Panasonic Lumix GX7 and the S-mode with vintage lenses
Started Aug 29, 2021 | Questions
Drahila New Member • Posts: 15
When using an adapted or lens any lens with no electric contacts that GX7 can read, auto-ISO does not work when camera's set to shutter priority mode. Auto-ISO can be selected but it doesn't pump the ISO. I might have a some setting wrong. Any suggestions?
I briefly tested some newer model a while back and I just can't remember the model name (G9?) but it was a Lumix camera and its auto-ISO worked as it should in S-mode, although I tested a manual focus lens without any electrics.
Panasonic Lumix DMC-GX7
MacOrneille Regular Member • Posts: 281
Re: Panasonic Lumix GX7 and the S-mode with vintage lenses
Shutter priority means the camera will adjust the aperture as required.  It can't do that with a manual lens.  Aperture priority or manual  mode is what you want.
OP Drahila New Member • Posts: 15
When Pana changed their S-mode to support auto-ISO with vintage lenses?
Thank you MacOrneille!
I just now got a G85 to my hands. It's wasn't G85 I was testing earlier, but this model also pumps ISO in S-mode, when auto-ISO is selected, and if a lens without electric contacts is mounted.
So I expand my question:
When did Panasonic change the behaviour of their S-mode? I'm looking for an older (aka more affordable) body but it needs to do the auto-ISO in S-mode, even without lens' aperture information.
pannumon Veteran Member • Posts: 4,130
Re: When Pana changed their S-mode to support auto-ISO with vintage lenses?
I can confirm that S-mode is not useful with older Panasonic when using lenses without electronic contacts (=manual focus lenses). I am used to A mode with manual focus lenses, although I admit it would be far better to pre-adjust the shutter speed, set the aperture from the lens and let the camera choose the ISO.
My impression is that the time of introducing DFD (2014?), Panasonic also improved the firmware in other ways (on GH4, G7, GX8). One thing was adding clean HDMI output, and my guess is that they also fixed how manual focus lenses work. All these improvements probably go hand-in-hand with the other improvements of the 2014 version of the Venus engine https://en.wikipedia.org/wiki/Venus_Engine#New_Venus_Engine_%E2%80%93_2014
Edit.: If you want an older Panasonic, there won't be IBIS, but all Olympus bodies have some kind of IBIS. Also IIRC, auto ISO works in S mode with manual lenses even with the oldest Olympus models. Just make sure that it is possible to exit the focus assist mode (magnification) by half-pressing the shutter release button.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
alcelc
alcelc Forum Pro • Posts: 19,003
GX7 can't do it.
On GX85 or later, it works. It could be the firmware issue. Until GX7, M must be manual ISO only, so not sure would it relate to the auto ISO in M from GX85 onward.
Albert
** Please forgive my typo error.
** Please feel free to download the original image I posted here and edit it as you like **
Thank you everybody for a solution, good to have a confirmation that it is a generation issue of GX7 and of other older Panasonic bodies.
Jouko Senior Member • Posts: 1,985
On full manula lenses there are no contacts for the camera to control the aperture, so at S-mode you are basically using the camera as in full manual M-mode. If you want more automatic version, you need to sift to A-mode, which changes the shutter speed automatically, depending on the used aperture and ISO. P-mode does the same with manual lenses, but no more.
On previous messages you got an answer, that it's the model that limits the auto ISO - maybe so, but get the latest firmware anyway.
Have a nice day!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
