D850 & not a cat...
lickity split
lickity split Veteran Member • Posts: 6,137
D850 & not a cat...
5
I wanted to see what kinda detail i can get with the 200/4
“Perhaps if you removed some clothing . “
http://www.flickr.com/photos/lickitysplit11111/
 lickity split's gear list:lickity split's gear list
Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF Micro-Nikkor 200mm f/4D ED-IF Sigma 15mm F2.8 EX DG Diagonal Fisheye +11 more
Nikon D850
CptAmerica
CptAmerica Senior Member • Posts: 1,799
Re: D850 & not a cat...
shoot it again at F8 iso200, see what you get.
 CptAmerica's gear list:CptAmerica's gear list
Nikon D850 Sigma 105mm F1.4 DG HSM Art Nikon D4 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G +7 more
lickity split
OP lickity split Veteran Member • Posts: 6,137
Why would it make a big difference ? This is with a bounced flash,I stopped it down to increase its depth of field  which is very narrow as you can see
CptAmerica
Becauase if youre interested in detail, loss of sharpness due to diffraction at F16 and ISO400 isn't going to be ideal. You're better off with more flash, ISO64, at F8. That is where you will see real detail.
lickity split
I’ll see what I get tomorrow, when filling most of the frame with the subject the depth of field is very shallow ( it’s a macro lens) ,it can stop down to f45
I know if I tried this at the minimum focusing distance of the 200/2 which is around 6’ I wouldn’t get the same amount of detail
ill post results tomorrow from both lenses, I’ll open the window blinds too this time.
lickity split
You were correct it gave more detail.
switching lenses gave results i thought they would, the macro lens @ f8 has a big reduction in depth of field which was harder to nail being handheld , the 200/2 gave more of the bird in focus but the detail was not as intense ,the amount of detail overall was incredible it was nowhere near as magnified as the 200/4 ,
The last pic shows shows his eyelashes pretty good
dave gaines
dave gaines Veteran Member • Posts: 9,671
D850 & detail with macro
You're shooting the 200 mm f/2 at farther away and cropping the image to achieve the same subject size, the bird's head. You've cropped to about 20% or less of the frame by my guestimate.
The 200 mm f/4 focuses much closer and so you can fill the frame. Subject distance is reduced so you can dial back the flash or use a smaller aperture, yielding better DOF.
That was your point of course. To compare the two lenses for detail and sharpness with small subjects. Luckily you have a patient subject.
Dave - Be safe. Stay Healthy.
 dave gaines's gear list:dave gaines's gear list
Olympus C-8080 Wide Zoom Olympus E-330 Nikon D800E Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +17 more
lickity split
Re: D850 & detail with macro
Correct, and thank you for summing things up. You get more pixels on the subject with the macro lens because of its minimum focusing distance which is about 18”,( the closer I get the shallower the depth of field becomes) the end of the lens was under 2’ from the bird with the macro and the 200/2 puts you 6’ away and the subject is only a portion of the frame .
They both show nice detail it’s just that one takes things to another level.
The parakeet will sit there all day for you ,good luck getting the finches to do the same.
Petruska Veteran Member • Posts: 9,143
That bird is watching the cat.......
Bob P.
