Refurbished Fuji X100V?
Started Aug 31, 2021 | Questions
ppuzzlerr New Member • Posts: 3
I had sent my Fuji X100S in to Fujifilm for repair as the EVF and screen would flicker drastically whenever trying to autofocus. Unfortunately, it seems like they don't have the parts to repair the camera and offered to swap it for a refurbished X100V for $950 USD + tax. Does it seem worthwhile to do so, or should I just buy a used X100F?
Fujifilm X100F Fujifilm X100S
yrc4 Regular Member • Posts: 108
Re: Refurbished Fuji X100V?
Ask about warranty on the refurbished X100V; if they have good coverage for it, go for it. The lens is somewhat better and so is AF.
 yrc4's gear list:yrc4's gear list
Fujifilm X100F Fujifilm X-T3 Fujifilm XF 10-24mm F4 R OIS Fujifilm 50mm F2 R WR Fujifilm XF 16-80mm F4 +1 more
OP ppuzzlerr New Member • Posts: 3
They're providing a 6 month warranty on it.
Are you based in the US?  I searched around and while I did not see any used X100Fs on KEH (a very reliable used photo equipment vendor), I did see some at mpb.com (another reputable vendor). They have some used X100Fs for anywhere between $904 to $824.    FWIW, at these prices, I would go for the refurbished X100V.  If you can afford it, then for $950, you are probably going to get a like new X100V.  I would make sure that Fujifilm gives you a return window if you find out  that there is something wrong with it.
AE Conrady
AE Conrady Regular Member • Posts: 252
The Fujifilm X100V is a (much) better camera against the "F", so I would go for it.
 AE Conrady's gear list:AE Conrady's gear list
Fujifilm X100V Fujifilm X-Pro3 Fujifilm XF 18mm F2 R Carl Zeiss Touit 2.8/12 Fujifilm XF 56mm F1.2 R +1 more
Kev the Jack Forum Member • Posts: 56
Ive previously purchased a refurb X100f from Fujifilm - it developed a problem - typically just after the warranty run out.  Probably just my bad luck but it has made me cautious.
https://www.flickr.com/photos/163617094@N07/
 Kev the Jack's gear list:Kev the Jack's gear list
Fujifilm X100V Fujifilm X-T3 Fujifilm X-Pro3
Dave_in_SD Forum Member • Posts: 73
The refurbed X100V sounds like a good deal to me.
John Sevigny Forum Member • Posts: 72
It’s a huge upgrade and you’re getting an x100v for a very good price. The x100v goes for $1,400 new and isn’t always easy to find. It’s by far the best x100 out there. Refurbished usually means they went over it in great detail. Make sure you get some kind of warranty and then pull the trigger.
allineedislight Senior Member • Posts: 1,311
I've bought refurbished cameras from Fuji, and they were in like new excellent condition.  So I wouldn't worry.  if you have the money go for it, as others have said the V is the best!
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
