10 photos with the TG6 (underwater only)
Started Aug 25, 2021 | Discussions
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
23
Following two similar posts in the Fuji X forum (10 photos with the 16-80 and 70-300) , I thought I would share my 10 best from this summer with the TG6. The TG6 proved to be the most used camera!
the only one above water
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Thanks for Sharing!
No text.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
addlightness Veteran Member • Posts: 3,641
Re: 10 photos with the TG6 (underwater only)
Wow!  Makes me full of envy - I'm no way near the skill level as you (I have a TG4).
Where were those taken if you don't mind me asking?
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
pop2eye Forum Member • Posts: 78
7
Here are a few of my own TG-6 photos taken while snorkeling in French Polynesia. All were processed from raw using DxO PhotoLab 4 Elite. The DeepPRIME noise reduction makes huge improvements in the images from the small sensor of the TG-6.
Lagoon Triggerfish
Manta Ray
Giant Clams encrusted in coral
Threadfin Butterflyfish
Magnificent Sea Anemone
 pop2eye's gear list:pop2eye's gear list
Olympus OM-D E-M10 Olympus E-M5 III Olympus 12-40mm F2.8 Pro Olympus TG-6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +2 more
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,308
Thank you for your kind words.
It takes some time to achieve them but its not that difficult.
You mainly need a good model that can dive up to 3-4m, a pair of color fins, a color swimsuit, a nice rocky water bottom (sandy bottom can be less clear) and clear water under the sun. Then you need to add the wide extender lens from Olympus and try to get the right angles.
They were taken in Greece, most of them in Kea and some  in Paros. Both of them are Greek islands in the Aegean Sea.
Yannis1976
Very nice. One improvement I found in the TG6 was the much better JPEG engine for underwater.
DDoram
DDoram Forum Pro • Posts: 10,361
Nice series Yannis
Dale
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
ShatteredSky
ShatteredSky Senior Member • Posts: 2,065
HA, there were 100s of those in Avlemonas last year ... also shot with the TG-5 (and lots more).
Cheers
"Blue for the shattered sky"
 ShatteredSky's gear list:ShatteredSky's gear list
Olympus XZ-2 iHS Panasonic LX100 Olympus TG-5 Panasonic LX100 II Samsung NX300 +5 more
Camrarat Regular Member • Posts: 349
Cheers
How did you avoid getting stung by the jellyfish?
ShatteredSky
Well, the tentacles of this species are short ... so no problem if you are not too clumsy in the water.
Cheers
