wouldn't be a bad thing if the everything but the subjects were out of focus so the Fuji 50 f/2 or Viltrox 56 f/1.4 (or 85 f/1.8) might be a good (and cheaper) way to go. I don't know if the Viltrox 56 is any good wide oven, but the 85 is OK. A 35 mm might be worth considering too (the new 33 f/1.4 will be unveiled tomorrow). Personally, except for the Fuji 18 f/1.4 and maybe the 16 f/1.4, I'd probably wouldn't go much, if any, beyond f/2 or so, most lenses don't perform all that well beyond that and don't deliver as much extra light as the aperture increase suggests. Sharper, cleaner images images from the get-go will require less processing/sharpening in post and produce better results overall.
Given what I see in that video you are going to need high ISO.  Without flash you are going to need faster than 1/1000s.  Unless you don't mind blurry appendages but are hoping for a somewhat sharp face.
So if you get a 2 stop faster lens it's going to have to all go into faster shutter speeds.  The ISO is going to have to stay up there.
Mike Dawson
chaimav
chaimav Senior Member • Posts: 1,577
If you are very close to the action and still want to maintain depth of field, consider some wide angle choices. Fuji has a 16mm and and 18mm 1.4, but Samyang has a 12mm f2.
 chaimav's gear list:chaimav's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS
Ad12 Senior Member • Posts: 1,514
If its super important to get the images a lot cleaner, it may be worthwhile to get a FF camera with cheap nifty 50?
Otherwise, faster lenses. The new 33mm XF 1.4 being released tomorrow would seem to fit the bill for a faster/brighter, quicker focusing, lens.
 Ad12's gear list:Ad12's gear list
Nikon D500 Nikon Z6 Sigma 150-600mm F5-6.3 | C Sigma 100-400mm F5-6.3 Nikon Z 24-70mm F4
