H-Alpha 12 nm filters
skyandcave New Member • Posts: 2
Does anyone have any experience with either using or replacing their filters for astrophotography?
Saw the Astronomik H-Alpha 12 nm and it is all way over my head currently. Are they worth it?
swimswithtrout Veteran Member • Posts: 3,892
Re: H-Alpha 12 nm filters
Is your camera modded ? Do you have a mount capable of 6-8 minute exposures ? Using a narrowband Ha filter on a dSLR is somewhat of a waste, because only 1 pixel out of 4 is going to get any signal and the other three will be all noise. Add to that, if your camera is not modded, Ha response can vary from 15-30%  due to manufacturers built in IR filters so 70-85% of it is being blocked by the filter.
Nowadays, it is far more efficient to use something like the the Optolong L Enhance or L-Extreme filters that also have a narrowband Oiii filter built in as well.
I just took this last night in a 88% moon using the L-Enhance on my modded D5300.
Rutgerbus Senior Member • Posts: 2,299
Here you have a comparison what you can expect when you use a 12nm Ha filter.
Both were shot with a non-modified Sony A6000 from roughly the same area in the sky although with different lenses. (Cygnus region).
You see that the Ha-data shows much more gas clouds but only in B&W compared to the "just color" image. Can you imagine what you will get if you combine both color and Ha-data
www.rutgerbus.nl
Photographic Moments
A photon only stops "existing" when it is captured by your sensor.
 Rutgerbus's gear list:Rutgerbus's gear list
Nikon D80 Nikon D700 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED +1 more
mermaidkiller Senior Member • Posts: 1,255
You use only the red channel and you can filter out the other three (2xgreen and 1xblue), so that noise does not bother you.
Well, I can take decent images with my unmodded Canon 6D using an L-enhance filter and sometimes combine it with RGB.
20x3min L-enhance 110mm (aperture)  ED scope f/5.6
20x30sec RGB + 20x2min L-enhance combined. Mars + Pleiades + CA nebula. Canon 85mm f/1.8.
Modding is indeed better, but moderner bodies (and even my 8 years old 6D) allow making decent pictures of the weak attenuated by 75% Halpha signal, if you have enough frames and decent post processing.
Ricoh KR-5 ... Pentax ME Super ... Canon T90 ... ... ... 40d ... 7d ... 6d
 mermaidkiller's gear list:mermaidkiller's gear list
Sony RX100 VI Canon EOS 6D Canon EOS R6 GoPro Hero7 Black Canon EF 85mm F1.8 USM +6 more
Same target, L-Enhance, 100% full moon, modded D5300, f6.5 showing all the Ha the stock cam missed
