Cross compatibility of Olympus lenses with Panasonic bodies
Started Aug 27, 2021 | Questions
Drahila New Member • Posts: 15
Hello.
When shooting a Lumix camera with an Olympus lens, will the Lumix bodies (all/some/none) fully support lens correction profiles, to remote distortion and purple fringing, for example?
I have been offered a set that consist Lumix G80, and lenses m.Zuiko 12-40mm f/2.8 and m.Zuiko 75mm f/1.8.
I already know that 12-40's Fn-button doesn't work with Lumix bodies but that doesn't bother me. What bothers me is that if G80 can't read/write the correction profiles of these two lenses.
Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic G85
Skeeterbytes Forum Pro • Posts: 23,186
Re: Cross compatibility of Olympus lenses with Panasonic bodies
Yes, the correction information is resident in the lens and won't be altered by the Panny body. I happen to love using the 75 on the GM5.
Rick
Old Timer63
Old Timer63 Veteran Member • Posts: 6,018
Well, my Oly pro 12-100 and the Oly pro 40-150 work superbly on my G9. Not sure if the lens correction is being applied but I have never seen any artifacts that suggest the corrections are not taking place. I suppose a WA lens might be a different matter.
 Old Timer63's gear list:Old Timer63's gear list
Fujifilm X-H1 Panasonic Leica Summilux DG 25mm F1.4 Fujifilm XF 14mm F2.8 R Panasonic Lumix DMC-G7 Fujifilm X-T10 +20 more
MOD Tom Caldwell Forum Pro • Posts: 46,352
Add the Olympus 12/2.0 Limited - works fine, quite rectilinear, and I know that it requires firmware correction.   In fact I believe that the firmware correction detail is included in the M4/3 specification.
I also have the 75, 12-100, and 40-150 (also 45/1.8 and probably others) and can confirm that AF seems to work just as well as native Panasonic lenses (DFD or no DFD).
Tom Caldwell
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Drahila wrote:
Hello.
As mentioned, all corrections work.
In my case the other way 'round where I use Panasonic lenses on Olympus bodies.
Even better is to shoot raw files and use DxO Photolab4 where they use their own laboratory derived correction profiles for body+lens combinations that actually work a bit better than the canned corrections coming from the lenses.
Trolleyman Senior Member • Posts: 1,048
Drahila wrote:
Hello.
They all work very well and I know that from first hand user exprience.
The lens function button also works to a limited degree on some Panasonic cameras. This is from my GX9 manual
[Lens Fn Button Setting]
Sets the function to be assigned to the focus button of an interchangeable lens.
• You can call up the assigned function by setting the focus selector switch of a
compatible interchangeable lens to [Fn] and then pressing the focus button of the lens.
Settings: [Focus Stop] / [AF/AE LOCK] / [AF-ON] / [Stabilizer] / [Focus Area Set] /
[AF Mode/MF] / [Preview] / [Off] / [Restore to Default]
●When [Focus Stop] is used, the focus is locked while the focus button is pressed and held.
 Trolleyman's gear list:Trolleyman's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 12-100mm F4.0 +3 more
Richandhiscat Senior Member • Posts: 1,199
Drahila wrote:
Hello.
Everything works fine, and certainly with the G9 and the 300 you can use the function button. The G80 is a great camera.
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
As others have said, the lens corrections work fine. The 12-40mm f2.8 is a cracking lens, the constant f2.8 is what sold the lens to me., hence, I recently bought one and use it on G80. The manual clutch is a very nice feature and works well. A few G80 + 12-40mm images here https://www.flickr.com/photos/dieselgolfer/albums/72157719661820874/with/51399253927/
The G80 is a great camera too,  fully featured and relatively compact.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
OP Drahila New Member • Posts: 15
I was able to mark only one reply as the one that solved my inquiry, but honestly you all helped. So, thank you everybody, this one's solved!
